Getting alignment tomorrow, what should I expect as far as numbers ?
Discussion in 'Suspension' started by TheBeast, Sep 22, 2017.
  1. Sep 22, 2017 at 3:47 PM
    TheBeast
    TheBeast [OP] The Beach
    gen 2 TRD 4x4 with 5.7L
    stock rear with oem Kings shocks
    front has TC UCAs and oem Kings shocks set to default ( pretty much level truck) so probably 2" lift front.
    what should I expect as far as numbers ? or close to it so I can check what the technician doing.
  2. Sep 22, 2017 at 6:37 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Not sure if this will help but here is the print out from my '13 after doing Bilstein 5100's. The front is up 1.7" with stock UCA's. It rides great and the numbers might at least get you close.20170503_191942.jpg
    TheBeast[OP] likes this.
  3. Sep 22, 2017 at 8:38 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    You should have no problem getting back in spec with a 2" level.
  4. Sep 23, 2017 at 3:08 PM
    TheBeast
    just got back from alignement place. All in the green :) similar numbers to above sheet
    duece292 likes this.
