"Reduced Engine Power - Visit Your Dealer" message
Discussion in '3rd Gen Tundras (2022+)' started by pjm805, May 16, 2024.
  1. May 16, 2024 at 5:45 PM
    pjm805
    pjm805 [OP] New Member
    I have a 2023 iForce Max with ~10k miles on it, a couple of days ago I was cruising on the freeway under normal conditions and a message showed up "Reduced Engine Power - Visit Your Dealer". The truck itself still felt perfectly fine and I couldn't feel any difference. Took it to the dealer, came back with code P02351C related to the turbos. They reset the code, did a road test, input a DTC code, everything came back with system normal. Has anyone else experienced anything similar? I'm still worried as to what triggered the code.
  2. May 17, 2024 at 4:15 PM
    katekebo
    katekebo New Member
    Did they give you an invoice? It's always good to keep a paper trail of these issues. The reason is that if the problem returns later, after warranty expires, you have a proof that the problem started while the car was still under warranty and claim that it should be repaired at no cost. Most manufacturers will honor warranty as long as the problem was reported earlier (within a reasonable timeframe).
    Blufin, mountaingroan and Jettster like this.
  3. May 17, 2024 at 11:42 PM
    pjm805
    They did luckily, definitely saving it
  4. May 24, 2024 at 8:05 AM
    Multiple toyotas
    Multiple toyotas New Member
    23 tundra lunar rock
    I have a 23 Sequoia. At 11,000 miles message "Reduced Engine Power- Visit your dealer." Restarted vehicle and light went out, ran normally- never noticed any change. Dealer found the same code P02351c. They found "pressure reading with vacuum applied is out of spec"- contacted Toyota and were told to replace the Turbo.
  5. May 24, 2024 at 8:08 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Is that a gas cap code?
  6. May 24, 2024 at 8:18 AM
    TRDoffroadPRO
    have you been running heavy ethanol based fuels or 87 octane only?
  7. May 24, 2024 at 8:30 AM
    Multiple toyotas
    In my Sequoia, I only used regular unleaded.
  8. May 24, 2024 at 8:34 AM
    TRDoffroadPRO
    Depending on where you buy gas or live can depend upon how much ethanol is in the fuel. Most that say 10-15 percent are more like 20-30 percent in actuality. I am not telling you or anyone what to run, but I have always at least run a mid-grade but most times premium fuel without ethanol. Try to find those type dealers since these new turbo vehicles say they will run on regular unleaded they tend to not like the fuel very much.
    jstmahoney likes this.
  9. May 24, 2024 at 8:47 AM
    Multiple toyotas
    Thanks for the advice! I live in Michigan, typically just fill up at Walmart or local stations.I will definitely look at upgrading the fuel. I love my Sequoia ( coming from a 2018 4runner) and want it to last a long time!
  10. May 24, 2024 at 8:52 AM
    RallySauce
    RallySauce New Member
    Middle TN
    ‘23 MGM SR // ‘20 T4R ORP
    not to change the topic of this thread, but i was very skeptical of running anything other than regular. Ive ran through 2 tanks of premium and the difference is small but noticeable. Much better idling, smoother acceleration (may be placebo effect tbh), and my mpg kicked up about 1-1.5 mpgs. Obviously long term effects remain to be seen, but short term ive seen enough to make me spend the little extra.
    24_SR and kirkb like this.
  11. May 24, 2024 at 9:57 AM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    The jist is higher octane grades have better resistance to the fuel combusting when it's not supposed to (Detonation.) That's why it's recommended on many turbo or high compression engines. Even though the Tundra says 87 octane minimum, I've always used ~92 (Or even clear non-e) on anything I've owned turbocharged. Whereas I use 87 in our 2019 Highlander.
  12. May 24, 2024 at 10:13 AM
    TRDoffroadPRO
    Yeah ethanol causes all kind of egr issues and will kill an OEM cat around 100 thousand miles. I get that is more expensive to run but it is the ethanol that tends to kill engine longevity and usually results in clogged cats, fouled plugs, and clogged injectors over continued usage. You can fill up with regular and run a tank or so of premium through a month and that helps clean off the excess carbon build up.
  13. May 24, 2024 at 10:21 AM
    pjm805
    Could that be part of the problem? Even though Toyota says 87 is okay, maybe it's not and causing some of these issues?
  14. May 24, 2024 at 11:31 AM
    SpilledTheSalt
    Oregon
    To each his own, but for me, it just makes sense to run a high octane gas in a turbocharged vehicle, even if it doesn't specifically require it. Higher octanes are more stable and have better resistance to detonation. To clarify, though, octane rating and ethanol content are two separate things. All 3 standard grades (87, 89, ~91+) will have ethanol in them. The fourth option would be clear gas or non-ethanol. It is high octane without ethanol, but is generally quite a bit more expensive comparatively if you even have it available near you. (A couple stations near me have it at roughly $1-$1.50 a gallon over the normal 92 octane premium.) It does provide slightly better fuel economy than those with ethanol. Keep in mind, though, vehicles are designed to work fine with 10-15% ethanol. It's more detrimental to small engines like generators, where it gums up the carburetors if you leave it in there for any period of time.
  15. Jun 18, 2024 at 1:59 PM
    Wessinger73
    Wessinger73 New Member
    2023 Tundra 1794 Edition
    Had several BMWs with turbos. Always ran premium. Figured I would at least run mid-grade in the Tundra.
  16. Jun 18, 2024 at 3:59 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I always fill at half or 3/4 tank. I alternate premium and regular.
    Tundrastruck91 likes this.
  17. Jun 18, 2024 at 6:49 PM
    lapoolboy
    lapoolboy New Member
    I've burned nothing but 92+ since new. Like others have said, I feel better with higher octane on a TT engine. Just personal preference.
    kirkb likes this.
  18. Jun 18, 2024 at 8:15 PM
    tesilential
    tesilential New Member
    Tampa bay
    ‘24 limited lunar rock hybrid TRD off-road
    I have 87, 89 and 91 near me. Also have Non-ethanol 87
    91 or nonethanol 87? (Might even be 89)
  19. Jun 18, 2024 at 8:40 PM
    SpilledTheSalt
    Oregon
    91, IMO. Only do non-e if its high octane. Higher octane is less likely to cause knocking. It seems weird to me that 87 is even deemed ok with this engine.
    Metro14536 likes this.
  20. Jun 18, 2024 at 9:47 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    All our pumps say "No more than 10% ethanol." If someone were to test the fuel and find more than 10%, I'm sure there would be a lawsuit.
  21. Jun 19, 2024 at 12:50 PM
    TRDoffroadPRO
    Are you sre about that? Go test it and find out. I can't say yes or no but there are videos out there that test your theory.
  22. Jun 19, 2024 at 1:02 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I believe non-ethanol versus the corn juice blend is more important than octane rating. If you've ever torn apart a carburetor (yeah I'm showing my age) that has been running on corn juice, you'd know why. That crap creates a gooey mess on anything it flows thru, especially if it sits for a while. I always try to find stations with non-ethanol.
  23. Jun 21, 2024 at 11:32 AM
    Bourbonator
    North ID
    '23 LE CM 6.5
    Then
    1) why hasn't it made the news
    2) why haven't state regulating agencies been contacted
    3) why aren't the stations and refineries being sued into oblivion?
    I can grab one of my jerrycans, pour some gasoline into a graduated cylinder, and say to my YouTube audience, "look, more than 10% of this is ethanol!" Did I actually test anything, or do anything about it?
  24. Jun 21, 2024 at 4:32 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    After 15 years and 325k with diesels dual turbos as my primary driver, these rigs have a ton of sensors and warning conditions. Reduced engine power is the check engine light of yester year. The vehicle is not happy and it could be something trivial or total FUBAR.
  25. Jun 21, 2024 at 6:42 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    The Toyota Forklift diesels are electronically controlled and not serviceable. New ones are Garrett Turbos @ $5k. So anything is possible as far as a glitch hope the op has smooth sailing. @Eurodriver could work the bugs out?
    Eurodriver likes this.
  26. Jun 21, 2024 at 6:49 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    I've heard the Mexican tuneup works wonders, even for break-in.
    pwpblue[QUOTED] and Eurodriver like this.
