Power locks and windows not working
Discussion in 'General Tundra Discussion' started by Whitey55, Apr 4, 2024.
  1. Apr 4, 2024 at 9:30 AM
    Whitey55
    Whitey55 [OP] New Member
    Glenn McGee
    2021 Platinum tundra
    Good afternoon I have two Rcsb tundras one is parts the other is the drive both are 5.7 driver is 4x4 parts truck is 2wd. The parts truck has power windows and locks. I put those doors on the drivable truck and plugged all connections in, the windows and locks aren’t working. All fuses are good. Can someone tell me if I’m missing a relay or something else. Thank you in advance
  2. Jun 3, 2024 at 10:11 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably need the body ECU to come over as well. If your running RCSB was manual windows, you may need to verify how these things work or routed wiring wise.
