  1. Jun 11, 2024 at 7:17 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Lmfao. Oh I know how that goes. There's a few areas of a few creeks and rivers back home where the NYDWC makes you cut your barbs, catch and release only. But go up or down stream a half mile or mile and your gtg .... Government has no clue what it's doing.
    BroHon likes this.
  2. Jun 11, 2024 at 8:29 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Anyone got any recommendations on brake line kits/upgrades? I need to replace those hard lines and might as well do more than just those...
  3. Jun 11, 2024 at 8:42 AM
    VR6T
    I got the steel braided one off of rock auto. Only have the rear one installed at the moment, but there is a noticable difference in my pedal. Much firmer
  4. Jun 11, 2024 at 8:47 AM
    metalpete
    ID
    Of course, my boys at RA!
  5. Jun 11, 2024 at 9:12 AM
    That's what me and Jake put in the other day. Solid kit. Do you need the hardline part numbers?
    I'll go ahead and put em up incase you do.
  6. Jun 11, 2024 at 9:42 AM
    I passed a First Gen broke down on the side of I40 today on my way to Nashville. It wasn't a LBJ failure either. The poor truck looked terrible. Gonna guess timing belt.
  7. Jun 11, 2024 at 9:43 AM
    I’ll go with fuel filter
  8. Jun 11, 2024 at 9:51 AM
    :D @bmf4069 can fix it...
  9. Jun 11, 2024 at 9:59 AM
    metalpete
    ID
    Thanks, brother.
    You talking about the $73 BH00127 kit? Cuz imma bouta get it.
    bmf4069[QUOTED] likes this.
  10. Jun 11, 2024 at 10:01 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Not sure if anybody else uses these but these are by far the best wipes I've used to get rid of that grease/dead skin that's on highly touched areas of the truck
    here some before and after. It requires zero elbow grease. A few wipes and everything just comes off. And it doesn't leave a slick film. It dries proper.
    Voss, The Black Mamba, abcinv and 6 others like this.
  11. Jun 11, 2024 at 10:07 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Got a dyno appointment to measure the base 93 octane VF Tune. Won't know the true power numbers until July 22nd. Full write up with results after.
    So far it feels quicker. No full throttle runs yet. Updated shift map hangs onto gears a little longer. I noticed under normal cruise it will shift between 2,000-3,000 RPM depending on throttle position.
    Noticed in the program there is a more aggressive map if O/D is turned off. Looks like it takes the TCU input of O/D button to change the map.
    Haven't tried it yet but I may go for a more spirited drive soon.
  12. Jun 11, 2024 at 10:16 AM
    That's the one!
  13. Jun 11, 2024 at 10:18 AM
  14. Jun 11, 2024 at 11:13 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Quick trip with Dale before I pull the camper and dive into truck project's.
    Left Amarillo in a thunderstorm and flash flooding, with only light rain falling when I pulled into Bugbee Canyon on the NW end of Lake Meredith. The skies cleared for a great sunset to grill a steak under and the gamble about the weather paid off as we had the entire cove to ourselves.
    10/10 Experience
  15. Jun 11, 2024 at 11:54 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Might have something to do with us bleeding the shit out of it and different drums on the rear too
    VR6T[QUOTED] likes this.
  16. Jun 11, 2024 at 12:04 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Interesting about the O/D off. I've only driven with it off on my non tuned 03. Now I want to jump my tuned 06's battery and try this out lol.
    (Yes @Mr.bee it needs another jump...and the front diff leak.)
  17. Jun 11, 2024 at 1:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Get a maintainer for it.
    455h0le_dachshund likes this.
  18. Jun 11, 2024 at 1:31 PM
    VR6T
    No oil on my shoes so. That could make a big difference as well lol. But the pedal is not as firm as the night we did it, but vastly better than it was before.
  19. Jun 11, 2024 at 2:18 PM
    Rib a little? Maybe. The only time I'm going to point and laugh is if you ignore someone else's sound advice, or proceed with work when you aren't confident about what you're doing. If the instructions are there, I'll at least skim 'em to look for any gotchas/differences.
    I've learned so many little tricks and shit over the years. I think my brain exploded the first time I saw someone swap out disc brake pads without removing the calipers. I've had plenty of older vehicles where you couldn't do that, but ... stupid shit like that.
  20. Jun 11, 2024 at 4:10 PM
    beemerphile
    beemerphile New Member
    Lee
    2006 SR5 Access Cab
    box stock
    Today was suspension day: LBJ replacement; new Bilstein 4600 shocks; and 2" drop shackles.
    I'm liking the stance and the ride and handling are improved.
  21. Jun 11, 2024 at 4:20 PM
    beemerphile
    Lee
    2006 SR5 Access Cab
    box stock
    This is where I started...
    Voss, oscardog86 and BroHon like this.
  22. Jun 11, 2024 at 5:16 PM
    FishNinja
    Lee
    06DC2wd
    Siiiiickkkk
  23. Jun 11, 2024 at 6:31 PM
    Hit a couple more hikes with the oldest kiddo. This time hiked the 'hooch starting in-town and worked our way OTP.
  24. Jun 11, 2024 at 6:37 PM
    Then hit Stone Mountain for a short stint on the Muscogee, and bike the loop.
  25. Jun 11, 2024 at 7:27 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Whats going on here? Do you have some frame bentage going on or do my eyes deceive me? The bed/cab gap is tighter at the bottom than at the top and it looks like your bed is sagging at the rear. Maybe its just the angle of the pic or sumpin. Carry on. Truck looks good mang.
  26. Jun 11, 2024 at 8:23 PM
    beemerphile
    Lee
    2006 SR5 Access Cab
    box stock
    No, unfortunately your eyes are spot on. The truck has had two rear-enders in its prior life. The one that caused the frame tweak was severe enough that the bed was replaced. I plan to get it on a frame rig to see what can be done. It is about 1" low right rear. I wanted to put a cap on it but the spreading panel gap would be huge at the top of a cap. But otherwise, the truck is A1 and I bought it knowing this issue. The frame is clean as a new penny (0.0 rust) and the truck only has 105K miles. It steers and tracks perfectly.
  27. Jun 11, 2024 at 8:24 PM
    CascadeSkyline
    CascadeSkyline New Member
    Forks WA USA
    05 AC Tundra Limited 4x4
    More like what has my first gen tundra done to me :rain:
  28. Jun 11, 2024 at 8:26 PM
    artsr2002
    'Yonder
    Get some fat chicks to jump up n down on the front of the bed at the cab and see if she'll straighten out. :D
    Just a couple at a time though, don't wanna bend the frame the other way. :D
  29. Jun 11, 2024 at 8:30 PM
    beemerphile
    Lee
    2006 SR5 Access Cab
    box stock
    I'm fortunately real low on fat chicks. I think it will be a simple tweak back. There is no crease or obvious damage point in the frame. I tried unbolting the bed to see if I could simply shim it back in line, but then the rear bumper is out. The bumper has some light damage as well and ought to be replaced.
    shifty` and oscardog86 like this.
  30. Jun 12, 2024 at 1:18 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    July 22nd, why so far out?
