Front amber lamps (DRL portion) both out
Discussion in '2.5 Gen Tundras (2014-2021)' started by DaveInTexas, May 26, 2024.
  1. May 26, 2024 at 3:25 PM
    DaveInTexas
    DaveInTexas [OP] New Member
    Dave
    West Texas
    2020 Tundra SR5 + 2003 Tundra SR5
    The 2020 has a Ranch Hand front brushguard/bumper
    I'll modify the title once I learn the name of these two bulbs.
    They are amber, with two filaments in each bulb.
    They are mounted in the headlamp lens fixtures, and are inboard of each headlamp.
    The filaments look fine and the connections on them ohm out ok.
    I cannot seem to get 12v at the connectors although there seems to be 5 or 6 brass colored connections in each! I *think* they are supposed to come on at the first detent in the steering column headlamp rotary switch?
    Anyway, could not find the fuse. Need the name of the lamp circuit.
    Photos immediately.
  2. May 26, 2024 at 3:28 PM
    DaveInTexas
    Dave
    West Texas
  3. May 26, 2024 at 3:30 PM
    DaveInTexas
    Dave
    West Texas
  4. May 26, 2024 at 5:09 PM
    2mchfun
    Fuse up under dash above parking brake, way up in there.
  5. May 26, 2024 at 5:12 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Turn signals? Probably come on with the parking lights also.
  6. May 26, 2024 at 5:15 PM
    2mchfun
    Curious, did you buy a flood damaged truck at a bargain price?
  7. May 26, 2024 at 5:20 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Looks like you have halogen headlights..
    Bulb is 4157NAK (amber)
    Those are DRL/turn signals.
    They are bright with the headlight switched off as DRLs and flash off as turn signals.
    Then with the headlight switch on, they stay dim, but flash bright with the turn signals.
    It's odd that they both went out at the same time.
    If the rear turn signals work the front should be working.
    Same circuit same fuse.
    DRLs are a bit different.
    There is a connector between the bulb socket and the wiring harness.
    Maybe unplug those and make sure everything is clean.
    You can find wiring diagrams here.
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum (tundras.com)
    bulldog93 and 2mchfun like this.
  8. May 26, 2024 at 9:18 PM
    d33pt
    d33pt New Member
    One time mine didn't work and I just needed to plug it in tighter. When it didn't work, my signals blinked faster.
  9. May 28, 2024 at 10:54 AM
    DaveInTexas
    Dave
    West Texas
    More info:
    The turn signal component is fine.
    The DRL portion does not have power.
    (the bulbs both test ok, both filaments)
    Still don't see the fuse.
    May have overlooked it; multitasking all weekend
  10. May 28, 2024 at 11:19 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    Is the DRL turned on your turn signal stalk?
  11. May 28, 2024 at 11:45 AM
    DaveInTexas
    Dave
    West Texas
    Good first place to start but yes, that is the issue - switch on, no power.
  12. May 28, 2024 at 2:53 PM
    yakeng
    yakeng 3URFE Apologist
    Not to state the obvious, but did you confirm yours doesn't fall into the turn signal recall, it affects 2018-2020?
  13. May 28, 2024 at 3:43 PM
    DaveInTexas
    Dave
    West Texas
    Did not receive a recall notice; dealers search did not find one. Link?
    (turn signals are working, if’n that matters)
  14. May 28, 2024 at 4:02 PM
    DaveInTexas
    Dave
    West Texas
    Would that explain how 4/5 issues were bad bulbs so far? I can see two bulbs with broken elements fixed with replacements, the bed LEDs test bad.
    <10?mi off dealer lot in Midland Tx, Fall 2020.
    Zero signs of corrosion or water ingress on the frame or interior.
    2mchfun[QUOTED] likes this.
  15. May 28, 2024 at 4:11 PM
    AZBoatHauler
    So.Arizona
    I had those bulbs seem to go out every year or 18 months before I upgraded to the LEDs that don’t use them for DRL.
    DaveInTexas[OP] and 2mchfun like this.
  16. May 28, 2024 at 4:12 PM
    2mchfun
    Just seems like excessive electrical or lighting issues to me. How many miles are on the truck?
  17. May 28, 2024 at 6:15 PM
    DaveInTexas
    Dave
    West Texas
  18. May 29, 2024 at 5:15 AM
    yakeng
    Put your VIN in here and it will notify you of any open recalls: NHTSA.gov/Recalls
  19. May 29, 2024 at 5:46 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    IIRC the turn signal recall was based on faulty wiring that caused the turn signals to be dimmer than necessary to the point of unsafe. I don't think it was an issue of them NOT working.
  20. May 29, 2024 at 7:16 AM
    DaveInTexas
    Dave
    West Texas
    That’s cool, thanks!
  21. May 29, 2024 at 7:16 AM
    DaveInTexas
    Dave
    West Texas
    And, in fact, my turn signals are working.
    It’s the other filament… we think the DRLs that are dead.
    Pillslinger[QUOTED] likes this.
  22. May 29, 2024 at 7:49 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I haven't read through everything in the thread the last couple of days, but just a couple of things.
    There is a DRL relay as well as a DRL fuse.
    It reads LED DRL, but it seems to also feed halogen DRLs
  23. May 29, 2024 at 1:40 PM
    Pillslinger
    Rollin
    SWMO
    Yep, I didnt read clearly enough. Man I wish you the best here. Electrical gremlins are my least favorite things to chase. Hopefully the wiring diagrams and info posted lead you to the answer.
