Fuel pump
Discussion in '1st Gen Tundras (2000-2006)' started by SuperDann, May 28, 2024.
  1. May 28, 2024 at 11:21 AM
    SuperDann
    SuperDann [OP] New Member
    Dann
    2004 Toyota tundra 4-door 4.7 V8
    New fuel pump
    Bought a new fuel tank because it was rusted changed the fuel pump and I still can't get it to start I pulled the fuel pumpReg after I unhook the battery left it off for a few plugged the plug back in with the battery back on and it just turns over it won't start is there any other restart button maybe anybody know
  2. May 28, 2024 at 12:05 PM
    Did you replace it with a genuine Denso pump or parts store pumps? I remember at least two poor, uninformed suckers who didn’t buy Denso brand from a trusted source, opted for store brand instead, and had to rip the tank right back out and replace the pump within hours or days. Starters and fuel pumps are one of those parts where people learn the “shitty side of store brands” the hard way, when they find their partners DOA. It happens. A LOT.
    This is one of those parts where you only use Denso - it’s guaranteed compatible, it’s OEM manufacturer of the original, it will last 4x-5x longer than any store brand but only costs like 1.5x as much.
    Didyou splice any wires to install the pump?
    Did you remove the negative battery cable while installing the pump? If not, did you check all fuses under the hood, and in the in-dash fusebox, make sure you don’t pop anything OR that the part and/or install didn’t pop anything?
    You confirmed power to the relay?
    You confirm power to the pump, or try running a battery to the pump?
  3. May 28, 2024 at 12:16 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Strong battery? Trying to start at full speed?
  4. May 28, 2024 at 12:56 PM
    SuperDann
    Dann
    New fuel pump
    Not sure what type of pump it is I'll have to check that I bought it at Napa strong battery did the thing with the relay fuse I don't know I have to check the power to each end
  5. May 28, 2024 at 1:00 PM
    SuperDann
    Dann
    New fuel pump
    Also I did have to splice wires because the wires they sent me with the fuel pump we're not long enough
  6. May 28, 2024 at 1:04 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    The aftermarket Denso 951-0017 pump has recently been unavailable. Probably a Delphi if from NAPA OR they gave you the pump for a 6 cylinder.
    Dealer pump is $300+ but they hold up.
    Getting close for the need to hoard parts now with so many becoming NLA.
    shifty` likes this.
  7. May 28, 2024 at 1:43 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Oof.
    Oof again.
