06 Tundra driveshaft & steering rack ??
Discussion in '1st Gen Tundras (2000-2006)' started by ps8820, Mar 28, 2024.
  1. Apr 6, 2024 at 3:12 PM
    If you have a 4-pin, you don't have TO.
    If you have an OEM 7-pin and factory receiver, you likely have TO.
  2. Apr 6, 2024 at 3:27 PM
    ps8820
    ps8820 [OP] New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
    Fair enough.
    But what about the trans coolers:
    IE: Is there only one Trans Cooler spec'd for the 2WD v8 drive-train whether TO package or not?
    Or, is there a HD Trans Cooler for the 'TO package' but others just recieve a standard duty unit?
    Almost sure this will be booted to a new thread.
  3. Apr 6, 2024 at 4:18 PM
    Not sure. Check the megathread, there’s links to feature/catalogs near the top @BubbaW was kind enough to pull together, and you may find that info in there.
  4. Apr 7, 2024 at 10:54 AM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    I have the same sticker on my drive shaft and I doubt it's ever been replaced.
  5. May 29, 2024 at 3:02 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    what's the best alternative since the Dana Spicer part has been discontinued?
    I've got to have a new driveshaft, carrier bearing, and U-joints.
