  1. Jun 1, 2024 at 7:19 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    That jerk! I feel your pain. At least they left enough wire to fix it and didn’t cut right behind the connector.
    Voss and 455h0le_dachshund like this.
  2. Jun 1, 2024 at 8:56 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    basils replied to a comment asking about price, they said $20k out the door for that setup.
    also, I should not have gone onto solo motorsports site and definitely shouldn’t have clicked on their mid travel setup. I do not need that in the slightest but damn I want it
  3. Jun 1, 2024 at 9:21 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I should have know, the old head unit wires were butchered also. No oem harness, wires cut and spliced with wire nuts. But I bought an oem harness and brought it back to life
  4. Jun 1, 2024 at 9:41 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Where did you find an oem harness? I’m looking for an oem radio connector and amp connector so I can fix mine.
  5. Jun 1, 2024 at 10:26 AM
    I hope the owner of that truck is smart enough to fully insure that truck, including the custom equipment.
    KTM_AJ421[QUOTED] and BroHon like this.
  6. Jun 1, 2024 at 10:30 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I bought this, to bring it back to oem. The first review on the product is someone with a 1st doing the same thing
    https://www.amazon.com/dp/B00029X1KA
    Then this to connect to that and the new radio
    https://www.amazon.com/dp/B0002BEQJ8
  7. Jun 1, 2024 at 10:35 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Thanks. I don’t think those work with mine. I have different amp and the stereo connector is different.
  8. Jun 1, 2024 at 12:40 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Today I undertook the pleasant job of replacing the spare tire lift unit. I used an angle grinder to cut off the olds nuts and used SS thru bolts and nuts with the new unit. Next up, replace the rear bumper.
    oscardog86, bmf4069, shifty` and 6 others like this.
  9. Jun 1, 2024 at 12:42 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    also cleaned the throttle body and MAF. And now at the slow speeds, coming to a stop it feels like my truck is heel-toe shifting. Lol will probably disconnect the battery and let the bitch relearn shit. The throttle body was DIRTYY, while the maf was basically pristine.
    oscardog86, bmf4069, shifty` and 4 others like this.
  10. Jun 1, 2024 at 1:23 PM
    Never heard of that oil. I wonder how you'll know if it "works".
    jerryallday likes this.
  11. Jun 1, 2024 at 1:26 PM
    FishNinja
    Lee
    06DC2wd
    whether or not my engine grenades itself or not. Lol
    I've actually been putting my engine through some seafoam treatments. And I've just been keeping tabs on my engine oil clarity. Truthfully. I'll probably run this just this once to help "clean things up" and go back to my normal "high mileage"
  12. Jun 1, 2024 at 2:12 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    @shifty` can I get your help on some wiring? I think you have the Alpine ILX470 right? I ended up having to cut out my connector to the amp since the previous owner fucked it all up. I'm installing the same stereo and curios how yours is wired. I have some wires from the factory side that don't correspond to the harness from Crutchfield. I'm wondering if you have the same ones on your AC and have thoughts on what I do with them?
    I have 2 solid brown wires and 2 red and black wires with nothing on the other side of the connector
  13. Jun 1, 2024 at 2:40 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Y'all remember that fantastic brand of spray paint that I used. That covered like ass.? Well I just got home from work I started sanding down the plate again so I can repaint it and it's still gummy underneath the surface after 6 days of drying time and 3/4 of the first day of it being in the sun after it was painted.
    But the resand is done with 400 grit and we're about to move on to a thousand.
    oscardog86 and The Black Mamba like this.
  14. Jun 1, 2024 at 2:49 PM
    VR6T
    1000 wet done
  15. Jun 1, 2024 at 3:05 PM
    VR6T
    And they were out of black so what ever MF Gray is .... @Mr.bee you know tractors, MF?
  16. Jun 1, 2024 at 3:10 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Massey Ferguson
  17. Jun 1, 2024 at 3:11 PM
    VR6T
    This is the exact thought that went through my head when I read it and I was like m************ Gray hell yeah
  18. Jun 1, 2024 at 3:11 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I think you know what it stands for mang.
  19. Jun 1, 2024 at 3:12 PM
    artsr2002
    'Yonder
    LMAO great minds think alike!
    VR6T likes this.
  20. Jun 1, 2024 at 3:16 PM
    Dude, are you looking for a mirror finish? 1000 grit, really?
  21. Jun 1, 2024 at 3:18 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Noted. When its time to do my brake calipers, VCs, and intake manifold, MF grey is the ticket.
    oscardog86, bmf4069 and VR6T like this.
  22. Jun 1, 2024 at 3:23 PM
    artsr2002
    'Yonder
    Kind of what I was thinking. I mean small rocks and pebbles are gonna hit that thing all the time.
  23. Jun 1, 2024 at 3:26 PM
    VR6T
    I was only going to 400 dry tack off it and then wet sand it with 400. But even after 6 days of curing spending more than half a day in the sun Monday it was still tacky underneath the surface. So I alcoholed it down and tac cloth the s*** out of it, then wet sanded it a 1,000 and then dry sanded it at 1,000. Had to get to a good bonding surface.
    BroHon and Jack McCarthy[QUOTED] like this.
  24. Jun 1, 2024 at 3:27 PM
    VR6T
    Well the paint is not going to adhere and cure if I sand only into the still tachy portion of the s*** paint. I had to sand through it to get to a dry surface so I could apply the paint. I'm not looking for a perfect finish I understand it's a skid plate it's going to get dinged up, however I would like the paint to cure hard
    BroHon likes this.
  25. Jun 1, 2024 at 3:29 PM
    Truthfully, if I get another skid plate, it’s getting coated in Line-X for durability. But that only because I deal with salt/rocks hitting it.
  26. Jun 1, 2024 at 3:29 PM
    artsr2002
    'Yonder
    Understood.
  27. Jun 1, 2024 at 3:29 PM
    VR6T
    Tractor supply has a color very similar to the Macy Ferguson Gray in brake caliper paint enamel. It was on the shelf in both spray can and in quart jars
  28. Jun 1, 2024 at 4:00 PM
    VR6T
    2nd coat done. 60 minutes dry time then off the the garage to cure for a few days. Then that sweet ass decal is going on.
  29. Jun 1, 2024 at 4:20 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    MF grey must be the new ODgreen. 1000 grit??? haha getting serious :D
    I'm just jelly cause I don't even have a skidplate
    The Black Mamba likes this.
  30. Jun 1, 2024 at 4:30 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I did some painting and sanding too. Not to the same detail as V6VW because nagging kids and wife (I do love them though). Anyway, Black is the new chrome. Cleaned and then sanded the chrome with 120. Applied 3 coats of self etching primer and 2 base coats of gloss black.
    upload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpgupload_2024-6-1_18-27-11.jpg
    JasonC., Tlar25, oscardog86 and 22 others like this.
