Should my Tundra weigh 9000 lbs?
Discussion in 'General Tundra Discussion' started by Marvthehamster, Jun 12, 2024.
  1. Jun 12, 2024 at 12:09 PM
    Marvthehamster
    Marvthehamster [OP] New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    I've given some shit to those who roll heavy in the towing forum before. Time for you guys to return the favor. Anyone got a weight ticket to beat the one I got last weekend at the landscaping yard? Green is empty, red is loaded with 1.19 tons of topsoil :eek2:
    I wouldn't recommend doing this regularly with a 1/2 ton pickup. YMMV.
  2. Jun 12, 2024 at 3:50 PM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Towing at 9000# is different from carrying 9000#
  3. Jun 12, 2024 at 3:59 PM
    Retired...finally
    I used to tow a 2,000 # GVWR HF trailer with my Element. I went to the gravel pit and asked for a "light ton". The gross weight came in a 3660#. I went real slow that 4 miles to get home.
  4. Jun 12, 2024 at 4:09 PM
    AZBoatHauler
    So.Arizona
    Hopefully you didn’t kill the rear axle.
  5. Jun 14, 2024 at 4:48 AM
    Marvthehamster
    Tom
    CO
    2018 CM
    I think the axle is fine. After I shoveled everything out everything seemed to return to normal.
    2mchfun likes this.
  6. Jun 14, 2024 at 6:07 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    No pictures of the squatted truck???
    I'm sure it'll be fine
  7. Jun 14, 2024 at 6:14 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Never done it. Wouldn’t recommend it. But I don’t think the rear axle is the limiting factor to the trucks carrying capacity. @Jowett posted something about the axle’s true capacity being significantly higher than the 4150 lb rating according to the people who build it.
    But you may be looking at bearings sooner than others. (Like @ 300k instead of 800k :D)
  8. Jun 14, 2024 at 9:02 AM
    AZBoatHauler
    So.Arizona
    Rear axle isn’t a full float design so the axle shaft has torque from the load applied to it which can cause them to bend and eat bearings. Not the same as a HD truck design…
