2021 Toyota tundra pro towing
Discussion in 'Towing & Hauling' started by Tundraluv=2, Jun 12, 2024.
  1. Jun 12, 2024 at 5:23 PM
    Tundraluv=2
    Tundraluv=2 [OP] New Member
    Darlene
    2021 lunar rock tundra pro
    What is the top wieght of a RV can the 2021 Toyota tundra pro, pull?
  2. Jun 12, 2024 at 6:03 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Anything under 165,000lbs should be good to go.
  3. Jun 12, 2024 at 6:27 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    It goes down with options. If you have bedliner, a sunroof, steps, etc, it’s going to lower your tow rating. You’re probably at 8800-9000 lb would be my guess.
    My truck is rated for 9200 lb. I have 1270 lb of payload on the door jamb. So if I’m in the truck at 180 lb, I can handle 1090 lb of tongue weight according to the door jamb.
    There should be a code at the bottom of the door jamb sticker that has your axle ratings. It’ll look something like USKSKA-something.
    Find that code, and post it here. Along with your “occupants and cargo shall not exceed ____” number on the other sticker.
    That’ll tell you real quick.
  4. Jun 12, 2024 at 7:34 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Check your owners manual or door stickers...
  5. Jun 12, 2024 at 10:57 PM
    Tundraluv=2
    Darlene
    Thank you
  6. Jun 13, 2024 at 3:45 AM
    Retired...finally
    Top weight safely? Oh, around 7,000 pounds...Maybe...If it's a travel trailer under 26 feet. Now, a flatbed trailer full of rebar with good brakes, you can get closer to the max listed number.
    in this picture my truck is hovering right at 7200# with the trailer about 200# short of it's 6080 GVWR. For me it's a well balanced rig. Enough room but not too much weight or length. It's a pleasure trip.
  7. Jun 13, 2024 at 6:21 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    First of all, fist bump for owning a 2021 Lunar Rock TRD Pro. Special piece of Toyota history right there.
    Agree w/ @Retired...finally, right around 7000lb and 26' long is the limit for me on an RV.
    I pull this camper around and personally would not want to go any larger: https://forestriverinc.com/rvs/print/rockwood/2507S/6067 . Weight is one thing, but the height/length/width makes it not fun to tow when it's windy (which is all the time in the Midwest).
    It's very important that you also have a properly set up weight distribution hitch.
    Tundraluv=2[OP] likes this.
  8. Jun 13, 2024 at 6:24 AM
    How you liking the vintage? Wife digs the style and we are looking to downsize from our 29’ Ultralite (7200# unloaded, probs 8200# kitted to camp.)
  9. Jun 13, 2024 at 7:47 AM
    Retired...finally
    you gotta understand these are designed to be used about 2 weeks a year. We live in ours more than we live in our home in Ohio and it's holding up pretty good. I'm staying on top of the little things that break on every trailer out of Elkhart area. It does have a one piece fiberglass laminated roof and adzel sides so you aren't going to see it going down the highway with a big bubble on top like the flexible rubber type roofs.
    The real big positive is that at the time of purchase, Gulfstream was still a privately, family owned company so at least the design was better than most.
    So, for us to live in that thing for 7 months+ says alot. We got the 23 RSS model. I'd rather have an Airstream but this only cost $26K plus tax new in Aug 21.
    KNABORES[QUOTED] likes this.
  10. Jun 13, 2024 at 7:49 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Remember that the Pro is leveled so you're going to be back here in a few months complaining about "sag" after you hitch your trailer up.
  11. Jun 13, 2024 at 7:49 AM
    I completely understand. We used ours as a transition residence between houses and during a remodel twice. About 7-8 months total. Now we just go the lake for the weekend. It’s basically an apartment on wheels and was perfect at the time but overkill now.
  12. Jun 14, 2024 at 8:54 AM
    Retired...finally
    @Tundraluv=2 I hope we answered your questions. Whatever you do, don't ask about transmission coolers.:deadhorse::crapstorm:
    yakeng and Cpl_Punishment like this.
  13. Jun 16, 2024 at 8:03 PM
    yakeng
    yakeng 3URFE Apologist
    Don’t worry, I got you covered.
    Hey OP, you need to install a transmission cooler.
