Reading trans temps - Questions about model year, device
Discussion in 'General Tundra Discussion' started by SD Surfer, May 24, 2024.
  1. May 24, 2024 at 5:54 PM
    SD Surfer
    SD Surfer [OP] Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    So I recently got the Kenwood DMX1057XR HU with Maestro RR2 installed in my 2019.
    I'm real happy with it, but one of the features/reasons I did it was the ability to monitor ATF temps since I don't have the external trans cooler.
    Sadly, Transmission Fluid Temperature is grayed out in the available gauges and doesn't display anything.
    The stereo shop who did it contacted Maestro and they were told that my 2019 doesn't transmit that data point to the CAN so that feature is unavailable.
    Can those of you who are reading trans temps please respond with:
    1. What year Tundra do you have?
    2. What device(s) you're using to monitor? (HU w/Maestro, Scangauge, OBD module w/App, etc.)
    I don't regret getting the (ridiculously expensive) Kenwood 'cuz it's awesome, but there may be some people who would base their purchasing decision on this knowledge. Might save people some money or buyer's remorse.
    Is anybody getting trans temps on their HU w/Maestro in a 2019?
    bulldog93 likes this.
  2. May 24, 2024 at 6:07 PM
    koditten
    Kirk
    Midland of the Mitten
    My '08 is read via a scan gaugeII.
    I do have the trans cooler package. I do know when programing the SCII, I had to use the x code for a 1999 truck. The '08 code didn't work. I think Toyota has several vendors for the sensors and whatever is in the parts bin is what gets installed.
    I also have a '21 with no trans cooler. I haven't driven it enough or towed with it. Eventually I will want to monitor the vitals, but drive the '08 mostly, so it hasn't been a priority.
    bulldog93 and SD Surfer[OP] like this.
  3. May 26, 2024 at 10:20 AM
    SD Surfer
    Bruce
    So Cal
    Anyone else care to contribute?
  4. May 26, 2024 at 10:30 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I also have the Maestro RR2, but with an Alpine HU. Same results, trans temps are not available selections for the gauges on the HU, but I can read and log them via any other scanner that connects to the same diagnostics CAN bus via OBD2. If it's available via any other tool, it should be available through the Maestro...I would contact their support directly, might be a firmware update that fixes it, or you can submit a feature request.
  5. May 26, 2024 at 10:42 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
  6. May 26, 2024 at 10:49 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    My situation exactly. I'm still under 10k miles on my '21 :anonymous:
  7. May 26, 2024 at 7:53 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    1. 2021
    2. Veepeak bluetooth OBDII scanner paired with OBD Fusion app on my phone (free app, but I paid for the 2021 Toyota/Lexus/Scion pack). This is what my display looks like:
  8. May 26, 2024 at 8:47 PM
    ScottsTundra
    ScottsTundra New Member
    2017 SR5 Crewmax
    Headwaters seat covers, Undercover Flex
    Towing a 2000lb empty utility trailer a week ago doing 80mph with ambient temps around 80ish
    bulldog93 and koditten like this.
  9. May 26, 2024 at 9:10 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I think you should be able to read trans temp. Is the Maestro RR2 plugged into the OBD2 port? There’s a separate harness with only 2 or 3 wires that plugs into the OBD2 port.
    My Dad and I both have Kenwood HUs and RR2s and can read trans temps, only
    difference is his RR2 is plugged into the OBD2 port on his 2010. You don’t need this on 20-21 trucks. You also have to flash the correct model year software onto the RR2.
  10. May 26, 2024 at 9:31 PM
    @AZBoatHauler didnt you have a kenwood?
    but 2006 DC
    SG2 is all I need
    AZBoatHauler likes this.
  11. May 26, 2024 at 10:15 PM
    AZBoatHauler
    So.Arizona
    @SD Surfer - go to the settings menu in the HU then gauges. Select Validate PIDs. You can now see your ATF temp.
  12. May 27, 2024 at 10:22 AM
    SD Surfer
    Bruce
    So Cal
    I've done this multiple times to no avail.
  13. May 27, 2024 at 10:32 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    @Terndrerrr , I very recently learned that the OBD Fushion app works with Carplay. And you can display probably everything to your head unit that you can to your phone, but only in a very simple written line display.
  14. May 27, 2024 at 10:40 AM
    centex
    centex New Member
    I just got a Sony HU with the rr2 and I can’t see the trans temps on it either but my scan gauge can see it. I’ve tried validating PID’s a couple of times as well. Glad I’m not the only one.
  15. May 27, 2024 at 10:40 AM
    2mchfun
    Currently using scan gauge 2. Next is an extra capacity pan from PML and an analog gauge for pan temps. Banks makes a really nice digital unit, but I can't recall the name they label it with.
    Edit: Banks Idash...very cool!
  16. May 27, 2024 at 11:23 AM
    Terndrerrr
    Music City
    6UR-FE
    I scrolled over while driving and saw that yes, it will display through CarPlay, but it was only coolant temp, vehicle speed, and remaining fuel.
    I keep forgetting to mess with it when I’m parked. I’d love for it to display all of the 2021 Toyota PIDs I paid for.
    BillyB[QUOTED] likes this.
  17. May 27, 2024 at 11:52 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    It will. Just have to set it up.
  18. May 27, 2024 at 12:09 PM
    SD Surfer
    Bruce
    So Cal
    So this is interesting... RR2 "taps in" to the harness, whereas the Scangauge (if I'm not mistaken) plugs into the OBD port.
    I wonder if there's any significance to this.
    I think the Maestro can be tapped or plugged into the harness. If so, I wonder if it would read them when plugged in.
  19. May 27, 2024 at 12:12 PM
    centex
    centex New Member
    Mine is plugged in but it’s only 2 wires I think (can’t remember right now).
  20. May 27, 2024 at 12:14 PM
    SD Surfer
    Bruce
    So Cal
    Your what is plugged in, your Maestro? Or Scangauge?
  21. May 27, 2024 at 12:46 PM
    centex
    centex New Member
    Maestro.
  22. May 27, 2024 at 1:27 PM
    Tbrandt
    Tristan
    Kansas City
    You can plug the Maestro RR2 into the OBD2 port, it is shown in the install manual.
  23. May 27, 2024 at 1:33 PM
    SD Surfer
    Bruce
    So Cal
    Well there goes that theory. :(:rofl:
    Yeah, I know you "can", I just meant that most install shops (or at least mine) typically tap into the harness in order to leave the port open.
  24. May 27, 2024 at 1:36 PM
    2mchfun
    A "y" splitter can be used to allow an open port.
  25. May 27, 2024 at 1:59 PM
    Tbrandt
    Tristan
    Kansas City
    Ah, I was wondering if your shop just left that out. Seems like you should be able to see transmission temperature though, I know it works on a 2010 Tundra. It’s probably a software thing with Maestro then.
  26. May 27, 2024 at 4:12 PM
    SD Surfer
    Bruce
    So Cal
    It sounds like it may be a year by year thing.
    If anyone with a 2019 is getting trans temps on a head unit, please chime in!
  27. May 27, 2024 at 6:29 PM
    centex
    centex New Member
    Here’s the response I got from maestro today when I asked.
    Hi,
    You can try going in the radio and validating the PIDs on the vehicle. It'll be in the radio menu, something like this:
    OEM Setup > Maestro Features > Gauges > Validate PIDs.
    If that doesn't light it up, we're not seeing the universal PID on network for Trans Temp and won't be able to display it.
    Thanks,
    Chris LaRoche I Maestro Technical Support
    Automotive Data Solutions Inc.8400 rue BougainvilleMontreal, Quebec H4P 2G1CanadaT514.807.2888
    TF 866.427.2999
  28. May 27, 2024 at 11:54 PM
    SD Surfer
    Bruce
    So Cal
    Yep, that's basically what they told my installer when he called as well. :(
  29. May 28, 2024 at 1:31 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    Here's how the ODB Fushion app displays through Carplay. Of course you can set it up to see many items, these are just the one's I want.
  30. May 28, 2024 at 8:48 AM
    SD Surfer
    Bruce
    So Cal
    This is intriguing... Do you know if there's a similar function in Android Auto?
    How exactly does Carplay get it on the screen?
