Kill switch on fuel pump
Discussion in '3rd Gen Tundras (2022+)' started by andille, Nov 17, 2023.
  1. Nov 17, 2023 at 7:15 PM
    andille
    andille [OP] New Member
    Canada
    Hello everyone,
    Is any of you as ever install a kill switch on a New gen of tundra, i receive my 2024 and i want to do that but i could not found any diagram yiet, is anyone as an idea, on witch relay do i have to connect this?
    If you have any other idea let me know.
    Anyone as an idea?
    thanks in advance
  2. Jun 1, 2024 at 8:33 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
  3. Jun 1, 2024 at 3:41 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Great idea.
    My approach will be to let the crooks steal the truck and as they are getting away, the engine debris will stop them in their tracks and the cops will grab them. ;)
    I can see the Tundra coming off the "desired truck to be stolen" list after a few gangs get busted while running away from the bricked Tundras.
    Just kidding, I really don't think that will happen...
    mayan and Black widow TRD like this.
  4. Jun 5, 2024 at 8:25 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    I wonder if you could replace the toggle with a push button to fit in one of the factory button spots so it is inconspicuous? Might be a sleek unobtrusive set up. I dont know if it would be compatible with the type of toggle they say you need?
  5. Jun 5, 2024 at 8:53 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    You could use one of those push button switches from many suppliers that fit into the squares in the panel left of the steering wheel. They fit and blend in very well. I think you could also get one without any picture on the front. I have one for my lightbar and it was pretty simple to install.
