Thoughts on an early oil change?
Discussion in '3rd Gen Tundras (2022+)' started by robcolo, Jun 13, 2024.
  1. Jun 13, 2024 at 10:23 AM
    robcolo
    robcolo [OP] New Member
    2024 SR5 TRD Sort
    2024 Tundra (build 2/2024) not identified in the recall, but thinking some 2024's might be included at some point. With the engine debris issue is there any benefit of a 1000 mile or less oil change or am I already in trouble if debris is present?Maybe 1000-5000-10000 oil changes? My Tundra is currently sitting in the garage at 750 miles until Toyota provides more info on a fix. Driving a gen 1 with 188,000 miles currently.
  2. Jun 13, 2024 at 10:27 AM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    I bought my Tundra 4 weeks ago(build date is after recall and it’s a hybrid) with 3500 miles on it and dealership claimed they changed the oil. I had no reason not to believe them, but when I got to 5000 miles last week and went in for service at my local dealer I asked for an oil change anyway and the tech came out and told me it looked good and he even cut open the filter to make sure no flakes were in it.
    Moral of the story is…. Why not? :thumbsup:
    Hella Krusty likes this.
  3. Jun 13, 2024 at 10:28 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I changed at 1k and 5k before all this panic about recall. Paid for both oil changes at dealer and sent my 5k oil over to blackstone for analysis.
    Will it hurt to change early, only your wallet. Will it help to change oil early, likely not.
    You do you
    Hella Krusty and bulldog93 like this.
  4. Jun 13, 2024 at 10:30 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    Do it! I changed mine at 1k, then again at 5k, and now do them at every 5k intervals. I've done this to all prior new vehicles and never had issues. Once upon a time when brands/dealerships were somewhat decent, they even suggested this in the manual.
  5. Jun 13, 2024 at 10:34 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Just do it.
    OHwendTrd likes this.
  6. Jun 13, 2024 at 10:35 AM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    Yeah, there's no downfall to it except maybe money. I generally dump the initial oil in most every new car between 500 and 1k miles, including my 24 Tundra. I even did the rear diff before 1k as well.
  7. Jun 13, 2024 at 10:44 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Dead horse topic
  8. Jun 13, 2024 at 10:44 AM
    paulphilly
    paulphilly New Member
    Paul
    Upstate NY
    '24 TRD Pro
    I would change it every 500 miles if I could. I did change at 800 miles, and then last week at 2,360 miles. I will let you form your own opinion, but as many have said, this doesn’t look good. My TRD Pro built 3/24:
  9. Jun 13, 2024 at 11:02 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    if you are truly worried about debris, pick up a filter cutting tool to open the filter and look in the pleats. You will immediately know if major problem(s) on the horizon.
    3d_pilot likes this.
  10. Jun 13, 2024 at 11:13 AM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    I always like to do an early oil change on a new engine, helps get the assembly lubes that are used when the engine is built out of the system. Also, a lot of the initial wear that occurs on an engine during break-in happens very early, so you are going to get that stuff out of the engine as well. Some debris in the oil is normal, that is why engines use oil and filters.
    GoHuskers and 3d_pilot like this.
  11. Jun 13, 2024 at 12:34 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Can't hurt to change it. I'd do it if it were my truck and add a Fumoto Valve in the process. The Fumoto will make changes mess free and simple. I added mine at 1500 miles when I dumped the oem oil. Changed the oil again at 5K. Nothing found in either oil change that looked unusual - 5/23 build. Knock on wood.
  12. Jun 13, 2024 at 1:09 PM
    brtnstrns
    brtnstrns New Member
    2024 Tundra Platinum HV; 2022 Polestar 2
    doubt
  13. Jun 13, 2024 at 1:51 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    Lots of opinions on this. For what it’s worth I dumped oil @1000k then the plan is every 5k or 6 months (km) whichever comes first.
    I live in Canada (brrrr) and I often drive short distances so I fall into “severe service”
    regardless of opinions, and data (blackstone) and wether or not it actually matters, I change oil to these timelines.
    I can afford it and it makes me feel better, rightly or wrongly.
  14. Jun 13, 2024 at 2:44 PM
    Steelhant
    Steelhant New Member
    TRD- Pro
    none...new
    I understand with the engine breaking in I'm sure there will be small pieces of debris, also if they left debris in the engine the oil filter should filter it ... shouldn't be anything going through ?? I have 2023 TRD PRO and love the truck, I did 1000 and every 5000 thousand oil change can never hurt. I think bad bearing parts, hope for the best .
    ArcticFox likes this.
  15. Jun 13, 2024 at 3:34 PM
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    2022 Tundra SR5 , blueprint
    Tonneau cover
    I have been changing mine every 5K. I had a cam failure at 19K , but since the repair no issues at all. Now at 41K
    The shavings you see after an oil change is not telling the whole story. Like it has been said earlier , open your filter. That’s where it’s all at .
    The ones that will do the most damage are in your filter and they were in the bearings doing damage before they were filtered out.
    I’m having difficulty believing this is strictly a cleaning issue.
    These type of issues can be relatively easy to resolve in the production process. The design problems are not.
    My camshaft was frozen in the seat. it went from 0 to failure . Tried to start in the morning and it wouldn’t move.
    They had to replace the cover as well due to damage. So I’m thinking its more then shavings.
    We will find out in time.
    Toyota, if you are listening. If you let us down on the recall you will loose us all in the truck market. Problems do happen but how you handle them tells the story of your reputation going forward.
    If I wanted a full size truck there was no where else to go.
    Honda was a very close 2nd. For me. I test drove every new full size truck out there. They ALL have major issues.
    Tundrastruck91 likes this.
  16. Jun 13, 2024 at 5:58 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I’ve done an early change on every new car/truck/bike I’ve owned. It’s cheap insurance and good to flush out any break-in debris. The first oil itself is subjected to higher temps in a new motor from increased friction. No internal mechanical failures in over 2 dozen vehicles and 44 yrs.
    JLS in WA and Tundrastruck91 like this.
  17. Jun 13, 2024 at 6:42 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    I did my first oil change at 5K with major protest from the service writer. I wonder if that will help with the recent engine manufacturing recall/TSB? Getting the debris out sooner can’t hurt can it?
    Sisu87TRDOR likes this.
  18. Jun 14, 2024 at 12:13 AM
    PNW Tundra Mike
    Back in So Cal
    Doubt it. Anything sucked up by the pump goes straight into the filter. Many have found the “glitter” when they drain the filter.
  19. Jun 14, 2024 at 4:23 AM
    Voto
    Voto New Member
    2022 tundra SR5 double cab rwd
    change your oil now than every 3000 miles after.
  20. Jun 14, 2024 at 5:35 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    +1 ... big investment and why not?
    raylo[QUOTED] likes this.
  21. Jun 14, 2024 at 6:03 AM
    Eurodriver
    Eurodriver New Member
    I changed the oil in my 2022 every 100 miles. You can never be too safe. It's cheap insurance. It's easy since it's a pickup and you don't have to put it on jackstands. It helps with fuel mileage. It allows you to inspect the rest of your vehicle.
    Did I hit all the touchpoints?
    Coal Dragger and brtnstrns like this.
  22. Jun 14, 2024 at 6:30 AM
    paulphilly
    Paul
    Upstate NY
    '24 TRD Pro
    I would never drive my 3rd gen that far without changing it earlier. Hence, why I do 20 mile oil changes. It's expensive, and I have to carefully plan routes/trips to allow for immediate pull over and oil change. It's especially a pain when taking vacation 600 miles away :(.
    Retired...finally likes this.
  23. Jun 14, 2024 at 8:10 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I posted in a similar thread that I changed mine at 5000 to be in the safe side. That post was deleted, so I hope this doesn’t get deleted as well.
  24. Jun 14, 2024 at 8:29 AM
    Hank Hill
    Hank Hill New Member
    Here is an interesting and scientific video on oil, very informative if youve got 30 min to burn.
    Topic of discussion is diesels, but also includes some insight into gasoline engines.
  25. Jun 14, 2024 at 3:59 PM
    11748
    11748 New Member
    2023 Tundra 1794 (build date1/23)
    I as well have changed my oil at 1K, 5K, and 8K given the recent concerns.
    If the engine does go, hopefully a new complete engine from Toyota will make it right before the warranty expires.
    "What this Toyota needs is an inline 6 diesel enema with a stick on the floor!"
  26. Jun 14, 2024 at 4:18 PM
    AZBoatHauler
    So.Arizona
    Recent oil reports show they are using super high moly oil from the factory - I’d be hesitant to change it before a few thousand miles as it breaks in. I believe this is a result of the failures seen on the early 3rd gens.
  27. Jun 14, 2024 at 4:30 PM
    Retired...finally
    I think the molybdenum disulfide is used as an assembly lubricant and plays little if any part in the break in process. You remember the days when new or rebuilt engines required non detergent oils for break in?
    Lee.M and PNW Tundra Mike like this.
  28. Jun 14, 2024 at 4:34 PM
    AZBoatHauler
    So.Arizona
    We just pour in a shit ton of zinc.
    Mr Badwrench likes this.
  29. Jun 14, 2024 at 4:40 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Agree //imo 5k oci is perfect, even though Toyota recommends 10k (in un-harsh conditions)
    AZBoatHauler[QUOTED] likes this.
  30. Jun 14, 2024 at 5:06 PM
    Steelhant
    TRD- Pro
    none...new
    You get 2 free oil changes, but my dealer stated if I change before 10,000 I would have to pay....whats the difference if you use them up early !
    I did it at 5000 and dealer at 10,000..just did it again at 15,000 before the recall, my hybrid not in it just want to check... I may want to look at the filter first or do the oil analyst before the dealer does the 20,000.
