Heli coil fix
Discussion in '1st Gen Tundras (2000-2006)' started by USERidiculousNAME, Jun 12, 2024.
  1. Jun 12, 2024 at 5:05 AM
    USERidiculousNAME
    USERidiculousNAME [OP] ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    If a heli coils ID threads were to big could you flux core weld it full and re- drill/tap it correctly? This would be for top right bolt (inside view) on fan pulley bracket 4.7 V8
  2. Jun 12, 2024 at 5:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've welded holes in steel, and then redrilled and tapped before, but I've never done it on cast or engine parts
    Post pics
  3. Jun 12, 2024 at 7:45 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    So you'd be welding in a hole on the block so you could then re-drill and tap the hole to mount your fan pulley bracket? I'd honestly try drilling the hole in the bracket out to a larger size first and finding a bolt that matched the threads of the helicoil that you put in.
    Otherwise, you'd be welding the hole shut, hoping you got decent penetration (assuming you're using a 125A flux core welder), grinding that flat, drilling through your weld (which will be harder than normal steel), then blind tapping the hole. I'd also be very concerned about drilling your hole perfectly straight, which will be hard to do while in the engine bay.
  4. Jun 12, 2024 at 10:30 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    Did you check Timeserts to see if there is one that will accommodate a larger hole with smaller internal threads? (grasping at straws here...)
    https://www.timesert.com/
    whodatschrome likes this.
  5. Jun 12, 2024 at 11:23 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Yes they exist. It’s called a Big Sert.
    Rich L. and Teutonics[QUOTED] like this.
  6. Jun 12, 2024 at 11:26 AM
    whodatschrome
    lots of dents
    So is the aluminum bracket pulley bracket or the cast iron engine block that has a stripped hole?
  7. Jun 12, 2024 at 11:36 AM
    Rich L.
    Rich L. this too shall pass
    Pacific NW
    '06 SR5 AC V8 4WD
    I used a Big Sert to repair a damaged helicoil in a Porsche 944 rear control arm, cast aluminum. Worked great.
    Before:
    After:
  8. Jun 12, 2024 at 11:38 AM
    kentuckyMarksman
    Good question! He's not going to flux core weld to aluminum, not going to happen (and I would just suggest replacing the bracket if it was just the bracket). He could possibly do it if he had an aluminum spool gun and he wasn't dealing with a 7000 series aluminum.
  9. Jun 12, 2024 at 1:10 PM
    whodatschrome
    lots of dents
    I totally agree, but i’m not sure if the OP is referring to some sort of “as seen on TV” aluminum welding kit, or some youtube videos of a gang of indians welding up cast aluminum pistons in a clapped out excavator!
    I’ve used a spool gun many times to fill in stripped out holes in various aluminum and parts. I’ve also used many different Timeserts in aluminum as well. If it is the engine block, then yeah, exactly what you said above about the trials and tribulations the OP will have if he tried to weld up the stripped hole in the block!
