  1. Jun 15, 2024 at 2:51 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Feels good, don’t it? Nice work!
  2. Jun 15, 2024 at 2:52 PM
    bfunke
    bfunke Tundra Curmudgeon
    Have you checked out the hiking trails in Amicalola and Ellijay?
  3. Jun 15, 2024 at 3:00 PM
    The Black Mamba
    DFW
    Imma keep it stock
    All chrome trim on the drivers side is now gloss black. The peeling trim under the window is now flat black. I’m not doing anymore today. I’ll save the passenger side for another weekend. I’ll eventually debadge and also take some restorer to the faded black trim and mud flaps.
    Vader03, Voss, bmf4069 and 10 others like this.
  4. Jun 15, 2024 at 3:26 PM
    Openbaffle
    Openbaffle New Member
    Sure does!
  5. Jun 15, 2024 at 3:32 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Anyone have any recommendations on how to fix this crack in the bumper?
  6. Jun 15, 2024 at 3:34 PM
    Black don’t crack
    Voss, bmf4069, oscardog86 and 13 others like this.
  7. Jun 15, 2024 at 3:36 PM
    We need to check out Sarah's Creek. Far Northeast corner of the state near NC/SC border. Videos on YouTube.
    Voss, bmf4069, oscardog86 and 5 others like this.
  8. Jun 15, 2024 at 4:04 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Now you need some 303 on some of those trim pieces Mang.
  9. Jun 15, 2024 at 4:21 PM
    Replace the bumper skin. Only other option is to epoxy in a backing plate and fill with a flexible filler. But with how jagged that is, and knowing you gotta repaint anyway, you may as well just replace the skin.
  10. Jun 15, 2024 at 4:25 PM
    Plastic welding. It’s a fairly involved process.
    455h0le_dachshund likes this.
  11. Jun 15, 2024 at 4:32 PM
    artsr2002
    'Yonder
  12. Jun 15, 2024 at 4:34 PM
    artsr2002
    'Yonder
    I have some damage on my bumper cover as well. I believe it's from the headlight bucket reflecting sunlight onto the cover. I'd probably sand down to smooth, clean and maybe add some body filler to level it, sand it smooth, then prime and paint.
  13. Jun 15, 2024 at 4:35 PM
    You've gotta use steele wavy brads for that, though, and the stuff to install the right way is $$$
  14. Jun 15, 2024 at 4:47 PM
    It’s not really a DIY job unless you’ve done a lot of it. Not something I’d attempt myself. Leave it to those who are more skilled at it.
    shifty`[QUOTED] likes this.
  15. Jun 15, 2024 at 5:58 PM
    artsr2002
    'Yonder
    Just finished installing the included backup cam for my dash cam mirror. I had to get an extension as the included video cable wasn't long enough. The company I bought it from on scAmazon never responded to my requests for a longer video cable. It's not even around on scAmazon anymore. Figures. Stupid pop up Chinesium sellers with retarded names. Lol.
    I broke the screw retaining legs on the sill plate cover and now only the front most screw holds the trim plate down. Gonna see if I can find some plastic retainer clips to put into the square holes the screws for thru before I look for a sill cover replacement which considering it's a best gen first Gen, it'll probably cost $300 and only 3 were ever made. Lol
    Update: Went to Lowe's for some clips to try and fix the sill plate trim and also to get a longer eye bolt for additional LSPV adjustment. I'm topped out on the stock one.
    Voss and The Black Mamba like this.
  16. Jun 15, 2024 at 6:01 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Have a bunch of Type T-IV from Toyota ready for this job but was planning a full flush using ideas from these methods:
    Timmy
    Fix it Angel
  17. Jun 15, 2024 at 6:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You got it.
    I've done two so far, separated by two oil changes. So I'll do a third (and hopefully last one for a while) in two more oil changes.
    MT-Tundra[QUOTED] likes this.
  18. Jun 15, 2024 at 6:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Needs black lug nuts.
  19. Jun 15, 2024 at 6:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    New bumper or junkyard
  20. Jun 15, 2024 at 6:25 PM
    ToyotaDude
    ToyotaDude Member
    Really like this channel. Lots to learn about body work and painting. Re the repair he shows here, just recently used similar technique instead of replacing a 1G Taco front Mud Guard for $126.28 retail. Repaired a tear out on a mounting hole by using heat to melt, rejoin, and re-form it like he did here with the bumper, but of course no cosmetic fillers or paint needed to put it back into service.
    shifty` and artsr2002[QUOTED] like this.
  21. Jun 15, 2024 at 6:33 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I would do that for sure but I have not seen them as still available. I’ll keep looking but I guess maybe look at junk yards
  22. Jun 15, 2024 at 6:35 PM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    so still new to me...2 weeks..unfortunately i have done several things today. I bought this from a friend who has owned 15 years....he has a "friend" that is a toyota wrench who works on the side to pay his rent to the previous owner. The repairs were crap. so what I did today.....put on a new tailgate handle, fixed the brake lights..not bulbs..fixed the door lock driver side, fixed windshield washer...needed a hose....fixed driver side headlight, he had tagged in pod lights to the high beam on driver side with a tap...which kept blowing fuse.
    thing is , i feel sorry for the friend I bought this from...he is about as honest as it comes...he has been ripped off by "mechanic". When he sold it to me I took his word for the work done. supposedly in the past year had the front suspension rebuilt....all I see is new shocks and one new upper ball joint....had the brakes rebuilt...pads are near metal.
    timing belt...by same wrench .....says asian..30k ago....now I dont trust
    like I said, the owner i bought it from is an honest guy....everyone that know him has high respect....so I did not doubt his word when I drove it. drives great and I was in a hurry..and up here in alaska they sell fast, like same day
    2002 access cab, 242k miles 4wd, almost no rust..$4500 to a "friend..me" had it listed at 6 and had offers. sight unseen within a half hour of posting..his girlfriend posted without her knowing he offered it to me .
  23. Jun 15, 2024 at 6:47 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Ordered
  24. Jun 15, 2024 at 6:50 PM
    artsr2002
    'Yonder
  25. Jun 15, 2024 at 6:54 PM
    artsr2002
    'Yonder
    Posted RockAuto link for you. Shit, just realized they all out of stock. Lol.
  26. Jun 15, 2024 at 7:32 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Tundra2 and shifty` like this.
  27. Jun 15, 2024 at 9:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I think it's cute yall care about dents, dings, holes, and scratches :rofl:
    bmf4069, oscardog86, abcinv and 8 others like this.
  28. Jun 15, 2024 at 9:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Mountun Goat likes this.
  29. Jun 15, 2024 at 9:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  30. Jun 15, 2024 at 9:38 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :rofl::rofl::fistbump:
    Tundra2[QUOTED] likes this.
