SPC upper ball joint - DESIGN UPDATE and Part number
Discussion in 'Suspension' started by Tundra234, Jun 21, 2024.
  1. Jun 21, 2024 at 9:45 AM
    Tundra234 [OP] New Member
    So when I was having my wheels installed, the tech showed me that my upper ball joints were worn. They have about 50K miles on them. I called SPC today to discuss this since the site shows 3 variations of the ball joints that may arrive with the control arms depending on where they ship from and how old the stock is.
    1- original ball joint with zerk fitting
    2- sealed and maintenance free ball joint without zerk fitting
    3- sealed maintenance free ball joint with all black housing
    He said that the joint failures that they are seeing is due to lack of grease and them not being serviced regularly. They were redesigned to create option #2 making them maintenance free. States that perform vehicle inspections had issues with the internal springs which led to design #3. The black housing joint is OEM style in design and is the only one in production. The other 2 designs have been discontinued.
    The part # is SPC 35102. Slee Offroad currently has them in stock. Installation instructions are attached as well. There is a higher torque value than what the previous joints required.
    https://www.spcalignment.com/index....part_description&pid=35102&Submit_form=Submit
    pvn.beluga and crikeymike like this.
  2. Jun 21, 2024 at 9:45 AM
  3. Jun 21, 2024 at 9:57 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    $218 for both or one? My uniball uppers are 50k+ miles and still goin strong. I have the replacement unis ready and waiting but don't need to do the swap yet. I use tri-flow on them after every wash.
    pvn.beluga likes this.
  4. Jun 21, 2024 at 9:59 AM
    They are $174 for both from places like Slee, Toytec, etc. I just linked the SPC site as it shows the details of the new design.
  5. Jun 21, 2024 at 11:19 AM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    SPC has been on this train forever. Bad ball joints and then blaming it on consumers using the wrong grease. It's always everyone else's fault and no reasoning as why other brands don't have the same issues.
    Unfortunately I've gone through this with them on two vehicles. Their bushings are known to fail as well and they even had cracking of their welds and upper control arms failing.
    Silverhorse likes this.
  6. Jul 26, 2024 at 9:07 PM
    Ry24000
    Ry24000 New Member
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    I just replaced my Ball Joints recently 40K miles. All the other joints on my rig are in good condition! Common SPC, get yer poo together! I hear a lot of people are having troubles with these joints in all makes and models. Nothing worse than a bad joint.
  7. Nov 18, 2024 at 5:15 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Have had mine on for 40k now, no signs of issues with my ballpoints at all. Greased 10-12
    pumps of molybdenum every 5k oil change.
    Can of brake cleaner and a tooth brush cleans it up nicely.
  8. Jun 21, 2025 at 7:49 AM
    Silverhorse
    Silverhorse New Member
    Same issue...SPCs WORN OUT IN 2 YEARS...
    And worse ate up my tires..
    Not sure I trust them on the re design...
  9. Jun 21, 2025 at 11:10 AM
    Were they the greasable? Those have to be religiously greased or they will wear out. The new ones are maintenance free.
