My $1500 tundra lol
Discussion in '1st Gen Tundras (2000-2006)' started by VWmanwithTundra, Jun 6, 2024.
  1. Jun 6, 2024 at 3:38 AM
    VWmanwithTundra
    VWmanwithTundra [OP] New Member
    Kevin
    2002 tundra access cab
    Work in progress lol
    I bought this 2002 tundra for a dynamic deal.... Or so I thought lol. It has a starter problem..... Previous owner handed me a fuse and said if it's not removed the battery will drain. Ok whatever lol.
    The starters bearing broke and the gear was stuck out. Ok new starter ( not denso oops) turns out previous owner while beating a hole in the top of the starter broke both knock sensors and wiring harnesses. Fixed that. I also decided it might be wise to change the timing belt so I did that. The truck started right up but was blowing water out of the exhaust after having both heads rebuilt resurfaced and head gasket. Started to write up and ran perfectly but the damn power steering pump was pouring out! Replaced that!
    So then I go to drive it, almost no brakes! So the previous owner let the brake shoes get so low and ride on metal for so long that it elongated the brake drum holes not to mention that 5 out of the six wheel studs where cross thread and barely holding on. I'll replace all those parts. So it turns out that the rotor in the front is so worn that it overextended the caliper Pistons bent the caliber backwards and broke the lower mount bolt!
    Then in the middle of all this it randomly starts not wanting to start. Damned if this brand new starter now doesn't work lol
  2. Jun 6, 2024 at 4:26 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Having fun yet?
    Mater and Black Wolf like this.
  3. Jun 6, 2024 at 4:30 AM
    Keep us updated. Check all of your ground connections......buy a 6 pack
    OldGuy03 and bulldog93 like this.
  4. Jun 6, 2024 at 5:01 AM
    Just a friendly reminder, as you're working on brakes... having a functional, un-frozen parking brake is vital to proper, firm braking on these trucks. If your parking brake isn't properly adjusted, and the bell cranks aren't adjusted by the book, soft brake pedal is a classic symptom. There's a sticky thread that covers this on the 1st gens.
    Toyotoholic, Black Wolf and bulldog93 like this.
  5. Jun 6, 2024 at 5:21 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Hey, did you get this in MA? On craigslist? I reached out to a guy with a remarkably similar truck going for 1500 a few weeks ago. After hearing about it more from him I passed.
  6. Jun 6, 2024 at 5:33 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    If not rusted out that's a good deal here. Running or not.
    rock climber likes this.
  7. Jun 6, 2024 at 10:36 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Keep at it, you'll get there and love it!
    Weagle and OldGuy03 like this.
  8. Jun 6, 2024 at 10:56 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Enjoy the Tundra. I think old VWs and 1st Gen Tundras are kindred spirits. They're relatively easy to work on, keep running forever and serve their purpose very well. Oh, and rust will take both of them out. My Tundra has 250K mikes and the Vanagon has 320K miles and I plan to keep running them for many more miles.
    Weagle likes this.
  9. Jun 6, 2024 at 10:58 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    It gets better, I promise. Just went through a similar ordeal on a Tundra I bought last year. It took a lot of work to get it where it should be, but the work paid off (well, almost, it's drivable now, just working on swapping the muffler out, then I'll be done).
    Weagle likes this.
  10. Jun 7, 2024 at 9:47 AM
    VWmanwithTundra
    Kevin
    Well I spent about 4 hours diagnosing and non-start issue that ended up being a defective new starter.
  11. Jun 7, 2024 at 9:47 AM
    VWmanwithTundra
    Kevin
    During my extremely stressful starting issue diagnostic I added a new ground wire actually two new ground wires lol
  12. Jun 7, 2024 at 9:48 AM
    VWmanwithTundra
    Kevin
    Looking at the mechanism doesn't let it adjusts itself when you drive backwards and stop?
  13. Jun 7, 2024 at 9:52 AM
    VWmanwithTundra
    Kevin
    This is my replacement work truck for my 04 Tacoma 2.4 workhorse beast!
    I have the tundra, the Tacoma, a first generation trooper, a VW caddy (Volkswagen's el Camino lol), a VW cabby (beach cruiser), a old bug, and a Corvette
    jimf909[QUOTED] and Black Wolf like this.
  14. Jun 7, 2024 at 9:54 AM
    VWmanwithTundra
    Kevin
    I got free tires I'm excited!
  15. Jun 7, 2024 at 9:56 AM
    Denso starter?
    Jack McCarthy likes this.
  16. Jun 7, 2024 at 9:58 AM
    Those drum holes look drilled
    BroHon likes this.
  17. Jun 7, 2024 at 10:03 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Explain yourself. Those look mint
    Weagle, Mater and Jack McCarthy like this.
  18. Jun 7, 2024 at 10:04 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    This is how you gotta try to do it. I don't know what your situation is but, it's great if it's not your primary vehicle and you aren't under the gun to get it running. Take your time, learn about the rig, do things right and you'll really love it when you get all the kinks worked out.
    Weagle likes this.
  19. Jun 7, 2024 at 10:07 AM
    VWmanwithTundra
    Kevin
    No
  20. Jun 7, 2024 at 10:08 AM
    VWmanwithTundra
    Kevin
    No it because only two lugs were tight rest cross thread and riding metal to metal long time
  21. Jun 7, 2024 at 10:09 AM
    VWmanwithTundra
    Kevin
    Found them at the dump they have 90% tread one has a nail in it but whatever
  22. Jun 7, 2024 at 10:10 AM
    Date code?
    OldGuy03 likes this.
  23. Jun 7, 2024 at 10:12 AM
    VWmanwithTundra
    Kevin
  24. Jun 7, 2024 at 10:15 AM
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    My reading on the subject suggests that it adjusts every time the E brake is used. For trucks without a manual trans, this may be a rare occurance!
  25. Jun 7, 2024 at 10:17 AM
    Nice score. As mentioned, have you checked the date code on the tires yet?
  26. Jun 7, 2024 at 10:17 AM
    FishNinja
    Lee
    06DC2wd
    Shit. If they mount and balance and hold air. You are fucking winning. Go buy a lottery ticket
    BroHon, 2mchfun, Weagle and 4 others like this.
  27. Jun 7, 2024 at 10:18 AM
    I want to know where that dump is........
    BroHon, 2mchfun, Weagle and 6 others like this.
  28. Jun 7, 2024 at 10:28 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    X2.
    Especially with the price of tires these days.
  29. Jun 7, 2024 at 10:43 AM
    It’s in the good part of town you can’t afford to live. They even have a sales clerk to tell you about the “reconditioned” inventory.
  30. Jun 7, 2024 at 10:49 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    those are actually great tires!
    Weagle likes this.
