Need help with bed light install
Discussion in 'Lighting' started by Jriedy85, May 27, 2024.
  1. May 27, 2024 at 3:38 PM
    Jriedy85
    Jriedy85 [OP] New Member
    Josh
    2022 SR5 Tundra
    I’m installing some Matt gecko LED strips in the bed of my 3rd gen tundra. I installed everything per the instructions. Power is coming from a wire running all the way to the positive terminal on the battery. When I turn on the switch to the lights the lights come on but they are incredibly dim. I thought maybe it was a ground issue. So I moved my ground but the problem persists. Could this just be a loose crimp on a wire? Any help is appreciated.
  2. May 27, 2024 at 3:56 PM
    Jriedy85
    Josh
    2022 SR5 Tundra
    Here is the wiring diagram.
  3. May 27, 2024 at 4:00 PM
    2mchfun
    Is it dark yet?
  4. May 27, 2024 at 4:01 PM
    Jriedy85
    Josh
    2022 SR5 Tundra
    lol not yet. I’m gonna check again when it’s dark out but they were so dim even during the day that they didn’t seem right. I’ll let ya know when it gets dark how they look. Currently they are almost not even visible even with my tonneau cover on.
  5. May 27, 2024 at 4:02 PM
    2mchfun
    Start the truck and they will brighten a little
  6. May 27, 2024 at 4:31 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Mine (Different kind) are very bright without truck running. Just as an FYI
    Have you checked how many volts you have at the end of your + wire?
    Are your LED strips already installed/adhered in the bed? If not, or if you have another 12V power supply, maybe connect power & ground directly to the strips and see if they're any brighter.
    I have a little 12V bench power supply that's pretty handy for stuff like this.
  7. May 27, 2024 at 4:33 PM
    Jriedy85
    Josh
    2022 SR5 Tundra
    I do not have any of these cool tools. And I can’t seem to find my multimeter. Gonna have to make a trip to the store.
  8. May 27, 2024 at 4:45 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    What color did you get?
    The pure white would be the brightest.
    Even during the day, you should see light if you have a bed cover.
    From his website..
    Try sending him PM on the forum or email if you don't find a solution. @mattgecko
    He is great to work with.
  9. May 28, 2024 at 10:03 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Dim lights happens when the ground connection too the truck is bad, try to find a new grounding point.
    1lowlife likes this.
  10. Jun 2, 2024 at 9:18 AM
    Jriedy85
    Josh
    2022 SR5 Tundra
    mine is red and not even close to being this bright. With my tonneau closed during the day I can’t even tell if the LEDs are on. It has to be dark out for me to see the light. I did move the ground once already and have the same results. Will have to move again I suppose.
