Access cab rear axle housing width
Discussion in '1st Gen Tundras (2000-2006)' started by Kalannar97, Jun 8, 2024.
  1. Jun 8, 2024 at 8:01 PM
    Kalannar97
    Kalannar97 [OP] New Member
    Michael
    Tullahoma, TN
    2003 Red Tundra SR5 2wd Access Cab V-8 Auto LSD Rear Axle
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    Hello all. I'm trying to find a new housing for my dad's truck and I found one possibly in good condition. But the guy bough the axle to use in an off road builder and doesn't know what exact type of Toyota it came out of. I see measurements but they have wms on it which I understand. But I need just to the end of the housing since that is what he is selling. Can anyone get me this number? The truck is in IL and I'm in TN and my dad can no longer drive or help get me a measurement from his truck. Thabk you in advance.
  2. Jun 8, 2024 at 8:11 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    If your dad's truck has the optional ABS, make sure this housing you're looking at has the ABS ports (holes for the ABS sensors). They're located at the top of the tubes, right next to the axle tube end flange.
  3. Jun 8, 2024 at 8:25 PM
    Kalannar97
    Michael
    Tullahoma, TN
    Screenshot_20240603_155628_Gallery.jpg The truck is in another state. Can you tell from this picture if it has ABS?
  4. Jun 8, 2024 at 8:28 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Are you sure its an access cab and not a double cab?
    Can you get a picture from the person of the bedside to see which fender flares it has? The trucks with the wide fender flares have the wider axle.
  5. Jun 8, 2024 at 8:29 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    @VR6T wanna sell this dude an axle housing that looks a million times better?
    VR6T likes this.
  6. Jun 8, 2024 at 10:16 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I mean I could.
    @Kalannar97 I have my old 3.961 open diff with ABS option. It will need axle seals, but other than that it's solid, fresh diff oil, drain plug magnet was bare as fuck. Has maybe 1200 miles on the fluid, drums were done 3 years ago, have about 9000 on them, will need new shoes, axle fluid got in the drums. Oh and new ABS speed rings in 20. Housing and axle shafts had 2169xx when swapped. Surface patina no real rust
    Make me an offer
  7. Jun 8, 2024 at 10:48 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    That would cost an arm & a dick to ship. I drove to memphis so many times i forgot how far TN is.
  8. Jun 8, 2024 at 11:02 PM
    VR6T
    Is he not in TX?
  9. Jun 8, 2024 at 11:09 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    No
  10. Jun 9, 2024 at 3:19 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I have a 2000 Access Cab, I can measure the axle. What precise measurement do you want?
    The rust on that axle in the pic looks horrible. Personally, I'd pass on that. Might want to check car-parts.com for a local salvage yard.
  11. Jun 9, 2024 at 6:02 AM
    Kalannar97
    Michael
    Tullahoma, TN
    Let me clarify. The picture I posted was the one of my dad's truck that I need to replace. I was asking if anyone could tell if it had ABS. The one I'm looking at buying is really clean. But it is just the axle housing and he didn't know what Toyota it came from as he was just building an off-road vehicle but has no changed his mind about doing it.
    Mr.bee likes this.
  12. Jun 9, 2024 at 6:04 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Good deal. That ones seen better days.
    I think this is the abs plug.
  13. Jun 9, 2024 at 6:06 AM
    Kalannar97
    Michael
    Tullahoma, TN
    Here is a picture of the axle I'm looking to buy. That should show the measurement I need. It also comes with thegeara as well.
  14. Jun 9, 2024 at 10:16 AM
    Kalannar97
    Michael
    Tullahoma, TN
    He messaged me back and said it was 57" from flange to flange on the axle housing.
  15. Jun 9, 2024 at 10:31 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Nope. My shock mounts are inboard of the spring perches.
  16. Jun 9, 2024 at 11:49 AM
    Kalannar97
    Michael
    Tullahoma, TN
    You are correct. I see that now when I look at both pictures more closely. Tha k you.
  17. Jun 10, 2024 at 4:51 AM
    tvpierce
    Maine
    I know that particular axle isn't going to work for your dad's truck, but I measured the axle on my 2000 Access Cab for future reference: Flange to flange is a hard measurement to get with axle on the truck, but the backing plates seem to be on about the same plane as the inside of the flange. So I measured from the inside of both backing plates, and it's 58 5/8".
    NickB_01TRD likes this.
  18. Jun 10, 2024 at 12:24 PM
    badass03taco
    That is a 2005+ tacoma prerunner/4wd with the shocks outside the frame i do believe
