High pitch noise coming from drivers footwell
Discussion in '1st Gen Tundras (2000-2006)' started by zag, Jun 10, 2024.
  1. Jun 10, 2024 at 12:02 PM
    zag
    zag [OP] New Member
    2005 Toyota Tundra Access Cab Limited V8
    There’s a very irritating high pitched noise coming from near my feet while I’m driving. It started happening a few weeks after installing a new radio head unit (Kenwood Excelon DMX809S with GPS, Carplay, backup cam, mic and amp bypass). That’s the only thing I can think of that might have caused it. Although, the sound did not start until driving it with the new radio for a few weeks.
    It goes away after I shut the car off or when I press the brake or accelerator past about half way. Maybe something electrical? Anyone have any ideas on how to fix this or what the cause could be?
  2. Jun 10, 2024 at 12:16 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Can you provide a video to record the noise?
  3. Jun 10, 2024 at 1:18 PM
    Questions for you, answer honestly please.
    Did you cut any factory harnesses to install the radio?
    Is the pitch of the whine consistent, or does the whine increase in pitch as you accelerate? (ground loop/"alternator whine")
    Does the whine disappear if you turn the head unit OFF?
    If you put your ear up to the driver's side lower door speaker, is it clearly coming from there, or maybe from the tweeter next to the door handle?
    When you connected the wires, what method did you use to attach them together? Twist and tape? Solder and shrink wrap? Wire nuts? Butt splices? Termination (closed-end) crimps?
    Did you need to ground anything extra? (parking brake bypass, for example, steering wheel control adapter, etc.)
    Bad Jackson likes this.
  4. Jun 11, 2024 at 10:27 AM
    zag
    zag [OP] New Member
    Here are my honest answers to your questions:
    No I did not cut any harnesses, I got the prewired harness from Crutchfield that plugs directly into truck. All the other connections plugged in directly or were spliced into existing wires.
    The pitch and volume of the whine are not consistent. Some days it is louder than others. The volume and pitch decrease the more I press on the brake or accelerator and is the loudest when neither pedal is pressed. Pressing the parking brake pedal seems to have no affect on the whine.
    The whine continues regardless of if the head unit is off or on.
    I can not tell exactly where the whine is coming from but it seems to be from right above the pedals, not from any of the speakers or tweeters.
    I used the Crutchfield provided harness connecters for everything except splicing the backup camera into the reverse light & splicing the parking brake wire into the parking brake switch. For the splices I used these quick splice lock snap connectors https://www.amazon.com/dp/B09539VNBK?ref=ppx_pop_mob_ap_share then I covered the connections with electrical tape.
    The only extra item that needed to be grounded was the backup camera. For this I spliced into the ground wire for the reverse light. Other than that, I just did all the splicing and connecting of provided harnesses explained above.
    Video of the noise here: https://youtu.be/rSaMOhf8eeI?si=RAZOY2mCKNagvKwU
  5. Jun 11, 2024 at 11:07 AM
    ATBAV8
    Tempe, AZ
    That sounds to me like a possible leak on the brake booster. I think that's where I would start.
    Jack McCarthy and bfunke like this.
  6. Jun 11, 2024 at 11:58 AM
    Man that is a weird one. I agree, the leak seems like it's tied to breaking. And I don't think it's your firewall steering shaft seal, although that's potentially toast right now too, and allowing excess noise into the cabin.
  7. Jun 11, 2024 at 12:21 PM
    bfunke
    bfunke Tundra Curmudgeon
    Check brake booster and vacuum lines to it for leak.
    shifty` and zag[OP] like this.
  8. Jun 11, 2024 at 12:29 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Man I messed up the first stereo install I ever did in pre-Internet days and had this exciting effect. Was going to be my first guess too until the video.
  9. Jul 31, 2024 at 3:45 PM
    zag
    zag [OP] New Member
    It ended up being the brake booster and had nothing to do with the head unit or other components I installed. Correlation not causation!
    Replaced the brake booster and the noise is gone. They only had an after market one available but it seems to be working fine for now.
  10. Jul 31, 2024 at 4:41 PM
    What did you go with for aftermarket make?
    shifty` likes this.
  11. Jul 31, 2024 at 4:54 PM
    I'm glad you asked this, after seeing the last several people who had probs with aftermarket boosters. Don't leave us hanging @zag :rofl:
