Fr33 Lance Fab Built Spindles
Discussion in '1st Gen Tundras (2000-2006)' started by AmericanKing06, Jun 5, 2024.
  1. Jun 5, 2024 at 8:34 PM
    AmericanKing06
    AmericanKing06 [OP] New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    Does anyone have any experience with this company (Fr33 Lance Fab) selling complete build spindles. $700 for a complete set isn't that bad and you can add gussets too. I know many would say just rebuild your set for cheaper. I prefer a straight swap not having to buy extra tools or go to shop.
    https://fr33lancefab.com/
    KNABORES likes this.
  2. Jun 5, 2024 at 8:46 PM
    bmf4069 Captain wtf
    For about $400 bucks, including shop prices, you could do your bearings and hubs. So if the convenience fee is worth $300 to you, I'd say go for it.
    But, the hard part and all the tools required is just to get them out. Once there, all you do is drop them off to have them pressed.
  3. Jun 5, 2024 at 8:47 PM
    What bearings did they use
    edit: checked the link, KOYO bearings. Approved.
    bmf4069 likes this.
  4. Jun 5, 2024 at 8:48 PM
    bmf4069 Captain wtf
    At that price it better be OEM or Timken.
  5. Jun 5, 2024 at 8:51 PM
    AmericanKing06
    New Mexico
    I would need a press to remove any parts right? I really don't have the room for a press.
  6. Jun 5, 2024 at 8:51 PM
    Pass on Timken. KOYO is OEM. Timken ain’t what Timken used to be
  7. Jun 5, 2024 at 8:51 PM
    AmericanKing06
    New Mexico
    Completely assembled spindles/knuckles include:
    Koyo Japanese wheel bearings
    Japanese inner/outer seals
    New retaining clip
    New hub/wheel studs
    Fresh layer of high solids paint
  8. Jun 5, 2024 at 8:52 PM
    He’s saying you could pull your spindle and take it to a shop and have them do the press work.
  9. Jun 5, 2024 at 8:52 PM
    bmf4069 Captain wtf
    Ugh. I'll keep that in mind.
  10. Jun 5, 2024 at 8:54 PM
    AmericanKing06
    New Mexico
    I might have to do a little digging for a reliable shop around me. Ill get quotes this week. Thanks.
  11. Jun 5, 2024 at 8:55 PM
    bmf4069 Captain wtf
    Yes. Spindle you can remove with hand tools and a ball joint press.
    Also, where's the dust shields?
    AmericanKing06[OP] and des2mtn like this.
  12. Jun 5, 2024 at 8:56 PM
    Feels like I’m looking into the future….
  13. Jun 5, 2024 at 8:59 PM
    AmericanKing06
    New Mexico
    The $300 convenience doesn't look to bad HAHA.
    I noticed that too. I wrote to them waiting to hear back.
    shifty` likes this.
  14. Jun 5, 2024 at 9:04 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I believe @STravis with S.O.B. fabrication is in New Mexico, they could possibly weld spindle gussets for you at the very least. Might be able to help you with press work on the bearings, or know someone else who does good work on this sort of stuff.
    bmf4069 and AmericanKing06[OP] like this.
  15. Jun 5, 2024 at 9:11 PM
    AmericanKing06
    New Mexico
    I hear good things from AVS in Albuquerque. I'm going to give them a call tomorrow. SOB fab is a great shop. I like all his work. When I get a 2nd gen I want to get his bumpers. His shop is about 2.5 hours from me. I'm located just south of Albuquerque. Thanks for the recommendation.
    des2mtn[QUOTED] likes this.
  16. Jun 5, 2024 at 9:13 PM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Thanks for the tag!
    Dom at AVS does some killer work and his fabricator is great at what he does. They should be able to get your stuff done no problem.
  17. Jun 5, 2024 at 9:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Watching this thread to see what it do
    shifty` likes this.
  18. Jun 5, 2024 at 9:22 PM
    bmf4069 Captain wtf
    In reality, mine was just a pain cause I couldn't get my UBJ to pop out, no matter how hard I hit it with my purse. I had to use a ball joint press in a really awkward way to pop it out.
  19. Jun 5, 2024 at 9:32 PM
    AmericanKing06
    New Mexico
    Ill be removing mine this weekend. I'm installing JBA UCA. I hope I don't have that same problem. Might have to tape my knuckles now.
  20. Jun 5, 2024 at 9:42 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I’ve found that for myself, dust shields haven’t ever been critical on any of my builds. I also removed the dust shields from my tundra when i pressed in new bearing. It also makes it MUCH easier to hose off any mud off the brakes.
    I thought about welding on spindle gussets to my spindles when i had them disassembled. I did a lot of internet research beforehand, and found out that it COMPLETELY changes the dynamics of installing the upper ball joint when there’s a spindle gusset in the way. So i passed on installing them. I feel as though i made the correct choice for my truck. I have no problems if anyone else choses to go the opposite route for their build.
  21. Jun 20, 2024 at 4:52 AM
    AmericanKing06
    New Mexico
    Looks like Fr33 recently changed their prices. $750 for spindle rebuild, was $700. Weld on gussets $200, was $150.
    With their new prices it would cost me $1,366.36 for a complete rebuild and gussets. That includes their $300 core charge. $1066.36 after core refund that doesn't include core shipping.
    Sourcing parts my self with Koyo bearing, Dorman hub assembly and having AVS install and weld on gussets will have me at $719.47.
    Ill save at least $350 having my local off-road shop do the work. No brainer. Go local!! Support Local!
  22. Jul 11, 2024 at 1:51 PM
    02wheeler
    02wheeler New Member
    2002 Tundra
    I have the Fr33lance Spindles. 100% worth every penny. I can fab and own a 20 ton press but opted to buy complete spindles. The hassle of doing it all and possibly jacking up the bearing wasn't worth the extra couple hundred. Professional shops often have a hard time pressing those bearings correctly so this was a no brainer. I got them when they were $700 but that was before they started media blasting and changed up their paint. I would have paid an extra $50 for that service. If you're paying a shop to weld the gussets and do the press work you're not hardly saving anything and still run the risk of them messing it up. Shops around me would be in the $100-150 range for welding and the same goes for press.
  23. Feb 22, 2025 at 4:17 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
