  1. May 29, 2024 at 11:50 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    ? the airstream? Dunno what it needs yet, but paint wouldnt hurt. Might have to patch or sew some 'tent', effin dave & brent have me looking at timbren axleless axles... call me crazy, but i think longbed tundra bedsides & taillights to make it a little less blocky.
    gotta convert my truck to a 7-pin/4-pin combo, and fit a battery box/extra water tank OR stretch the neck & fit dirtbike ramps.
    whats in the box up front? Too big for a gastank.
  2. May 29, 2024 at 12:39 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    My impromptu homemade drop hitch. I couldn’t find anything with enough drop online, plus i needed something fast, so i fabbed it out of both 2” and 2.5” receiver stock and a random hitch with a 2” ball on it. I only needed it once, otherwise i would have built it stronger and designed it differently. I spent about an hour cutting and gluing it all together with random scrap that i had laying around.
    D1CA81D3-8BF3-4022-84D6-9C13DB2175E5.jpg 4FC6739D-DA8C-4D74-BAF2-F5C05D5C546C.jpg
  3. May 29, 2024 at 12:48 PM
    Id be plowing asphalt in some of the road dips and parking lot entrances with that thing.
  4. May 29, 2024 at 12:53 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  5. May 29, 2024 at 12:56 PM
    I like some tilt on my smaller utility trailer when loading the mower. Flattens the approach angle so I don’t drag the deck. 2” drop works great for that.
    Mr.bee likes this.
  6. May 29, 2024 at 1:04 PM
    +1 vote for timbrens
  7. May 29, 2024 at 1:07 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    +1 for air.
    FrenchToasty and metalpete like this.
  8. May 29, 2024 at 1:18 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Cross Posting with "What have you done to your 1st gen Tundra today?"
    Hey guys, second gen owner here but I have the 4.7L along with the A750F; looking for your knowledge on this transmission... three years ago I had to throw a torque converter in it fur shuddering; all good after that until about half a year ago I started getting ever so slight shudders again, thought it was the tc going out again but I think I've come to the conclusion that its actually the valve body. Had a trouble code pretty much for the last couple months (P2757 with check engine, 4lo flashing, abs light). I was looking at the TransGo shift kit (SK A750-WTA here) but I also priced up a new valve body from Toyota at $977. Shift kit is about $170; from what I've been able to find this transmission has valve body problems? So with that being the case is it even worth messing with the TransGo kit? Could it be another problem like the wiring harness? Should I just get the valve body and call it a day? Or could the fluid just be slightly low throwing the code (it did leak some fluid out months ago through a bolt on the side of the trans, tightened the bolt and filled the trans back up but I suppose it could be slightly off)? Truck is at about 260k miles, I was gonna drain the trans and send the fluid off to Blackstone to get tested but at this point I'll do that once I pull the pan. What would y'all suggest with this transmissions known problems? Thank you
    Edit: Every now and then especially when cold I do get a knocking noise that I haven't been able to narrow down but I believe its coming from the transmission, and sometimes only happens when in reverse and under throttle
  9. May 29, 2024 at 1:18 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    listen pal, everyone has their kink, but that thing is gonna hurt someone!
  10. May 29, 2024 at 1:19 PM
    metalpete
    ID
    My guy, those are some nice looking beads!!
    whodatschrome[QUOTED] likes this.
  11. May 29, 2024 at 1:21 PM
    You beat me to it.
    metalpete[QUOTED] likes this.
  12. May 29, 2024 at 1:21 PM
    Damn dawg that’s some serious bondage hardware you got there bro. I had no idea.
    metalpete likes this.
  13. May 29, 2024 at 1:22 PM
    metalpete
    ID
    Also, @Mr.bee hit me up if you run into issues when you do the 7 way/ 4 way conversion ;). I'm something of a scientist myself.
  14. May 29, 2024 at 2:55 PM
    whodatschrome
    lots of dents
    You think that’s impressive? That’s nothing. I’m down right dangerous with theses beads right here...
  15. May 29, 2024 at 3:00 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    regular stuff just dont hold some folks.
  16. May 29, 2024 at 3:03 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Late response, but I had a 2010 and I liked it pretty well. Didn't love the esthetics of the body style, but liked all the rest. The 5.7 was nice. Even the "access cab" version or whatever its called in that gen was roomy in the back. I drove some 6'0" buddies in the back seat for 3-4 hours no problem. Bed was a good size. Not a bad truck at all.
  17. May 29, 2024 at 3:05 PM
    whodatschrome
    lots of dents
    I fabbed up both a front receiver hitch and that drop hitch in an afternoon. My sister was leaving the next day to head 400 miles south on a road trip. I sent her with a tow bar and tools to pick up a donor 2004 2wd tundra (that has a blown engine) for me. She never mentioned about the drop hitch grinding on the pavement, but then again i didn’t ask if it did or not. I had $0 into both the receiver and hitch, so i didn’t really care if it’s a one time use or not. Who knows, maybe at some point i’ll remodify then again for something else?
    39CB61F3-A57E-4BBB-A78D-D7E9EFB95CA3.jpg 4678219C-985A-4F78-9A7E-563EE8D8E024.jpg
  18. May 29, 2024 at 4:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Safety? OSHA don't work here, boy.
  19. May 29, 2024 at 4:43 PM
    I see nothing wrong with that. Jackstand is there.
  20. May 29, 2024 at 4:47 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It's holding up the step. See how it's bowed up? And that tire is too far back to save your life if the step fails.
  21. May 29, 2024 at 4:50 PM
    I’ve witnessed a kid using a high lift on the same point, he didn’t care for some reason……….. he was also high centered on the only big rock in the center of the trail with plenty of room to go one side or the other
  22. May 29, 2024 at 4:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    When will they learn that running boards and steps and nerf bars aren't rock sliders?
  23. May 29, 2024 at 5:00 PM
    Even the sliders I made for our 4R showed their weakness and I fixed the issue; to long of a span between outer tube braces. But they did their job
  24. May 29, 2024 at 5:01 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah my BFF sliders bow a little when I lift the truck by them. It's because my buddy who welded the sliders forgot the weld in the gussets. I still have em. Eventually I'll get @VR6T to do it for me. Maybe once me and @Mr.bee are ready to tackle the 1" body lift
  25. May 29, 2024 at 6:08 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    What I don't get to do body lift things....... Chopped liver
  26. May 29, 2024 at 6:09 PM
    VR6T
    I will use my nerf bars however I see fit thank you
  27. May 29, 2024 at 6:12 PM
    VR6T
    I'll start ya at 19.50 an hour with welds like that. Barring they pass a bend test lol.
    What says @JakeJake ?
  28. May 29, 2024 at 6:20 PM
    Okay. It looked to me like it was set back to lift the frame point there. Hard to tell.
  29. May 29, 2024 at 6:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Obviously you'll be around for that too. It would be the same days off. I just think B's house is better suited for the job. Plenty of even concrete. Or my house. Unless we did it in your culdesac.
  30. May 29, 2024 at 6:28 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    So here's the thing, every job has its own tolerances. WhoDats slapped that jobbie together in an hour with what he had on hand. 10/10 for getting it done.
    That being said insurance is easily my biggest expense every year (or month) and my policy expressly prohibits only a few things. Aircraft, Amusement rides, Cranes, Nuclear plants, towers greater than 100' in height and at the top of that list is trailer hitches :rofl:
    Sunnier, bmf4069, metalpete and 4 others like this.
