Center console/cup holder configuration
Discussion in '3rd Gen Tundras (2022+)' started by Silver23, Jan 10, 2023.
  1. Jan 10, 2023 at 2:05 PM
    Silver23
    Silver23 [OP] New Member
    2023 Silver 1794 TRD
    I've noticed that there must be two different set up's on the Tundra. I have a 1794 and the cup holders are "vertical" and there's some wasted space (or lackthereof) to the right of the cup holders. Additionally, the location in front of the cup holders where you charge your phone is angled at the bottom which makes it almost useless for anything other than your phone. On other models, the cup holders are horizontal and the area where you charge your phone is much larger where you could store other things besides your phone. Other than the ability to cover your cup holders with the lid, not sure why Toyota did this.
  2. Jan 10, 2023 at 8:27 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I've wondered this too. Our 1794 has the vertical as you describe. As the driver I have to reach over the lower cup to get to mine on the top. Or...to get to the lower one I have to really wrench my wrist to get a grip on it as the center console is pretty tall. Either way it's a dumb design IMHO.
    Additionally I find that the plastic springy things in the cup holders hold the cup/can pretty tight. Good for stability. But....on day one with our new truck, reaching for a Subway cup with lid, I didn't know to pull it so hard to get it out and the lid popped off the cup spilling pop on the gear shift. Fortunately it was diet coke, so "only" left ugly colored water, no sugar to get sticky. Wife and have now officially christened our new truck :(
  3. Jan 10, 2023 at 8:35 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I have a platinum and have the same vertical cup holders . My grief with this center console is that I have nowhere to use as a base drum of sorts to music . Everything feels like plastic
  4. Jan 11, 2023 at 3:48 AM
    dowdydl
    dowdydl New Member
    I have a Platinum and have the same vertical cup holders also. Everything doesn't just feel like plastic, it IS plastic.
  5. Jan 11, 2023 at 5:11 AM
    Silver23
    LOL. I was thinking the same thing about the cup holder tensioners. Bad design. Every time I'm setting my Dr. Pepper can in there, I have to angle the can to get it in there and end up spilling it. Maybe they'll loosen up over time. LOL.
  6. Jan 16, 2023 at 4:17 PM
    Mookie
    Mookie New Member
    That’s not how you christen a new truck.
    Raven67 and SAGE63 like this.
  7. Jan 18, 2023 at 7:18 AM
    nnguyen04
    nnguyen04 New Member
    anybody know the part number to replace it with the lower trim design?
  8. Jan 18, 2023 at 8:39 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
  9. Jan 18, 2023 at 12:57 PM
    Havoc353
    Havoc353 New Member
    I’ll save you the read, there doesn’t seem to be an easy solution. Others tried to figure out what part numbers to order without anything definitive.
  10. Jan 9, 2024 at 8:38 AM
    jedi008
    jedi008 New Member
    Pete
    Supersonic Red Tundra
  11. May 27, 2024 at 8:58 PM
    Bacchus1310
    Bacchus1310 New Member
    Joel
    2022 Tundra SR5 TRD
    Does anyone know of a modification that removed those little annoying spring arms in the front cup holders? I can't stand them. Haven't been able to find anything to swap them with or some way to have a cup holder without them!
  12. May 27, 2024 at 9:23 PM
    Hella Krusty
    Hella Krusty New Member
    Pull the console up and remove them.....just a thought !
  13. May 27, 2024 at 9:44 PM
    Bacchus1310
    Joel
    2022 Tundra SR5 TRD
    That may be what I do. I thought maybe there was an insert or something else that didn't leave the openings. Thanks
  14. May 28, 2024 at 7:21 AM
    jedi008
    jedi008 New Member
    Pete
    May I suggest looking at AJT Design? They have a fantastic solution. I have the 1794 edition and swapped out the stupid fake walnut lid to gain more space and a side by side cup
    mayan likes this.
  15. May 28, 2024 at 7:49 AM
    Bacchus1310
    Joel
    2022 Tundra SR5 TRD
    I already have those cup holders. What I want to get rid of are those spring loaded "arms" that make noise and annoy me when I put a cup in the holder. hahaha
    Soupbean77 likes this.
  16. May 28, 2024 at 8:23 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I'm constantly tempted to purchase the oversized (regular size?) cup holders, but I'm not enthusiastic about tearing the center console apart.
    I really miss being able to secure two nalgenes up front.
    ryanwgregg likes this.
  17. May 28, 2024 at 8:35 AM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Super easy to do honestly. Just follow AJT’s video and you will not have any issues. Hardest part was getting the shift knob off. Other than that only took about 30 minutes to swap and put everything back together
  18. Jun 9, 2024 at 6:00 PM
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    2024 Silverado 1500 LZ0
    Did my swap today.
    The AJT VIDEO isn’t completely correct. The 1794 cup holder has four of the spring cup holder tabs, not two. You will not be short two of those if you do the swap.
    The parts are high quality and I really like the new console’s utility with the open spaces.
  19. Jun 9, 2024 at 6:02 PM
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    AJT's video is wrong here too. All you need to do is push one of the metal tabs to the left or right. Take a small screwdriver and push the left tab to the left. Then pull up on the knob and it will come off.
    Do not try and push the metal clip towards the dash. All you will end up doing is yelling at the knob b/c it won't come off.
  20. Jul 17, 2024 at 9:06 PM
    nmk_61802
    nmk_61802 New Member
    Wonder if the oversize holders would allow me to set my Tervis mugs in this location
  21. Jul 17, 2024 at 9:16 PM
    HulkHog
    HulkHog New Member
    2024 Limited Nightshade - 3” dealer lift w/ 20 in. wheels; Nitto RidgeGrappler 35x12.50R20LT
  22. Jul 18, 2024 at 9:19 AM
    nmk_61802
  23. Jul 18, 2024 at 9:55 AM
    SM Tundra
    Cody
    I fit my 40 ounce hydroflask in the oversized couple holder and have no issues. I always have a hydroflask with me so the oversize cup holder was a must.
  24. Aug 27, 2024 at 1:16 PM
    Just_Tito
    Just_Tito New Member
    23 Tundra
    I’m waiting for my kit to arrive. Are those screw holes just for show? I don’t like them… It doesn’t go with the Platinum interior
  25. Aug 27, 2024 at 1:22 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    They will not flow at all with a Platinum...thats why I stayed away. Theyve got no plans on making plain ones either, iirc.
  26. Aug 27, 2024 at 1:26 PM
    Just_Tito
    23 Tundra
    if they’re fake, I’m going to sand them down and hopefully find a brushed overlay. Not everyone wants to these overland style products
  27. Nov 5, 2024 at 8:09 AM
    Tomlastrange
    Tomlastrange New Member
    Tom
    2022 Tundra 1794
    I installed the AJT “downgrade” today in my 2022 1794. When moving the cup stabilizers I managed to lose one of the springs. Any idea how I find a replacement part number for the springs or stabilizer+spring combo? Thanks
  28. Jan 11, 2025 at 5:09 AM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    Farmers Branch , Texas
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Any play with different size cups in the oversized cup holder? Thinking of grabbing one to get two full deep cup holders.
  29. Jan 11, 2025 at 6:13 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Agreed 100%…. No need to reinvent the wheel or reimagine a simple cup holder. I just need a simple round semi deep hole to set my normal water bottle/cup of coffee or the wife’s can of pop, and go around a corner without it flying out. I really have no need for a quart of milk or 40 liter beer in my front console.
