Best fitting bug deflector?
Discussion in '1st Gen Tundras (2000-2006)' started by CC80guy, Jun 7, 2024.
  1. Jun 7, 2024 at 7:23 PM
    CC80guy
    CC80guy [OP] New Member
    Larry
    Lehighton, PA
    Who makes the best fitting bug deflector for a Gen 1 (2001)? I've been reading reviews for a couple of days and it seems nobody makes one that fits without some massaging/trimming/grinding. If not a perfect fit whose requires the least modification to get it to fit? Opinions?
    AlexiosTundra02 likes this.
  2. Aug 23, 2024 at 4:18 PM
    AlexiosTundra02
    AlexiosTundra02 New Member
    Ventura County
    2002 Tundra AC 4WD
    Amazon has behind the grill or front mount. Do you know which ones me fits 2001?
  3. Aug 23, 2024 at 4:24 PM
    @abcinv can answer this question. I believe there's a thread on it, but he's got the info, and the product is way less $$ than I expected.
    abcinv and AlexiosTundra02 like this.
  4. Aug 24, 2024 at 3:08 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    shifty` likes this.
  5. Aug 24, 2024 at 3:59 AM
    The best was the original Toyota one honestly. Wish they still made them.
    Weagle likes this.
  6. Aug 24, 2024 at 4:37 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I got mine direct from WeatherTech for 80 bucks.
    The one I tried before that was what a lot of others ran into that would've required a lot of cutting
  7. Aug 24, 2024 at 5:47 AM
    CC80guy
    Larry
    Lehighton, PA
    I put this one on. I did not have to cut etc to get it to fit. However, there is one problem and I believe it exists with all the new acrylic deflectors, they warp in the center in the sun. What I did to fix that is to put 3 small self-adhesive rubber bumpers stuck to the back of the deflector between it and the hood. Problem solved.
    https://www.amazon.com/gp/product/B000CSNK8E?th=1
    https://www.amazon.com/gp/product/B075KZBR2Y?th=1
    Burgmane, shifty` and Weagle like this.
