Lookin’ for a new car jack
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, Feb 23, 2024.
  1. Feb 23, 2024 at 6:25 AM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    What’s the max lift height that I need if I have 18s on my truck?
    I want to be able to lift the truck if without worrying if it will be high enough
  2. Feb 23, 2024 at 6:40 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Most 3 ton floor jack provide a 18-20 inches of lift which should be sufficient for your purposes as long as you don't have a lift and/or larger tires. If you do plan on lifting though, they do make "long reach" jacks and off road jacks that lift significantly higher for lifted vehicles.
    TundraMidwesterner likes this.
  3. Feb 23, 2024 at 6:48 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    If you are ok with Harbor Freight, I have the long reach low profile 3 ton daytona jack and it works great. Its on sale right now.
  4. Feb 23, 2024 at 6:49 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Just need blocks.
  5. Feb 23, 2024 at 7:42 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    I second harbor freight, I had a low profile Pittsburgh brand jack for years that worked great until I lifted my truck. Then I switched to their badlands offroad jack which is also awesome.
  6. Feb 23, 2024 at 10:28 AM
    clarkritchie
    clarkritchie New Member
    I, too, reluctantly got the Harbor Freight one (based on a lot of good reviews here and elsewhere) and have to agree, it has been solid.
    TundraMidwesterner and Nbab23 like this.
  7. Feb 23, 2024 at 10:40 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Also have a HF floor jack, works OK for my needs..
  8. Feb 23, 2024 at 7:03 PM
    pg_osborne89
    pg_osborne89 New Member
    I will advocate for the Daytona floor jack. Has raised anything from a Corolla to my Tundra no problem. I do nothing but abuse it.
    Your question is better asked with tire size as opposed to rim size. I’ll get back once I upgrade my tire from stock to 34s.
  9. Feb 23, 2024 at 7:26 PM
    HairyFishies
    HairyFishies Somewhat new member
    Andy
    Central MN
    2016 MGM PRO
    295/70R18 Falken Wildpeak R/T01
    Another Daytona 3ton low pro owner here. For the price, can't beat it. HF has a pretty cool purple one now too
  10. Feb 24, 2024 at 6:43 AM
    yakeng
    yakeng 3URFE Apologist
    I use the Daytona low profile long reach from HF, I did not reluctantly buy it and used a 25% off coupon I had. It is a superb floor jack.
    Henry1jg and PolishedTRD like this.
  11. Feb 24, 2024 at 6:46 AM
    With 34's and a 4/2 lift, I have to use the Badlands 3 ton offroad jack. My Craftsman wouldn't cut it.
  12. Feb 24, 2024 at 7:07 AM
    windblown101
    windblown101 New Member
    2019 CrewMax Limited
    Depends on where you want to lift from and what you're trying to do. Plus as another poster mentioned the tire size is more telling than the wheel size.
    If you are lifting from under the rear axle or under the front LCA to get a tire off the ground it doesn't take much lift. If you want to lift from the frame to get the suspension fully extended and wheel(s)s off the ground you are talking a bunch more lift. My HF Daytona 3 ton jack plate is 20" off the floor when fully extended. It will lift the tires off the ground when placed under the rear diff or under the outer end of an LCA but it won't lift the wheels off the ground from a frame point without the use of blocks. Most jacks won't.
  13. Feb 24, 2024 at 7:28 AM
    The Badlands 3 ton offroad will extend to 29 inches.
  14. Feb 24, 2024 at 8:29 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Terrifying lol
    caboj and BravoDeltaRomeo like this.
  15. Feb 24, 2024 at 8:49 AM
    2mchfun
    ATV25 likes this.
  16. Feb 24, 2024 at 7:17 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    I'll jump in on the HF Daytona floor jack. I have a low pro, long reach, 3 ton. I also have the cross beam. That thing does amazing work in my garage. Love it!
    Not my pic, but so you get the gist.
  17. Feb 24, 2024 at 8:12 PM
    fakehatch
    fakehatch New Member
    Rasdaniel
    2021 Toyota Tundra Platinum
    Level-CAI
    Damn, the 3 ton, low profile, super duty is $289 vs the Badlands at $319 in my neck of the woods.
    Somebody send me a coupon!
  18. Mar 13, 2024 at 11:23 AM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    Would that cross beam attachment work on the frame rails for tire rotations?
  19. May 30, 2024 at 8:19 PM
    brigand80
    brigand80 New Member
    Roman
    2017 Limited CM MGM 2WD
    Its Always A Work In Progress...Because Its A Labor of Love!! - aFe Pro Dry Filter + TRD Intake Flow Accelerator + Carbon Filter Delete - nFab Podium Steps - TRD Rear Sway Bar - TRD Pro Grill - Color Matched Hood Bulge, Front Bumper End Caps, Mirror Caps, Door Handles - Nightshade "Limited' Badges & Others De-badged - NSV LED Lightbar - Desert Eagle Offroad Catalytic Skid Plate - Craven Speed Untenna - Diaz Fabrication TEQ Trailer Hitch Cover - Klearz 3rd Brake Light Smoked Lens - Winjet Renegades Smoked Tail Lights - Headlight Revolution GTR Lighting LED Bulbs - Morimoto 4 Banger HXB LED Fog Lights (White) - XD 847 Outbreak 18x9 +12 5x150 - Gorilla Black Spline ET Lugs - AJT TRD Key Fob + Interior Chrome Delete Kit - TRD Shift Knob (Black) - JimmyRigged ToYoda Steering Wheel Emblem Overlay - JRT Tech 12 Front Dash JL Audio Speakers - K&N Cabin Filter - Chalk Bag Mod - Weather Tech Mats - Ceramic Window Tint
    For those of us waiting, Badlands 3 Ton Offroad Jack going on sale starting next week (for Harbor Freight ITC members) at its lowest price ↓
    grant.ducckk likes this.
