Clunking noise when coasting to a stop and pressing on accelerator
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andhon, May 17, 2024.
  1. May 17, 2024 at 10:01 AM
    Andhon
    Andhon [OP] 2014 Platinum MGM CM
    Andy
    2014 Tundra Platinum MGM CM
    I have a 2014 CM and for the past year, I have been getting this clunk noise when I am coasting and then pressing on the accelerator. I also get this clunk when I'm reversing and then shifting into drive. I have greased all my joints a few times and checked for carrier-bearing play but those don't seem to be the issue.
  2. May 17, 2024 at 12:28 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Assuming the trans is in good shape, good fluid, etc. I would look at ujoints and pinion next. You dont say what tires you run, but larger tires (34+) can induce some driveline clunk, especially with with stock gears. And doublecheck that carrier bearing.
    KNABORES likes this.
  3. May 17, 2024 at 1:05 PM
    Andhon
    Andy
    Just did a fluid drain and refill for my trans, front and rear diff and transfer case, and everything looked fine. You know what I started noticing this issue after switching to 35's. Would regearing possibly fix the clunk? And should I be concerned about the clunk if I stayed on stock gears? i have the tow package so my gears should be 4:30
  4. May 17, 2024 at 2:00 PM
    bfunke
    bfunke Tundra Curmudgeon
    Check your yoke slip joint and u-joints. If you have zincs lube them.
    WFD473 and SpottedDog like this.
  5. Jun 5, 2024 at 12:03 PM
    Andhon
    Andy
    Yeah I've greased them a few times after getting the truck and I'm still having the same noise
  6. Jun 5, 2024 at 3:20 PM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    How many miles do you have on the truck?
    Test the truck by getting it to do the clunk on a section of road. Put the truck in 4x4 and run the same section of road the same direction. See if the clunk stays the same or changes.
    Andhon[OP] likes this.
  7. Jun 5, 2024 at 3:56 PM
    Andhon
    Andy
    I have about 135k miles
    Ill give it a try and will update! thanks
  8. Jun 5, 2024 at 5:08 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    super random but i had a clunk to, randomly whenever i braked or accelerated (but not all the time). turns out my pops had put a thin piece of plywood as a barrier in front of the rear window when we were hauling some junk, but the barrier fell down in between the cab and the bed. any momentum would cause the plywood to smack a wall and cause a thunk. it was real hard to see, and even harder to get out...
  9. Jun 5, 2024 at 5:18 PM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    The 4x4 test is really just to see if there is any change in the clunking which may point to driveline.
    I have found clunks in rear ends of Toyota trucks due to axle wrap, slip yolks sticking (axle wrap), and bad bushings on rear control arms.
    Front end clunks (more common) are ball joints, CVs, diff bushings, sticking slip yolks, tie rods, bad steering rack bushings... I even had a Land Cruiser where I found the diff drop that had been installed wasn't torqued properly and was causing the pop at the frame mount bolts. These can be annoying to track down but eventually it will be found.
    bflooks and Andhon[QUOTED][OP] like this.
  10. Jun 6, 2024 at 11:57 AM
    Andhon
    Andy
    I assume the only way to get rid of the axel wrap is to get traction bars? The clunking noise is for sure coming from the back end. I forgot when the clunking/loud ticking started but it started either when I switched from 33's to 35's or when I changed my leaf springs to the icon RXTs
  11. Jun 6, 2024 at 1:57 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Hi OP,
    Have you tried jacking up your wheels and spinning them? I just recently came back from a road trip and heard clunking sounds more when I was driving in the city vs on the highways that left me wondering what it was. Turned out to be my TPMS broke off inside the wheel. At first it sounded like it was coming from the rear of my truck so I jacked up the rear spun both tires they were fine. Jacked up the front and found it to be my front passenger TPMS.
    https://www.tundras.com/threads/clang-sound-on-passenger-side.123422/#post-3606739
    Edit:Just realized you said you've had the clunking noise for a year but you recently changed your tires so that might cancel that possibility out :(
  12. Jun 6, 2024 at 2:03 PM
    Andhon
    Andy
    Hmmm I'll give it a shot when I get home from work... I don't think that is the issue because I only get the clunk/ticking noise when I reverse and then shift back into drive or when my truck downshifts and then I accelerate. (my TMPS light is always on lol)
  13. Jun 6, 2024 at 3:57 PM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    I'd start focusing on the driveshaft to see if the slip yolk is actually slipping. It will create axle wrap. Then check the rear control arm bushings for play. It's very rarely the uppers, focus on the lowers with a pry bar to see if they compress.
    Andhon[QUOTED][OP] likes this.
  14. Jun 6, 2024 at 4:13 PM
    Andhon
    Andy
    Rear control bushing? 2.5 gen tundras don't have track bars? lol
  15. Jun 6, 2024 at 4:45 PM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    They have one, which centers the axle under the vehicle.
  16. Jun 7, 2024 at 8:20 AM
    Andhon
    Andy
    Wouldn't that just be the carrier bearing? sorry I'm confused lol
  17. Jun 7, 2024 at 10:40 AM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    I would also check the shock mounts they possibly could be worn out.
  18. Jun 7, 2024 at 7:39 PM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    Carrier bearing = rear driveshaft
  19. Jun 10, 2024 at 8:23 PM
    SC_Mike
    SC_Mike New Member
    2019 Crew Max in Cement 4WD
    None really.
    I had a similar problem with my 2011 Tundra, 130k miles. Mine seemed to have too much backlash in the ring and pinion in the rear differential. Try chalking the wheels, putting it in neutral and grab the differential yoke and see if it will rock back and forth. Took it to the local dealer they told me it was "in spec" nothing to worry about. I ended up trading it.
    Good luck.
  20. Jun 19, 2024 at 8:10 AM
    Andhon
    Andy
    Shock mounts look good!
    I tested it in 4wd and am still experiencing the same clunk noise when reversing and then shifting into drive :/
  21. Jun 19, 2024 at 8:12 AM
    Andhon
    Andy
    My truck drives fine... besides feeling sluggishness from the 35's lol. I checked the carrier bearing and it looks like its in good condition and does not have a lot of play
    BiiigTruck likes this.
  22. Jun 19, 2024 at 8:14 AM
    Leaf sprung vehicles don't have track bars. The leafs center the axle all ways.
    OP, still sounds like a U-joint, even if they "seem OK" they can be bad. Get outside and look under the vehicle and have someone else perform the offending operation to pinpoint the source of the clunk.
  23. Jun 19, 2024 at 8:16 AM
    Andhon
    Andy
    Yeah I'm planning on doing this this weekend! ill keep yall updated! Thanks!
  24. Jun 19, 2024 at 8:19 AM
    Andhon
    Andy
  25. Jun 19, 2024 at 8:21 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I also think it's a u-joint. I had an old Chevy that chewed up u-joints like candy. I'd always have a couple spares in the truck box and got real good at changing them.
    CaptRussia253 and Andhon[OP] like this.
  26. Jun 19, 2024 at 10:29 AM
    Andhon
    Andy
    Would you recommend that I change all of them? i feel like might as well since I have the drive shaft taken off
  27. Jun 19, 2024 at 10:40 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wouldn't hurt. Don't know your mileage....
  28. Jun 19, 2024 at 10:58 AM
    Andhon
    Andy
    Im at about 135,000 miles! Do you guys have any recommendations on which U-Joints to get? (I prefer the greaseable ones)
  29. Jun 19, 2024 at 11:03 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm a Spicer guy but for Tundras there could be something better - @reywcms @snivilous
    snivilous and Andhon[QUOTED][OP] like this.
  30. Jun 19, 2024 at 11:10 AM
    Andhon
    Andy
