What is this connector?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TacomaTRD4x402, Jun 1, 2024.
  1. Jun 1, 2024 at 6:59 AM
    TacomaTRD4x402
    TacomaTRD4x402 [OP] New Member
    Southern California
    Morning all,
    Just got back from a road trip the other day and during it my tpms light came on. I've already attempted resetting it with the reset button and drove it around town for a bit and it remains on(maybe I'm just being impatient).
    I thought that maybe when I did a recent dash disassembly that maybe the reset button got disconnected so I thought I'd get in there and check. The reset button looks like it's connected just fine but I found this loose connector.
    Anything I need to concern myself about with it being disconnected? Is it for the push start ignition equipped tundras?
  2. Jun 1, 2024 at 7:18 AM
    TacomaTRD4x402
    Southern California
    And any tips on getting that dang top plastic clip to line up on this trim piece? My OCD kicks in a little with this.
    Update: Got it! Didn't think to remove the clips from the truck. D'oh!:facepalm:
  3. Jun 2, 2024 at 5:48 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    The connector behind the lower dash could be the OEM trailer brake controller wiring or another option your trim level didn't come with...looks to be trailer controller to me...
    TacomaTRD4x402[OP] likes this.
  4. Jun 10, 2024 at 10:06 PM
    Nova1967
    Nova1967 New Member
    Maryland
    2021 tundra crew max, 1794, Smoked Mesquite
    Rear Sway bar, TRD dual exhaust, storage unit under rear seat, cargo mate, 10 spoke aftermarket 21" rims (Lexus), weather tech mates, Morimoto headlights, HR hood bar light, Chrome deleted: bulge, grille surround, valance, bumper end caps, mirrors. Replaced all parts with smoked mesquite, and L.E.D bright interior lights.
    Reconnect the wire and your TMS light should go off. The button switch is located just above your right knee under the dash to reset the TPMS.
  5. Jun 10, 2024 at 10:11 PM
    TacomaTRD4x402
    Southern California
    Update: After I bit of city driving I started to hear a clanking sound. Put the TPMS light and clanking sound together to find that one of the sensors broke off inside the tire. I already got it fixed just this past Friday. The connector however still remains unplugged. It does however have a little blank spot for it to sniggly sit in(you can see it in the picture. I'm thinking what @HulkSmurf14 said may be correct, perhaps a feature my truck didn't come with :monocle:
    HulkSmurf14 likes this.
  6. Jun 10, 2024 at 10:12 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Chances are your clips came off and they are stuck in the truck body.
    Pull that piece off and you should have 2 clips on it.
    They have a funky angle to them.
    Amazon.com: OAUTOO 25pcs Cowl Trim Retainer Clip for Toyota 90467-09212 : Automotive
    If they are stuck in the truck body pry them out with one of these.
    Amazon.com: EldHus 5 Pcs Car Trim Removal Tool Kit Upholstery Tools, Auto Clip Removal Pry Tool for Door Dash Dashboard Panel Fastener Remover, Push Pin Puller Body Repair Tools, Blue : Automotive
    Then replace them in the panel and it should go all the way in.:thumbsup:
  7. Jun 10, 2024 at 10:15 PM
    TacomaTRD4x402
    Southern California
    Thanks! That was bugging the heck out of me for so long. Couldn't get that panel to seat right so it was loose. I still need to fix the pass side.
    1lowlife[QUOTED] likes this.
