Oil change
Discussion in '1st Gen Tundras (2000-2006)' started by MrFeldman, Jun 14, 2024.
  1. Jun 14, 2024 at 10:26 AM
    MrFeldman
    MrFeldman [OP] New Member
    Mr
    ‘05 Tundra Limited Crew Cab
    Upgraded Stereo
    What particular motor oil are you all running on your 4.7 gen 1?
    I’m always a diy guy, but without an auto lift, the removal & replacing of the underside brush guard seems like a lot of freakin work, I’ve been hitting up a drive thru Mobile Oil shop. My rig currently has 148k on the odometer.
  2. Jun 14, 2024 at 10:30 AM
    CascadeSkyline
    CascadeSkyline New Member
    Forks WA USA
    05 AC Tundra Limited 4x4
    6.5 quarts of Mobil 5w30 then just level slightly as needed from there. I use a long toyota filter. The under carriage is 4 or 5 bolts. 5 if I'm missing one front center. You don't have to lift the truck to change the oil. I never have.
    MrFeldman[QUOTED][OP] and chunk like this.
  3. Jun 14, 2024 at 10:45 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I don't lift the truck and leave the skid plate on and pull the filter from above. Use 2 grocery bags and unscrew the filter into them to catch oil.
    I won't get into oil brands, this thread will be 100 pages long. Most oils these days are good. I run synthetic in mine.
  4. Jun 14, 2024 at 11:18 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    M1 is recommended probably the most here, and makes Yotas oil. However, seen some pretty poor oil analysis of M1 at 3k plus miles. I’ll be giving Pen platinum a try.
    MrFeldman[OP] likes this.
  5. Jun 14, 2024 at 11:23 AM
    I run Pennzoil plat high mileage and the extra large Mobil1 filter. Takes about 7.2 qts to fill me up now. Change it once a year. I average 3-4k miles in a year. About $65 at Walmart for all supplies and have 2.5qts oil leftover.
    MrFeldman[OP] and jerryallday like this.
  6. Jun 14, 2024 at 11:31 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Which oil you ask?...extra virgin guy here!
    It shouldn’t take more than a minute to remove the 5 screws that attach the splash guard and probably closer to 20 seconds with an impact driver. There’s plenty of room under the truck to not have to use ramps or a floor jack.
    MrFeldman[OP] and ATBAV8 like this.
  7. Jun 14, 2024 at 11:32 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Mobile 1, 5w-30, 6.5 quarts with a Toyota filter, and new OEM drain plug gasket every time. I also take the skid plate thingy off too, and do it with all 4 tires down.
    Edit to add: I've been doing it this way for 23 years, it's not that hard, and with the skid plate off you can eyeball the underside with a light and look for potential issues at each oil change.
  8. Jun 14, 2024 at 11:47 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Iv been putting in all 7 quarts of Mobil 1 5w-30 high millage for the last 3 years vs the recommended 6.6 quarts. OEM filter always.
    5 bolts for the splash guard, im lifted 2 inches so no lift or jack needed.
  9. Jun 14, 2024 at 12:30 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Oil change is about as basic a diy as you can get. Skid plate is annoying. It's part of the job. Just has to be done. 90% of the diy on a vehicle will be laying on your back on the ground. That's how it is.
    I've done one oil change since buying my Tundra. I used Mobil 1, because where I live is rural, and I'm regularly in other towns, some big, some small. Pretty decent chance anywhere I find myself will have Mobil 1. Good enough for me.
  10. Jun 14, 2024 at 6:16 PM
    bfunke
    bfunke Tundra Curmudgeon
    Costco or Wallymart 5W30 Full Synthetic (or any brand of same) + OEM filter every 5K miles. Bam - problem solved on Tundras!
  11. Jun 14, 2024 at 6:21 PM
    I do not remove my skid plate. I replace the oil filter from above and slide a cardboard box piece onto the skid plate under the filter to redirect the oil drainage.
    NickB_01TRD and HBTundra like this.
  12. Jun 15, 2024 at 6:47 AM
    MT-Tundra
    Montana
    Hmmm....I know I've seen people talking about different things they've done, but that's the most simple I've heard yet. I have the rubber "wings" on either side of the metal skid plate, but I wonder if I could still rig something. I'll look closer at things.
  13. Jun 15, 2024 at 6:50 AM
    If I were keeping my 2019 forever I would probably swap for a TRD skid plate to have the oil filter trap door. Or mod mine to make one.
  14. Jun 15, 2024 at 6:59 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    You're not?
  15. Jun 15, 2024 at 7:23 AM
    Nope. Keeping the 2000 forever. This truck pulls the camper I don’t really need more. I’ll sell the camper and find a smaller one that better suits our use. Don’t need a mobile apartment anymore.
  16. Jun 15, 2024 at 7:55 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :thumbsup: What type of camper you currently running?
