Good rack for 05 DC
Discussion in '1st Gen Tundras (2000-2006)' started by mike's limited, Jun 10, 2024.
  1. Jun 10, 2024 at 7:58 PM
    mike's limited
    mike's limited [OP] New Member
    05' Limited DC 4x4
    Stock
    I'm looking to purchase a new rack and pinion for my 05' DC 4x4. Just looking for suggestions for a high quality rack. I live in Milwaukee Area.
    My mechanic has put in back to back POS remanufactured racks and I'm just gonna do it myself and get it done right.
    Thanks in advance!
  2. Jun 10, 2024 at 8:06 PM
    Are you talking about a ring and pinion?
  3. Jun 10, 2024 at 8:22 PM
    Pretty sure he’s talking steering rack.
    BroHon and ColoradoTJ like this.
  4. Jun 10, 2024 at 9:22 PM
    That could be it too.
  5. Jun 11, 2024 at 4:35 AM
    Most of them are garbage, especially store brand parts, but then again almost all store brand parts are garbage these days, only intended to last 2-4 years if you manage to get something that isn’t already DOA, which happens far too much!!
    It’s why a lot of us drop the $$$ to buy OEM, it lasted how many years now? The genuine OEM replacement will do the same, if you buy from a reputable source (counterfeits are rampant on scAmazon and fleaBay these days) . Buy once, cry once, at least you’ll won’t be replacing it every 2-5 years, I reckon if you add up the racks you’ve bought so far it’d be roughly the cost of one OEM rack….
    We track aftermarket wins/fails on this forum. So far, the only rack I recall a couple of people had success with is Detroit Axle.
  6. Jun 11, 2024 at 7:03 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    +1. I'm happy with my Detroit Axle rack.
    Weagle likes this.
  7. Jun 11, 2024 at 7:06 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    So far, this is the only aftermarket option, but take that with a grain of salt since I can only recall 2 members stating it has held up.
  8. Jun 11, 2024 at 7:25 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I did the Detroit axle new rack for $200 with a 10 year warranty. So far, extremely pleased. Steering is tight again.
    I know some went with the rebuilt one that has a lifetime warranty when you return your core
    I opted for the new one to be sure it had new gears inside and not just new seals
  9. Jun 11, 2024 at 8:22 AM
    +3 on the Detroit axle. I have one as well. We put it in 4/22 and it's survived 2 heavyish offroading adventures.
