Best ground location in bed
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAA96, Apr 18, 2023.
  1. Apr 18, 2023 at 4:17 PM
    AAA96
    AAA96 [OP] New Member
    2020 Tundra 4x4 SR5 CrewMax
    Just like the title, where would the best ground location be in the bed? Or should I go through a through hole and down to the frame of the truck? Thanks.
  2. Apr 18, 2023 at 4:28 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Depends on what you're trying to ground, and what you have in your bed (spray liner? plastic liner?). If you're just trying to ground a led light, go off something convenient. If you're installing an inverter, best to do a home run to the batt or at least go to the frame and make sure the connection is clean and solid.
    Saltyhero13 likes this.
  3. Apr 18, 2023 at 4:31 PM
    AAA96
    I have a rough sprayed in liner. I am grounding the air compressor that I mounted in the bed. I am thinking of running it to the chassis.
  4. Apr 18, 2023 at 4:35 PM
    Gravy
    Yucaipa, California
    That's your best bet, air comp is a decent load. There should be a couple of access holes with plastic/rubber plugs on the cab side of your bed you can go thru.
  5. Apr 18, 2023 at 4:38 PM
    AAA96
    I see the thru hole you mentioned. I also see several bolts that hold fuel lines to the chassis. Can I use that bolt for a ground or find one that doesn’t hold a metal fuel line.
  6. Apr 18, 2023 at 4:44 PM
    Gravy
    Yucaipa, California
    If its just one of those viair or arb airbag/train-horn compressers, a bolt should be fine. If its something more serious I'd find a more dedicated ground. Personally I'd go with the later, but I overdo everything.
  7. Apr 18, 2023 at 4:49 PM
    AAA96
    Thanks for the help! Much appreciated.
  8. Jun 6, 2024 at 1:27 AM
    WhiteDevil1978
    WhiteDevil1978 Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    I have an overlanding solar setup and just drilled through the bed and went straight to the chassis with a 4/0 wire. Drill as close to the cab as you can get, or you will start cutting into a bracket the helps hold the bed in place. Crawl under the truck and look up at it. You will see it plain as day.
