Bilstein shock loose
Discussion in '1st Gen Tundras (2000-2006)' started by mike's limited, Jun 13, 2024.
  1. Jun 13, 2024 at 3:39 AM
    mike's limited
    mike's limited [OP] New Member
    05' Limited DC 4x4
    Stock
    I had a rattle underneath my 05' DC 4x4 and found my rear driver side bilstein was loose on the top mount and had been bouncing around. I am mostly worried about the shock mount and if it is damaged, and whether or not it may need to be repaired or replaced?
    I sprayed with PB blaster the last two days I was kind of hoping I could just crank the nut on top tight again and be able to drive safely for the time being?
    The boot on this paticular shock was hanging and mostly torn off. I have attached pics and appreciate any feedback!
  2. Jun 13, 2024 at 3:46 AM
    Why’s the metal washer puckered like a starfish? If it was normally flat, I’d say you’ve got an issue with it and it most likely needs a weld repair patch to reduce the hole size.
    Weagle likes this.
  3. Jun 13, 2024 at 4:46 AM
    mike's limited
    05' Limited DC 4x4
    Stock
    That's kinda what I thought, and am afraid of. Thnx
  4. Jun 13, 2024 at 5:09 AM
    I’d say it’s not unrepairable though since there appears to be plenty of good metal around it to brace the force of the shock from a new plate of steel being welded in there.
  5. Jun 13, 2024 at 5:13 AM
    I’d like more pics. Clearly a new shock is called for but that looks more like an internal clamped piece of the shock than a crumpled washer to me.
    And I’d be more worried about the delamination I'm seeing in all that rust more than the shock. That’s pretty rough.
    You didn’t buy the shocks on scAmazon by chance, did you?
    Weagle likes this.
  6. Jun 13, 2024 at 5:27 AM
    mike's limited
    05' Limited DC 4x4
    Stock
    Why do u ask? Are there some shady bootleg Bilsteins sold on scAmazon? I had them installed about 4-5 yrs ago. I'd have to do some research as I dont remember where I purchased them.
  7. Jun 13, 2024 at 5:37 AM
    Possibly. scAmazon and fleaBay are both widely known for selling counterfeit/knockoff parts, especially automotive, small engine, and appliance parts. We had one guy on here who bought 5100s off scAmazon, and they came with very suspicious shaft ends that weren't finished like any legitimate 5100.
  8. Jun 13, 2024 at 7:50 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    so...ummmm....where’s the upper shock bushings? The shock stem is threaded only partially, and the nut that’s currently on there might already be threaded down to the very ends of them.
    Or can i not see the bushings for some reason? If they’re scamazon/fleabay Philistine 5100’s, perhaps the bushings were made out of old tennis shoe mid soles?
    JasonC. and FrenchToasty like this.
  9. Jun 13, 2024 at 10:49 AM
    My guess is OP didn't install them properly. And I'm pretty sure that shock is completely blown, and what you're seeing up there is a cap that was once inside the shock.
  10. Jun 15, 2024 at 6:41 AM
    mike's limited
    05' Limited DC 4x4
    Stock
    OP had them installed. The bushing is collapsed and pushed thru.
  11. Jun 15, 2024 at 6:48 AM
    mike's limited
    05' Limited DC 4x4
    Stock
    That is correct. Thanks.
    I think I bought them from auto anything, but not positive.
    Any recommendations on where to go for decent new rear shocks other than bilstein? I'd like to just pick some up locally rather than wait for them to ship, if I can. I live in the Milw area. I called around for bilstein and it's special order everywhere Ive called. Thanks again guys
  12. Jun 15, 2024 at 8:29 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
    :rofl::rofl:
  13. Jun 15, 2024 at 4:40 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    KYB
  14. Jun 16, 2024 at 6:01 AM
    bfunke
    bfunke Tundra Curmudgeon
    Just order from the rock. They ship is 2-3 days
    mike's limited[OP] likes this.
