My next project - LED Bed Strip Kit with Waterproof on/Off Switch Blade
Discussion in '2.5 Gen Tundras (2014-2021)' started by JohnWhicker, Jun 10, 2024.
  1. Jun 10, 2024 at 8:13 AM
    JohnWhicker
    JohnWhicker [OP] New Member
    What do you guys recommend in terms of approach and parts for a good LED strip for my truck bed. Something that is reliable and it does not break after few months. Any personal suggestions please? Any good experiences you could please share?
    HulkSmurf14 likes this.
  2. Jun 10, 2024 at 8:47 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    BushBandit and mattgecko like this.
  3. Jun 10, 2024 at 8:58 AM
    What are you looking to spend?
  4. Jun 10, 2024 at 9:23 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    reneaux and HulkSmurf14 like this.
  5. Jun 10, 2024 at 9:29 AM
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
  6. Jun 10, 2024 at 9:40 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    I have kits in stock specifically made for the Tundra's.
  7. Jun 10, 2024 at 9:43 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I have the same ones except mine is the 3-pc kit. (Like $33)
    The 2-pc is probably plenty bright.
    Love being able to hit the switch and see what I'm doing, find what I'm looking for. Mine have been in for at least a year with no issues. Some people in the Amazon reviews said the adhesive was weak... I cleaned the surface REAL good with alcohol and they're still stuck just fine.
    They fit quite well... I have a CM and just had a little extra wire to zip tie in the front corners of the the 5.5' bed, I'm guessing DC would use up that extra and fit perfectly.
    TreeCat likes this.
  8. Jun 10, 2024 at 9:46 AM
    SD Surfer
    Bruce
    So Cal
    FYI, I've heard nothing but good things about the MattGecko's above ^^^ & having the dual colors might be kinda' cool.
  9. Jun 10, 2024 at 11:37 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    1 year deep with the same Amazon kit above. Still love it. Easy install. I got the 2 pc setup. Plenty of light.
  10. Jun 12, 2024 at 3:14 AM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    I’m super happy with Matt Gecko kit, quick service, and its custom made …lots of experience doing these …it will work if you follow his instructions…one of my favorite mods
    mattgecko likes this.
  11. Jun 12, 2024 at 3:32 AM
    smokint
    smokint New Member
    Order Matt’s truck bed kit AND his under hood kit…they’re inexpensive, and if you’ve gone to the trouble to run the wire from bed to engine bay, you just splice the bed powerline to the hood light and voila!
    The hood light is literally less than 10 minutes if you’re also doing bed light…it’s super useful, especially if you go camping or overnighting somewhere…
    I can walk you thru it if you need help!
    Robert
  12. Jun 12, 2024 at 7:58 AM
    SD Surfer
    Bruce
    So Cal
    Got a link to the shovel/axe holder?
    Is it bolted at the bottom too or just in the rail?
  13. Jun 12, 2024 at 8:48 AM
    JohnWhicker
    What is least intrusive way to tap into something in the back and get a 12V. Perhaps the trailer hitch connector (can I get a source there) or tap into the license plate lights harness? I hate running a wire all the way to the battery or tapping into the fuse box or taping into something else. Not being lazy, just being less intrusive :) But I do need to keep an open mind as well :)
  14. Jun 12, 2024 at 9:15 AM
    SD Surfer
    Bruce
    So Cal
    I went direct to the battery 'cuz I wanted constant power to the bed lights and 12V/USB receptacle, and didn't want to have to futz with turning on anything else like running lights, etc.
    I think anything you tapped into elsewhere would need to be energized with another switch.
  15. Jun 12, 2024 at 11:09 AM
    JohnWhicker
  16. Jun 12, 2024 at 12:41 PM
    smokint
    smokint New Member
  17. Jun 12, 2024 at 12:57 PM
    SD Surfer
    Bruce
    So Cal
  18. Jun 12, 2024 at 12:59 PM
    smokint
    smokint New Member
    I wish I had got the full molle, but this works fine
    Got my Bedrug mat today, unfortunately it was for an F150….back to Amazon it goes :rolleyes:
    SD Surfer[QUOTED] likes this.
  19. Jun 12, 2024 at 1:03 PM
    smokint
    smokint New Member
    Running the wire was the hardest part, but not hard. You drill a little hole under rear of driver bed rail, fish it in, pull down and drill a hole in metal by bumper for ground, screw in self tapping screw, then get on your creeper armed with a lot of zip ties, and work your way forward following existing wire looms…I went over spare tire to passenger side, then above frame to front passenger wheel well and up into engine bay…sounds harder than it is :D
  20. Jun 13, 2024 at 11:14 AM
    BushBandit
    There's not a constant at the brake harness. Only voltage when something is on such as brakes, running lights, turn signal. Same with the license plate harness, it's only on when the running lights are on.
    It really is easy to follow the factory harness from the bumper to the engine bay. I was even able to snake mine through the factory zip ties on the harness. I want all the way to the passenger headlight then cut across the radiator under the cover
  21. Jun 13, 2024 at 11:20 AM
    I tapped into one of the license plate lights. You will just need to have the parking lights on to get power to the switch.
