Can't Find 2004 Fog Light Switch
Discussion in '1st Gen Tundras (2000-2006)' started by Dook55, Jun 15, 2024.
  1. Jun 15, 2024 at 11:33 AM
    Dook55
    Dook55 [OP] RCLB Guy
    Montana
    My 2004 RCLB SR5 has the factory fog lights in the front plastic and I have never been able to turn them on because I can't find the switch. The manual says there is a band on the light switch that you twist, but mine has no such band. I have no record of the light switch assembly ever being replaced, but I guess it's possible someone put the wrong switch on it. Where is the stock fog lamp switch on your 2004?
    Also, looking at the lights from the front, both of mine appear to have an inch of water in both of them. Is this a common problem?
  2. Jun 15, 2024 at 12:19 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    On my truck (a 2001) it’s the left-most black circular switch.
    Dook55[OP] likes this.
  3. Jun 15, 2024 at 12:24 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Mine is 06 but sounds like it is the same or very similar
    I've got my fingers on it here in the off position
    here it is in the on position
    Dook55[OP] and whodatschrome like this.
  4. Jun 15, 2024 at 1:01 PM
    bfunke
    bfunke Tundra Curmudgeon
  5. Jun 15, 2024 at 1:02 PM
    Water intrusion is not a common problem if it's the round fogs. I can't remember any of the trucks I looked at having that much buildup. Possibly they're aftermarket garbage.
  6. Jun 15, 2024 at 1:47 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I've found that the turn signals are much more prone to filling up with water than the fog lights.
  7. Jun 15, 2024 at 1:48 PM
    whodatschrome
    lots of dents
    My 2004 AC had the exact same fog light switch
    Dook55[OP] and Weagle[QUOTED] like this.
  8. Jun 15, 2024 at 2:20 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I grabbed a fog light switch stalk for cheap and swapped out my original stalk that didn't have the fog switch. I kept my original in case. The new one was cheap and has worked great. The only other thing I had to do was install the fog relay in the back of the fuse panel under the driver side dash. That was fun. Had to twist and mangle my hand to get it in there. Lol
  9. Jun 15, 2024 at 2:21 PM
    artsr2002
    'Yonder
  10. Jun 15, 2024 at 2:28 PM
    Dook55
    Montana
    Thanks for the reply. Mine has the mirror heater in that position.
  11. Jun 15, 2024 at 2:31 PM
    Dook55
    Montana
    Thanks for the reply. My 2004 SR5 does not have that. I just checked my 2006 (base model) and it doesn't have that band either.
    So I'm thinking the switch must have been replaced.
    Thanks to all who replied.
  12. Jun 15, 2024 at 4:08 PM
    artsr2002
    'Yonder
    My 05 SR5 didn't have the band on the stalk either but did have the fog plugs zipped out of the way behind the bumper and I used the relay from my trailer fuse box under the hood. The wiring was in place but I needed the stalk and relay.
