SEVEREUpper Radiator Hose Leak
Discussion in '2nd Gen Tundras (2007-2013)' started by Albinator, Jun 18, 2024.
  1. Jun 18, 2024 at 3:01 PM
    Albinator
    Albinator [OP] SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    My mechanic said that my upper radiator hose has a 10/10 SEVERE leak. Is this considered severe?
  2. Jun 18, 2024 at 3:23 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Uhh no, no it's not. That's a minor seep.
  3. Jun 18, 2024 at 3:39 PM
    I'd give it a 1/10 since I can see some pink crustys. If you've never replaced the hose, it is a 2008, so that hose is 16 years or so old. I would replace the hose and the clamps, both upper and lower.
    Cruiserpilot likes this.
  4. Jun 18, 2024 at 7:21 PM
    Albinator
    Utah
    You’d replace them both even if it’s a 1/10 just because of their age?
  5. Jun 18, 2024 at 7:21 PM
    Albinator
    Utah
    I thought the same…
  6. Jun 18, 2024 at 7:36 PM
    Yes. I would replace 16 year old hoses because of their age and because they are starting to leak. 100%.
  7. Jun 18, 2024 at 7:36 PM
    BIGUGLY
    Paul
    2018 Limited
    But yes at that age replacement is a good idea, a lot of time it's not mileage that ruins hoses it's time. Plus those hoses and clamps are not expensive
    Black Wolf and KNABORES like this.
  8. Jun 18, 2024 at 9:34 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    This is called preventative maintenance.
    This is called "Can someone come get me, I'm broken down half way between Vegas and LA in August at 112F"
    I'm a preventative maintenance guy. My response is facetious, but it has merit. In the end my decision is which is actually
    cheaper. Aside from the cost of doing a proper coolant flush and fill, this also makes me look at water pump, thermostat
    and all the other parts that might 'just have a seep' too.
  9. Jun 19, 2024 at 10:17 AM
    Canman
    Canman New Member
    2007 Crewmax Limited
    I’m in the process of replacing my rad with new OEM hoses. They were not cheap. Think collectively, they were at round CAN$140 total.
  10. Jun 19, 2024 at 10:47 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Have you looked at Rock Auto? I know they sell in Canadian dollars but the shipping/taxes coming in can be a pain but
    they have options on parts quality and supplier. I've used them only a couple of times but example the front RH
    catalytic converter was worth it that time. Just an option if you haven't looked. I have US CC since I work lower 48
    a lot. But doesn't make it cheaper, just easier. Unless you can drive down to border mailboxes and cross that way.
  11. Jun 19, 2024 at 12:44 PM
    Canman
    Canman New Member
    Yeah, shipping is really a deal breaker with RockAuto unless you are ordering lots of stuff. I do order from them from time to time though, and the other option I have is to order stuff in the US and have it drop shipped to Ogdensburg, NY which is only 1.5 hrs away.
  12. Jun 19, 2024 at 12:59 PM
    AZBoatHauler
    So.Arizona
    I put Mishimoto silicon rad hoses on after 5 years on the OEM.
    Black Wolf likes this.
  13. Jun 19, 2024 at 6:01 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I had 3 yr old upper heat hose fail with a pinhole leak. Took 2 days to figure it out, and I was offroading in Yukon.
    Cost me 2 hotel nights and lot of lost sleep. That was with all newer hoses, it can happen anytime after that.
  14. May 4, 2025 at 3:19 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    My 17 is doing the same thing im at 97,000miles. weird. Neither hose nor the clamp have ever been off or touched
