brakes still squeaking after putting new ones
Discussion in '1st Gen Tundras (2000-2006)' started by Humphrey316, Jun 10, 2024.
  1. Jun 10, 2024 at 9:51 AM
    Humphrey316
    Humphrey316 [OP] New Member
    humphrey
    2004 tundra SR5 2WD
    No
    replaced my front brakes yet they are still squeaking when im coming to a stop. Any suggestions?
  2. Jun 10, 2024 at 10:11 AM
    How do you know it's not coming from the rear?
    bmf4069 likes this.
  3. Jun 10, 2024 at 10:14 AM
    Humphrey316
    humphrey
    2004 tundra SR5 2WD
    No
    I said the Front Not the Rear
  4. Jun 10, 2024 at 10:20 AM
    Did you grease everything? Pads put in the right way? New pads and rotors?
  5. Jun 10, 2024 at 10:23 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Are your wheels & calipers tight? Bed the pads in?
    The backing plates arent rubbing the rotors are they?
  6. Jun 10, 2024 at 10:33 AM
    Easy tiger, it’s a legit question. Sound can bounce around and fool the ear. He was merely asking if you had confirmed it was indeed the front, like had someone outside of the vehicle confirm the sound was coming from the front. Very little information given, so it’s difficult to give good suggestions. Were the pads you removed old and worn out? What type of pads are you using? Did you replace rotors and pads? Did you put the anti-squeak lube on the back of the pads? Did you replace the anti-rattle clips? Did you properly bed the pads in after instillation?
    Weagle, FrenchToasty, ATBAV8 and 2 others like this.
  7. Jun 10, 2024 at 10:48 AM
    bfunke
    bfunke Tundra Curmudgeon
    Did you apply caliper grease to the back of the new pads?
    ATBAV8 and Randy Morton like this.
  8. Jun 10, 2024 at 11:03 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    What pads (brand and part number) did you use?
    Some pads are noisy, due to material or just poor fit.
    Weagle likes this.
  9. Jun 10, 2024 at 11:41 AM
    shifty` Oh, I have felt Cobain's sarcoma
    Rear brakes require grease in 6 points, as I recall, where metal sits on metal. So @FirstGenVol has a valid reason to ask the question, and you have a valid reason to check it's not the contact points on the rear causing the squeal. Unless you've got your ear on the wheel while the truck is backing up and you're 1,000% positive it's coming from the front ... no reason to shoot that idea down.
    For the fronts, your new pads, unless you went with shitty store-brand parts, should've come with shims. If they weren't pre-glued, you must pre-glue the shims onto the pads using something like CRC Disc Brake Quiet. There's a flash time using that product, you apply to the shim and the pad, but you need to wait 5-10 minutes (read the f'n bottle) before adhering them. If your pads didn't come with shims, that may be problematic. Some pads, like Advics (which are the Toyota OEM supplier), come with the shims pre-glued.
    For disc brakes, you can install the pads backwards and/or on the wrong side and that'll lend to noise. You only use one squealer pad per pair/caliper, the squealer pad goes on the lug nut side of the caliper, and the squealer needs to be oriented upward. If they were installed backwards previously and with new pads, that may be your issue.
    But I'd also check your dust shields. Especially if you're in the rust belt. This was the cause of my recent aggravating squeal. Inspect your shit. https://www.tundras.com/posts/3576977/
  10. Jun 10, 2024 at 11:46 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
  11. Jun 10, 2024 at 6:38 PM
    2003DC
    2003DC New Member
    The pads should be installed with a set of shims - two shims per pad. The shop manual requires you to lubricate the first shim that goes right against the pad (the slotted one). If you didn't use shims or didn't grease the shims, that could be your problem.
    ToyotaDude likes this.
  12. Jun 10, 2024 at 8:12 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    The grease points on rear drum brakes are to prevent the shoes from wearing out the backing plate. If you don't grease them, it will not cause significant noise, only wear. The only thing I have ever found that causes squealing drum brakes is too hard pad material, brake dust and poorly seated pads.
