6112 springs on a 5100's
Discussion in 'Suspension' started by SRLimited, Jun 14, 2024.
  1. Jun 14, 2024 at 9:29 AM
    SRLimited
    SRLimited [OP] New Member
    Mitchell
    2003 Toyota Tundra Limited
    5100s
    Anyone have any input on wether putting 6112 would work on 5100 bottom hats? Mostly concerned with what might happen under load to the bottom hat and if the spring will sit upright. Anyone try anything like this? I have an isolator from the stock strut that would fit in between.PXL_20240614_161809596.jpg PXL_20240614_161742041.jpg PXL_20240614_161909923.jpg PXL_20240614_161929020.jpg
  2. Jun 14, 2024 at 9:41 AM
    RobertD
    Robert
    DFW, Texas
    Paging @memario1214
    What happened to the hardware that came with the 6112's?
  3. Jun 14, 2024 at 9:51 AM
    SRLimited
    Mitchell
    5100s
    and 3.[/QUOTE]
    Purchased these springs independently. All I've seen online to mate these properly online is an adapter on PRG products. Just thinking about if these would work safely or if the spring is going to shift around due to the 5100 bottom mount shape. It also sits on the outer 50% of the mount as you can kind of make out in pictures 1 and 3.
  4. Jun 14, 2024 at 9:51 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    No, the coils aren't suitable as they're a different design.
    The 5100's are made to take the factory style springs.
  5. Jun 14, 2024 at 9:54 AM
    SRLimited
    Mitchell
    5100s
    Yeah, I was expecting a unanimous response like this. I'm just exploring the thought and if anyone had any experience trying to run race coils on 5100s that they might be able to suggest a way to make it work.
  6. Jun 14, 2024 at 9:56 AM
    RobertD
    Robert
    DFW, Texas
    Oh!
    I misunderstood your post. I thought you had 6112 body and coil but were trying to use 5100 bottom hats
  7. Jun 14, 2024 at 9:57 AM
    SRLimited
    Mitchell
    5100s
    All good, first time poster here, go figure.
    RobertD[QUOTED] likes this.
  8. Jun 14, 2024 at 9:58 AM
    RobertD
    Robert
    DFW, Texas
    No worries, its easy to have some info lost since you know what you have and I read what you post with a different mind set.
    We got there in the end :thumbsup:
