  1. May 28, 2024 at 12:55 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    This also means I know have to re access my engine speeds while driving and redo ument them correctly.
  2. May 28, 2024 at 12:59 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    BroHon, oscardog86 and VR6T like this.
  3. May 28, 2024 at 1:29 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I know I haven’t spent much time on the forum as of late, but holy hot bag of cocaine, how did I not see what you did with them wheels?? Low-pro/flying under the radar has left the building. If I stand on my roof, I could probably see your truck from my house. :boink::rofl:
    ScangaugeII is awesome for this. It’s the reason I’ve always got mine connected and mounted on my dash. Speedo hasn’t been right since a week after I bought the truck and mounted the 35’s. Thru all the gear changes, tires sizes, you can always trust the scangauge. After you set it up correctly of course.
  4. May 28, 2024 at 1:32 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    What's people's opinion on the plastic ears on each side of the skidplate? I sorta like the splash protection, but it feels like they're more trouble than anything. Bolt holes rip, etc, and I swear they catch wind when I'm driving at highway speeds and always have me nervous that I've got a vibration/grumble somewhere in the driveline.
  5. May 28, 2024 at 1:34 PM
    Pretty sure that’s only an earlier model thing.
    JakeJake likes this.
  6. May 28, 2024 at 1:39 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Speaking of gears; unfortunate to report that I ate up another set of gears. Really like them 4.88’s, but gobble gobble. Glad I’ve held onto my stock 3rd member. It’s saved me a couple times now. Before anyone asks if the gears were set up well; since installing the (now compromised) 4.88’s, it’s been a year and a half and about 40k miles, including 2 trips wheeling the shit out of it, and testing the governor daily on the freeway. Never showed any signs leading up to failure and no noise ever until the failure. :notsure:
    Motive gears. Fkn hell.
    455h0le_dachshund and oscardog86 like this.
  7. May 28, 2024 at 1:40 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    How did they fail? Broken pinion? Missing teeth on the ring?
    oscardog86 likes this.
  8. May 28, 2024 at 1:40 PM
    Lame
  9. May 28, 2024 at 1:41 PM
    oscardog86
    oscardog86 New Member
    Southern California
    I forgot mine even came with those! But I got rid of them a long time ago and have a skid row skid plate anyways. Sounds like you just wanna get rid of them too
  10. May 28, 2024 at 1:43 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'll put mine back on if i ever get a stock bumper.
  11. May 28, 2024 at 1:53 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Mine are long gone
  12. May 28, 2024 at 1:55 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    So this local glass place told me I most likely have a rust issue and will have to be down my truck a few days to replace the windshield. I'm just gonna put this off till "fuck knows" when lol at the very least I'm looking at $600 for rust treatment/glass/seals/install and about 2-3 days
    Gonna ride it till it falls off
  13. May 28, 2024 at 1:58 PM
    MT-Tundra
    Montana
    Yeah. Like I said the extra protection is nice, but they seem like more of a hassle than they're worth.
  14. May 28, 2024 at 2:17 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  15. May 28, 2024 at 2:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My 03 had em. One was missing and the other is now hanging because I sold the skid plate
  16. May 28, 2024 at 2:32 PM
    MT-Tundra
    Montana
    The Black Mamba likes this.
  17. May 28, 2024 at 2:33 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Solid pinion spacer or no?
    I been trying to find one for the 03 when I regear to 4.10
  18. May 28, 2024 at 2:54 PM
    They help limit salt intrusion during the winter so they play their part. Your skid plate tells the same story.
  19. May 28, 2024 at 3:36 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Did my passenger side lower ball joint today. Broke the damn tie rod end castle nut and cannot locate a replacement. Could not finish the job today. Will there be any damage if the truck sits a few days on its own weight with the tie rod end disconnected?
  20. May 28, 2024 at 3:38 PM
    MT-Tundra
    Montana
    I had a similar situation. Found nylock nuts that fit to get me through until the castle nut I ordered from Toyota showed up. Can't you just keep it up on jackstands?
    oscardog86 and 455h0le_dachshund like this.
  21. May 28, 2024 at 3:38 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Nah, should be fine.
    KTM_AJ421, BroHon and VR6T like this.
  22. May 28, 2024 at 3:43 PM
    VR6T
    Isn't there a way I can get it recalibrated or do I just have to know my offset which is currently minus 4 off the needle. RPMs are still true tho.
  23. May 28, 2024 at 3:50 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    nah I’m out of town for work working on the side of the road at an Airbnb haha
  24. May 28, 2024 at 4:28 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yellow box.
    Both my trucks have scangauge2. That's the thing you asked me about at your house. I'd possibly be willing to part with one. I been considering buying a new scangauge3
    shifty` and oscardog86 like this.
  25. May 28, 2024 at 4:42 PM
    VR6T
    Yeah but will it recalibrated the "mechanical" speedo
  26. May 28, 2024 at 4:44 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yellow box.
  27. May 28, 2024 at 4:44 PM
    VR6T
    I'll look it up,
  28. May 28, 2024 at 4:55 PM
    Just glue a toothpick offset to the needle by 4 mph so you’ll remember what’s the right number. :rofl:
    #classy
  29. May 28, 2024 at 5:00 PM
    VR6T
    Now this is my kinda fix
  30. May 28, 2024 at 5:02 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Keep it classy, Boston. :hattip:
