2021 TRD Pro engine lower power?
Discussion in '2.5 Gen Tundras (2014-2021)' started by armygreentundra, May 24, 2024.
  1. May 26, 2024 at 5:49 AM
    2mchfun
    An exhaust pressure gauge set can be had for about $50. Simply remove o2 sensor and screw in adapter and the gauge hose. So much better than a SWAG.
  2. May 28, 2024 at 1:39 PM
    armygreentundra
    armygreentundra [OP] LIVIN'
    Desert SW
    2021 TRD Pro MGM
    Dirty Deeds TRD Replacement
    While looking under the hood this weekend I noticed a black 'nipple' that is on the driver side near the fuel rail that looks like it should have a vacuum line or something connected to it. I don't see any unattached lines anywhere obvious but wanted to see if anyone knows if this is supposed to be connected to anything.
    2mchfun likes this.
  3. May 28, 2024 at 1:49 PM
    AZBoatHauler
    So.Arizona
    Pic would be really helpful.
    2mchfun likes this.
  4. May 28, 2024 at 1:51 PM
    2mchfun
    Spray it with a burst of starting fluid while at idle, if it revs higher, you found an open vacuum port.
    bulldog93 likes this.
  5. May 28, 2024 at 2:11 PM
    armygreentundra
    Desert SW
    2021 TRD Pro MGM
    Here's a pic of it.
    bulldog93 and 2mchfun like this.
  6. May 28, 2024 at 2:27 PM
    2mchfun
    Normal
  7. May 28, 2024 at 2:54 PM
    armygreentundra
    Desert SW
    2021 TRD Pro MGM
    Good to know, thank you.
    2mchfun[QUOTED] likes this.
