First Gen Lower Ball Joint(LBJ) Failures
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, May 1, 2024.
  1. Jun 6, 2024 at 5:18 AM
    #91
    Dook55
    Dook55 RCLB Guy
    Montana
    We would know a lot more about this if we knew whether he used OEM parts. Most likely not, IMO. Like I stated earlier, mine have 250K miles on them and I have taken the bolts off and put them back on with an impact 5 times, still original bolts, never used a torque wrench or Loctite. No LBJ problems ever. I am the original owner.
    I also have another Tundra, a cherry 2004 RCLB 4x4 with 152K miles, which I bought used at 128K miles. The PO gave me a file of repair records and nothing about LBJ in them, so I imagine they are original. I will replace the LBJ on this one as well when I get around to it. The lower control arm bushings have some cracks so I'm contemplating whether to do the LCA's and LBJ's all at the same time. Over $800 of OEM parts and then have it aligned.
  2. Jun 6, 2024 at 7:29 AM
    #92
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    option 2 is the best option. Striking anything with a hammer leads to deformation and fracturing. Use a puller and few taps with a hammer will get it pop if the puller doesn't do the job itself. refrain from the "just keep smacking it"
    HBTundra likes this.
  3. Jun 6, 2024 at 12:07 PM
    #93
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    Big ooof :(
    Stolen from Facebook.
    G_unit3000, BroHon, Tlar25 and 4 others like this.
  4. Jun 6, 2024 at 12:13 PM
    #94
    At least they were able to maintain control.
  5. Jun 6, 2024 at 1:11 PM
    #95
    bfunke
    bfunke Tundra Curmudgeon
    Yup. Saw a Tundra roll in front of me when his LBJ broke loose on a curve doing 55
    Tlar25 and Jack McCarthy like this.
  6. Jun 7, 2024 at 3:32 AM
    #96
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    That's exactly what mine did but I didn't swerve across 2 lanes of traffic. Pretty sure I got it stopped a lot sooner than that too.
    Jack McCarthy likes this.
  7. Jun 9, 2024 at 2:23 PM
    #97
    Dook55
    Dook55 RCLB Guy
    Montana
    OK, I just installed kit 04006-62134 (plus new bolts) which I believe are the recall LBJ's, on my stock 2006 RCLB. After 250K miles the old ones still looked perfect. Before I removed them I tested them with a pry bar and they had no slack. The old ones were recall LBJ installed by the dealer.
    What keeps coming to mind is that I'm not certain that recall LBJ's ever fail by shearing in half. Isn't it only the OEM originals (pre-recall) and aftermarket LBJ that fail that way? We should draw a distinction here and we have to draw a distinction between slack failures and shearing failures. Does anyone know for a fact that recall LBJ's have broken in half (not to be confused with ball slack failure)?
    I watched a couple videos beforehand and was under the impression that you have to remove the 4x4 axle nut. Why? Just remove the 4 LBJ bolts and set a jack stand under the rotor, lifting it 2" off the LBJ so you can get it out. Easy peazy.
    I did not use any pullers since I have none that fit and I live way out in the middle of nowhere and didn't want to go for a ride. It seems the consensus here is that the only alternative to pullers is a BFH. I used to be a mechanic back in the 70's and it was understood that you didn't pound tie rod ends with a BFH, you use a SFH. A small hammer has more speed and impact of the type that jars the bolt free. The speed is the trick. On the LBJ main bolt I used a BFH as backup on one side and beat the other side silly with a SFH and it took a lot of wailin but they came free. Just be sure your aim is true on the tie rods so you don't damage the tie rod or boot. On both the tie rods and ball joints it took more than 15 licks with the SFH.
    Next I get to do my 2004 RCLB ball joints with 152K miles and as far as I know they are original, and since it was made in January, they might be the older type used in 2003.
  8. Jun 9, 2024 at 2:48 PM
    #98
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Huh. I haven't looked at an official Toyota writeup of how to do the job, but I've never heard to remove the axle nut. Either way you're right, there's no need.
  9. Jun 17, 2024 at 4:01 AM
    #99
    FirstGenVol [OP] Recovering mangler
    BroHon and The Black Mamba like this.
  10. Jun 17, 2024 at 4:09 AM
    #100
    I saw this happen to a Range Rover the other day in the Northbound traffic on I93. Traffic was backed up for over a mile or two.
  11. Jun 17, 2024 at 6:47 AM
    #101
    Another one potentially?
    Tlar25, bmf4069, 87warrior and 2 others like this.
  12. Jun 17, 2024 at 7:32 AM
    #102
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    That's a reminder that it's not just your life that you're gambling with
    Tlar25, tvpierce, bmf4069 and 3 others like this.
  13. Jun 17, 2024 at 9:01 AM
    #103
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    Yeah, I'm definitely getting mine replaced next month. These pictures all of you are posting are scaring the crap out of me.
  14. Jun 17, 2024 at 11:43 AM
    #104
    Mine are getting replaced next month too. With OEM this time since y'all weren't impressed with my Moogs or Mevotechs, or whatever the hell is under there.
  15. Jun 17, 2024 at 11:53 AM
    #105
    shifty` You can call 1 (800) PP5-1-DooDoo
  16. Jun 17, 2024 at 12:12 PM
    #106
    That'll be me after 35k miles if mine don't herniate and kill me and everyone in a three block radius before I get them replaced.
    bmf4069 and shifty`[QUOTED] like this.
  17. Jun 17, 2024 at 12:25 PM
    #107
    Solid Snake
    West TN
    2006 AC 4x4 V8
    How many miles are on your current LBJs?
  18. Jun 17, 2024 at 12:27 PM
    #108
    Too many
    bmf4069, shifty` and KNABORES like this.
  19. Jun 17, 2024 at 12:27 PM
    #109
    See above post, around 35k miles.
  20. Jun 17, 2024 at 2:07 PM
    #110
    My algorithm is going hard today. This shit it starting to anger me. We share the road with these people and they think it's funny. Owner reported almost 200k miles on this set....
    Bought2Pull likes this.
  21. Jun 17, 2024 at 2:10 PM
    #111
    FishNinja
    Lee
    06DC2wd
    I'm like 90% sure that AZ is in SA area by castle hills
  22. Jun 17, 2024 at 2:13 PM
    #112
    142k miles..
  23. Jun 17, 2024 at 2:15 PM
    #113
    bmf4069 Captain wtf
    Be sure and get pics. We like pics.
    The Black Mamba likes this.
  24. Jun 18, 2024 at 3:12 AM
    #114
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    …you know that he walked right into AZ and bought an over the counter AC Delco branded Moog, installed it and now calls it “guud”.
  25. Jun 18, 2024 at 3:15 AM
    #115
    No doubt. Probably reused the same bolts too.
  26. Jun 18, 2024 at 3:16 AM
    #116
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  27. Jun 18, 2024 at 8:22 AM
    #117
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Man, its more than when do I replace my LBJ. IF you are running 33. And have Kings with high articulation ubj, extended CVJ' OR Whatnot. The oem will be overstreased from bigger tire alone. Im not saying dont due that. But, every yota tech that has hands on experience w this stuff sais, stay away from big tires, any extra mass will wear them out...hey i did not lisyen either. But also realized out trucks chould not be on 33+ tires.
    Not if you have dirst king, solo, heim jounts etc and maybe reinfored IFS ( GUSSETS, LBJ CAGE. LIMITING STRAP) different story. I chenck mine ever month. And everytime I wheel and make IFS WORK HARD. Our trucks are light duty trucks w good all around utility.
    Nothing will make them like a dual live axle or custom link set up. Bottom line. If you added additional rotational mass or increased articulation, I would inspect frequently. Test is best done lifted slight by frame with long pry bar as the bolts can llok fine. Its the play under the rubber skirt.
    ps8820 and The Black Mamba like this.
  28. Jun 18, 2024 at 8:25 AM
    #118
    I'm comfortable with 33" tires but I'll keep replacing my LBJ's well before 90k miles. Especially with some of the abuse they see at places like The Cinders.
    Cheap peace of mind to spend $200 every 5 years.
  29. Jun 18, 2024 at 8:32 AM
    #119
    BluegrapeVr6
    J
    I agree, if anyone is not sure about there trucks recall status, several website options for you:
  30. Jun 18, 2024 at 8:34 AM
    #120
    MT-Tundra
    Montana
    I don't get these 1st gen Tundra facebook posts. Are these people just finding the FB group and only just hearing about the ball joint issues after it happens to them? Because from reading this thread, it feels like all these people are already part of that FB group, know about the issue, then when it happens to them are like "cool, now I get to post about joining the LBJ failure club!", like they're waiting to celebrate turning over 300,000 miles or something...
    I'm sure that's not what's happening but it's what it feels like from the outside.
