Engine work
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fatbastard, Jun 8, 2024.
  1. Jun 8, 2024 at 8:56 AM
    Fatbastard
    Fatbastard [OP] New Member
    2017 black tundra sr5 5.7
    Have a 2017 tundra that I have maintained myself with 80,000 miles. Any suggestions as what I should have Toyota work on at this time? Something they actually put a wrench on not the visual inspection and charge me $150. Thank you in advance for any information you have.
  2. Jun 8, 2024 at 9:50 AM
    bfunke
    bfunke Tundra Curmudgeon
    Is it running well and not throwing any codes. Change oil and filter every 5K with 5W30 full synthetic. If you havent changed antifreeze, ATF, TC and diff oils do it now. Also new brake fluid and air/cabin filters and you should be GTG. This engine should run 1M miles with normal maintenance. Don’t let the dealer rip you off.
    Mdl likes this.
  3. Jun 8, 2024 at 10:31 AM
    Fatbastard
    Thank you very much. Thought maybe a valve job or belt replacement would be helpful? As for your suggestions I can/will take care of those. Thank you again.
  4. Jun 8, 2024 at 10:36 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.tundras.com/threads/tundra-maintenance-guide.315/
    :cheers:
  5. Jun 8, 2024 at 10:39 AM
    Ericsopa
    Ericsopa Old man and the sea
    Valve job @ 80K?!? Oh hell no!! And you can inspect the belt yourself, too, and replace if necessary. Easy peasy.
    And welcome aboard!
  6. Jun 8, 2024 at 10:51 AM
    2mchfun
    Change your pcv valve. Easy and important every 30k or so
  7. Jun 10, 2024 at 8:12 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Just make sure fluids are up to date.
