First Gen Grille Options
Discussion in '1st Gen Tundras (2000-2006)' started by daveeasa, Sep 16, 2021.
  1. May 25, 2024 at 7:22 AM
    #241
    Here's a quick and dirty photoshop. Looking at it like this, I'm not sure I'd trust the outer edge to hold paint in a rock chip event. But I do like the look for the most part.
  2. May 25, 2024 at 7:36 AM
    #242
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Yeah that looks good
  3. May 26, 2024 at 9:34 PM
    #243
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    There was always a little flex even with the OEM. But this one definitely has more. However, once I realized that support bar near the bottom needed to be moved over to the new grill that helped a lot
    I do have to fabricate another mount for the hood latch. I thought it was difficult to open because that grill flexed until I stiffened it up with that support bar. Then I noticed the issue was they got the geometry all wrong.
    So I've got to Make a small steel plate to attach the latch that then attaches to the grill mount so I can move the latch over about an inch. Easy fix
    G_unit3000 and shifty`[QUOTED] like this.
  4. Jun 11, 2024 at 9:37 PM
    #244
    qdjohn
    qdjohn New Member
    2003 AC SR5 V8
    Is this still up for grabs by the way?
  5. Jun 12, 2024 at 8:34 AM
    #245
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
  6. Jun 12, 2024 at 3:24 PM
    #246
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    A couple of more colormatched examples I found on the zuckerbooks. I really like both of these.
  7. Jun 23, 2024 at 11:03 AM
    #247
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  8. Feb 21, 2025 at 4:30 AM
    #248
  9. Feb 21, 2025 at 7:10 AM
    #249
    MT-Tundra
    Montana
    These trucks really do look great with trimmed front & rear fenders for aftermarket bumpers. Don't think I'll be making those mods to my truck (at least anytime soon), but they do look great.
  10. Feb 21, 2025 at 7:19 AM
    #250
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    :smack::rofl:
    shifty`[QUOTED] likes this.
  11. Feb 22, 2025 at 8:57 PM
    #251
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  12. Feb 23, 2025 at 2:03 PM
    #252
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    how did you lower the back? 2" shackles?
  13. Feb 23, 2025 at 5:12 PM
    #253
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    shifty` and FrenchToasty like this.
  14. Feb 24, 2025 at 11:45 AM
    #254
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Not mine, but a double cab for sale locally.
    PNW15, G_unit3000 and KNABORES like this.
