Another diff/transfer fluid question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Uncle914, Jun 11, 2024.
  1. Jun 11, 2024 at 3:34 PM
    Uncle914
    Uncle914 [OP] New Member
    Bob
    Frederick, MD and Kent Island, MD
    2020 SR5 DC TRD Offroad
    I am getting ready to do my 30K service on my 2020 SR5 TRD. Dealer said gear oil is backordered so I started doing some research. I am looking to use the Ravenol Diff/Transfer kit, but see there are 2 different products, DGL 75W-85 and MTF-FE 75W-85 GL5 (one green and one gold). Question, is one preferable over the other? Both Synthetic. Thanks!
  2. Jun 11, 2024 at 3:49 PM
    AZBoatHauler
    So.Arizona
    No reason to do your transfer case at 30k in my opinion. Certainly not called for in the Toyota maintenance schedule.
    For the diffs I used Amsoil Severe Gear but any quality 75-90 will be fine.
    WILLINH and FrenchToasty like this.
  3. Jun 11, 2024 at 4:34 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I’ve checked with 3 dealers and they all use 75-90 in rear, differential. They only use 75 or 75-85 if it is a warranty claim.
  4. Jun 11, 2024 at 5:01 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    The green one is a more affordable option. It’s like $20 less than the gold ravenol for the kit. I just ordered my kit yesterday and spent the extra $20 for ravenol.
  5. Jun 11, 2024 at 8:36 PM
    blenton
    blenton New Member
    I'm going to assume the Ravenol MTF-FE was either a typo and you meant MTF-1, as I'm not seeing MTF-FE on Ravenol's website, or you were looking at Eurol MTF-FE. The MTF-1 is not GL5 rated whereas the MTF-FE and DGL 75W-85 are. A GL5 rated gear oil comes with more extreme pressure additives than a GL4 or non-GL5 rated oil. GL5's are typically recommended for hypoid gears like in axles/differentials. Blauparts sells maintenance kits for tundras, 4runners, etc; they appear to use the MTF-FE GL5 fluid for the tundra diffs, and an MTF 75w (not listed as GL5) for the transferase. For the Sequoia, they use the same MTF-FE GL5 for the diffs, but a Fultrasyn 75w90 (again, not GL5).
    Comparing the Eurol MTF-FE 75w85 GL5 and DGL 75w85 GL5, the kinematic viscosity is lower on the DGL, meaning the DGL is actually thinner, which is surprising to me since the -FE is "fuel efficient" designed for that fraction of a percent of fuel economy.
    Ravenol DGL specs
    Eurol MTF-FE specs
