Installed a rci skid plate today worth it
Discussion in '3rd Gen Tundras (2022+)' started by Duke_962, Nov 5, 2022.
  1. Jan 26, 2023 at 4:06 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have mine RCI plates downstairs waiting till I am better to go install them! I ordered them last Nov and they shipped a fews days after my order and got them a few days later by Fedex. Overall great experience with RCI.
    Tundrastruck91 likes this.
  2. May 19, 2024 at 12:35 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    When I installed mine I had to push pretty hard on the front part of the skid to get the 2 screws in. Is there supposed to be that much tension to where you have to bend the front end of the skid to get the screws in?
  3. May 19, 2024 at 2:49 PM
    Tom976
    Tom976 New Member
    Tom
    It gives you enough access to change the oil filter and clean things up. No need to remove it at all when doing oil changes.
  4. May 19, 2024 at 3:00 PM
    Duke_962
    Duke_962 [OP] New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Mine went on with no issue but I left all the bolts loose till they were all started. Still the best insurance plan over the carpet from the factory.
  5. May 20, 2024 at 6:00 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Get feeling better ! Yeah, had RCI powder coated Alum skid, trans and cat protection on last Tundra and never a problem with them.
  6. May 26, 2024 at 4:01 PM
    2TunGet1
    For those of you with diff drop spacers - I used the 3 spacers for the middle section of the skid but there is a gap where the front 2 bolts go due to those spacers.
    Are we supposed to install 2 spacers for the front 2 bolts?
  7. May 28, 2024 at 8:05 AM
    CactusTundra
    CactusTundra New Member
    FU
    The spacers go between the frame and the plate most forward bolts. The middle two go into the recess at a slight angle pointing back a little, washer only. It looks like you are using the spacers in the middle recessed spot - wrong spot i think. I used a deep throat socket to hand thread it. Keep everything loose and use a little anti-seize or penetrating oil or something helps everything thread a little better until final torque.
