Partial cab power
Discussion in '2nd Gen Tundras (2007-2013)' started by Mrxcitable, May 23, 2024.
  1. May 23, 2024 at 3:15 PM
    Mrxcitable
    Mrxcitable [OP] New Member
    Greg
    Bronze 2012 SR5
    Trying to figure out what fuses could have been blown by my battery clamp broke and the positive the shorted out the cam shift position sensor. Replaced the sensor which got rid of the code but now still have no traction control, dome light, door locks only work while running or shortly after turning off ignition
  2. Jun 3, 2024 at 6:42 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Going to have to test most of your Relays. Look up the wiring diagram on this site and trace these wires to what relay you may need to test. Worst care it may be the body ECU, but possibly a bad ground somewhere that will need to be replaced. A rodent probably got the right wire that shorted out your Camshaft position sensor, you may also need to check all your wiring.
  3. Jun 4, 2024 at 3:32 AM
    Mrxcitable
    Greg
    Bronze 2012 SR5
    Thanks Black Demon, it wasn't a rodent, my battery support broke, the battery slid and the cable touched the manifold and shorted it out
  4. Jun 4, 2024 at 8:18 AM
    blackdemon_tt
    Damn, my battery has slid out as well, has not gotten that far though. I did snap the fender ground wire, which I had to Mickey Mouse back on the ground side. You will have to check those big square power fuses and relays for the short.
  5. Jun 4, 2024 at 8:51 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    2mchfun likes this.
  6. Jun 4, 2024 at 9:02 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Fuses to check, all of them.:eek2:
    I'd start with the dome fuse and the ECU-B1
    2mchfun likes this.
  7. Jun 4, 2024 at 10:12 AM
    2mchfun
    Battery hot to ground can easily turn into a fire. First priority, get that sucker anchored down.
