In need of 1-1/2 inch rear lift advice
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, May 28, 2024.
  1. May 28, 2024 at 10:28 AM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    After reading the forums my head is spinning from all of the different and often contradictory opinions
    I'm in the process of raising my bilstein 5100's with 2883's to the second clip for 1&1/2-2" lift from factory height, at least that's what I believe I was told for my DC.
    when I installed the 5100s I went with a 1 inch block in the rear temporarily until I knew for certain how much I would lift the front. So now it's time to make a decision on the rear leaf springs. AAL or some variation or completely replace all springs. Honestly, the prices for the full replace were a bit steep for me at about $1400 or more.
    I first thought of getting the icon AAL's from 1st gen offroad. But there seems to be quite a few that were very negative about that option
    @FirstGenVol @shifty` I know you guys and many others went through this on your bestGEN's. But I appreciate input from anyone with real world experience
    I am after about 1-1/2" of rear lift to keep most of the rake. I may tow a relatively small travel trailer in the future (3800-4300lbs). Otherwise, I don't haul but around 400-800 pounds (guessing) in the rear on a few trips I make each year but most of the time just street with no load.
  2. May 28, 2024 at 11:13 AM
    You are correct about avoiding add-a-leafs. It's a waste of money at this point and you likely wouldn't get much lift. There are replacement leaf pack options that are substantially less than that.
    @shifty` can probably name the leaf pack options from memory but I know there are ones for closer to $500.
  3. May 28, 2024 at 11:45 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I went icon AAL, 4 years ago it did its job but now I am looking to upgrade and change the entire leaf pack the oem springs have done its job. Looking to do a Deaver pack.
    when I lifted it originally I had little to no knowledge or money and just did what everyone on YouTube was doing.
    I don’t tow anything. I just have a camper shell with a box system and a full size spare
    455h0le_dachshund and Weagle[OP] like this.
  4. May 28, 2024 at 12:14 PM
    Get the ATS HD springs. Link in my signature below. You will get likely 1.5” lift out of them. Should be less than $600 shipped for anyone in the CONUS, I paid like $40 or something. Skip AAL, but if you do want to go that route, avoid ICON. You’ll only get 3/4” without the overload, and if you leave in the overload you get 1.25” but it’s risky because of where the rivers make contact. Tons of people running these, average height was 1.5 - 1.75” lift regardless cab type. Really bolsters things up in the back. Jump on your jumper before and after, you’ll see the difference immediately in how they function.
  5. May 28, 2024 at 2:17 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Wheeler's Offroad AAL and never look back. Best bang for your buck. Will achieve your desired 1.5" and will be stout.
    Install with the overload for 2" or without for 1.5" and more flex.
  6. May 29, 2024 at 6:38 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    See if RAS is available for your year, it is for the newer leaf spring trucks. Adds 1-1.5 lift depending on tension, helps with loads, sag and handling and does not negatively impact the ride like an add a leaf. Activesuspension.com
    I run the HD version on my 2016 and it has been excellent.
    Weagle[OP] likes this.
  7. May 29, 2024 at 7:14 AM
    Weagle
    Prattville, AL
    at that price that is definitely the solution I prefer
    By HD I'm assuming they're a little more firm or study than stock in addition to giving a bit of a lift. I believe I recall someone that went the AAL path saying it helped tremendously or resolved the "bump" at a stop from the slip yoke/leaf spring issue. Is that a problem on the AC and if so, did it Help yours or had you already resolved it by other means?
  8. May 29, 2024 at 7:15 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Go with the ATS HD. They gave my DC 1.5" in rear with canopy.
  9. May 29, 2024 at 7:19 AM
    Weagle
    Prattville, AL
    That's the way I'm going. Even though shipping is $100 for me it's still about $600
    looks like it does not include U-bolts, etc. so still got a check in to see what else I need. that might run the price up a bit
  10. May 29, 2024 at 7:21 AM
    noahrexion
    Washington
    2005 4WD DC
    I put 6125 in front after these pics - but these give nice idea. They ride great after a year. Love em and would do it again.
    Weagle[OP], 87warrior and des2mtn like this.
  11. May 29, 2024 at 9:05 AM
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    upload_2024-5-29_9-3-31.jpg I was thinking about getting this ATS heavy duty kit that has everything for $634.95 part number BT90221HCK
  12. May 29, 2024 at 9:17 AM
    That’s a good deal overall, I was just going to tell @Weagle that….
    … they definitely sell pretty stout bolts suitable for their spring kits.
    Bump/thunk at stop for 4WD is typically lack of greasing the driveline properly, specifically the slip yoke. For 2WD it’s often cracked trans crossmember or missing trans mount bolts (the 4 hidden bolts up under the crossmember). In any truck, it can also be a few things, not limited to bad u-joints.
  13. May 29, 2024 at 2:11 PM
    Weagle
    Prattville, AL
    Bump from rear was a problem for me from the factory. A friend who bought a double cab before me warned about it because his had it too, so sounds like none of those problems you mentioned
    The other thump I was talking about in other threads recently was different. It was while you're moving usually going above 50, and you let off the gas for a few seconds then got on the gas again.
    That started about 40,000 miles ago and I've gotten the run around about it - blaming it on all the miles on the drive train. Right
    I believe that latter issue is gonna be the carrier bearing and extremely poor workmanship with the U joints because I just found out from the machine shop I have to have my entire driveshaft replaced. They cannot even put new U joints in it because it was mangled so badly from the previous shop.
  14. May 29, 2024 at 3:29 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Ouch!
    Can you get a junkyard driveshaft and have it rebuilt?
    Weagle[QUOTED][OP] likes this.
  15. May 29, 2024 at 3:32 PM
    Weagle
    Prattville, AL
    I'm researching all of my options now. I read a few threads On here where people were recommending going to a heavy truck shop and having them build an aluminum one piece drive shaft
    It appears Dana Spicer is no longer making our driveshaft which would've been my first choice.
    Since I am replacing all three U joints and the carrier bearing anyway if I could find a good quality fully assembled new or rebuilt one that might be my choice at present unless I find better information in this forum
  16. May 29, 2024 at 3:39 PM
    1794TX
    Steven
    N.TX
    '20 1794
    +1 on the RAS
  17. May 29, 2024 at 5:34 PM
    www.car-part.com
    Go used bro!
  18. May 30, 2024 at 1:16 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I think I may have asked this before but I don't remember. Looking at the ATS leafs. I'm looking at the left side for both RWD and 4WD and the dimensions are all the same as far as long and short end lengths as well as width. They are both 1500/lbs per. The 4wd versions are about $40 cheaper per side which would almost cover their shipping cost. Can I put the 4WD leaves on my RWD DC? I don't haul or carry much of anything and I def don't need the HD leaves. Thanks. Just trying to save a buck here.
  19. May 30, 2024 at 1:53 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Put the Wheelers 1.5" AAL on years ago and leveled it with 2.5" up front.
  20. May 30, 2024 at 2:01 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've run it on four different Toyotas and can't find anything to complain about em. Great company and great product. Their AALs are 1mm thicker metal per leaf than the competition's. That's what makes em so stout compared to the icon progressive AAL and a great option for anyone looking to gain 1.5"-2" without having to resort to cheap lift blocks, single AALs, or the more expensive option of new leaf springs. It's the perfect middle of the road option for the thrifty truck owner.
  21. May 30, 2024 at 9:07 AM
    Weagle
    Prattville, AL
    Do you happen to know the driveshaft diameter? I've searched and searched, but can't find it
    I found one from a driveshaft manufacturer that has been around since 1981 and uses spicer U joints with a three-year unlimited mile warranty. The price with free shipping and warranty make it an attractive option since it has three new U-joints and the carrier bearing.
    The diameter is only 3 1/2 inches. I'm pretty sure mine is larger. I know the wall diameter is a factor as well. They assured me the way it is built makes it at least as strong as the OEM. But they can say a lot of things doesn't make it true
  22. May 30, 2024 at 12:39 PM
    Call them and ask. They’re super helpful and will steer you right. They want you to be happy and aren’t going to jeopardize that over $40, $80, $100.
    I can’t say, not near the truck to measure mine. Gripwise, I can’t fit my hand all the way around it to touch my middle finger to thumb so at least 3.5”-4”.
    If it were me, I’d grab a donor off same year/cab and drive type, and carry that f’er into a drivetrain shop to balance and install if needed. But I’d personally update all the u-joints while I had it out. And probably replace center support bearing. Yeah I’d be in it for several hundred dollars at that point but I also wouldn’t need to touch it for another 10+ years so it’s worth it.
  23. May 30, 2024 at 12:47 PM
    Weagle
    Prattville, AL
    I was already replacing the carrier bearing, so I had also told the machine shop to also put on 3 new Spicer U joints
    can't find a used driveshaft nearby at present
    artsr2002 and shifty`[QUOTED] like this.
  24. May 30, 2024 at 3:53 PM
    artsr2002
    'Yonder
    General Spring only lists springs for 4x4 models so I asked if they would work on my RWD. Just posting for additional info.
  25. May 30, 2024 at 3:53 PM
    artsr2002
    'Yonder
    Excellent choice. I did the same when I replaced my carrier bearing.
  26. Jun 1, 2024 at 7:55 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Depending on how your springs are holding up, by checking your current measurements, the Deaver AAL might be an option. I used that on my AC and it gave I think 3.5/4 inches of lift unloaded. It also handled weight pretty well; which is something I haven’t heard about Deaver.
