OEM Air Filter Size Difference
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigfoot17, Jun 10, 2024.
  1. Jun 10, 2024 at 4:09 PM
    bigfoot17
    bigfoot17 [OP] New Member
    2018 Crewmax TRD Off Road
    I just purchased an OEM air and cabin filter from my local Toyota dealership. I gave the parts guy my VIN number for my 2018 tundra SR5 to make life easier. The filter I received (17801-YZZ15) was about half the of the filter I took out (17801-OP100). Did they change the part number and size of the filters?
    The filter does fit so I guess I’m ok for now.
  2. Jun 10, 2024 at 4:38 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    I had same issue. I'm not positive about the part numbers. But the new filter will fit but is about half as thick. I'm good if it's the official new part. I will be watching to make sure I'm good. It was almost 10 bucks cheaper so I'm happy with that.
  3. Jun 10, 2024 at 4:41 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
  4. Jun 10, 2024 at 4:47 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    trainracer, bulldog93 and WILLINH like this.
  5. Jun 10, 2024 at 5:35 PM
    Vizsla
    Vizsla pretend2send
    I’ve tested a bunch of different air filters under extreme conditions, Wix did not do well, probably the worst. Few others did also, same results. OEM Toyota filter performed noticeably better than anything else.
  6. Jun 10, 2024 at 6:42 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I would buy OP100 if I can.
    Out of engineering curiosity: what did you do for your test and what did you see? Also this filter model exactly? Filtering media didn't look bad at all in it. I saw bad air filters, yes.
  7. Jun 11, 2024 at 5:35 PM
    737fixer
    737fixer New Member
    Anytime you receive a part that has YZZ in the P/N you are getting Toyota's economy line. With some parts it is the only option as with the oil filter right now. But for air filters you can still get the original and should request it as it is much larger. Brake pads are also a part where you never want the YZZ P/N and if they hand it to you walk out the door if that is all they offer.f6f7056956308009aea406167f64bb27.jpg s-l1600.jpg
    bulldog93, Y0TA PR0, blenton and 3 others like this.
  8. Jun 11, 2024 at 5:45 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Do you guys know if you can get the OEM from Rock Auto for example, or do you have to get 'em from the dealer?
  9. Jun 12, 2024 at 3:54 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Factory-equipped air filter in my 2019 SR5 TRD Offroad had a prefilter glued to it. The rubber seal was orange, not black, like OP100 has. I wish I took a picture of its part number, but I did not. Anyone knows the number?
  10. Jun 12, 2024 at 4:21 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Under the "belt and suspenders" theory.................here's the actual box with part # for the standard Toyota engine air filter.
  11. Jun 14, 2024 at 7:55 AM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    How was this tested? Over the years, I’ve read a few tests and Wix came out near the top in flow and filtration in all.
    Sunfish and 17inferno like this.
  12. Jun 14, 2024 at 8:08 AM
    blanchard7684
    blanchard7684 New Member
    That is interesting. By anecdote I recently put a WIX in my truck out of lack of any other option, and I swear I lost 15 hp.
  13. Jun 14, 2024 at 8:55 PM
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    Interested in how this was tested... Though I guess it doesn't matter as I've always used the fat OEM air filter
  14. Jun 14, 2024 at 9:05 PM
    2mchfun
  15. Jun 15, 2024 at 2:54 AM
    Adamace1
    Adamace1 New Member
    None....
    So everybody in in agreement that the newer thinner filter is in fact the replacement filter for the Tundra?
    I guess same thing goes for the more red oil filter too.
  16. Jun 15, 2024 at 7:53 AM
    BushBandit
    ^^ This
