2019 Tundra Trd Pro Light Bar Question
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bayou Spartan, May 16, 2024.
  1. May 16, 2024 at 7:49 PM
    Bayou Spartan
    Bayou Spartan [OP] New Member
    Black 2019 TRD PRo
    None
    Evening Everybody.
    I am looking to put a light bar inside my hood scoop. The first one which is about 41" per my measurement. I dont want the head light revolution one. I was wondering if anyone has installed multiple 6 inch light bars and how did it go?
    DD sells a 42" light bar and I wondered if anyone had tried that one in the hood scoop slot?
    Thanks in advance
  2. May 17, 2024 at 12:50 PM
    edwardlyle
    edwardlyle New Member
    I bought the one from whoever sells it that is custom fit for the hood scoop. It was an easy install and it has been great.
    I've had it for over a year with no issues and it wires into the factory bright switch.
  3. May 17, 2024 at 3:07 PM
    That's the NSV and Headlight Revolution sells it.
    bulldog93 likes this.
  4. May 17, 2024 at 3:08 PM
    I don't think the DD 42" will fit. I have the BD S8 40" and it's tight.
  5. May 17, 2024 at 6:28 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Hood scoop or hood bulge?
    Bayou Spartan[OP] likes this.
  6. May 18, 2024 at 4:22 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    The hood scoop which is the larger of the two. Definitely not the small one which i thought was the bulge
  7. May 18, 2024 at 4:39 AM
    The large opening is the bulge. The scoop is the smaller one.
  8. May 18, 2024 at 4:41 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
  9. May 18, 2024 at 10:05 AM
    NatesNightMare
    Pinetop Az
    Youre backwards
  10. May 18, 2024 at 12:04 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Bulge
    Thanks all and thanks for the picture that made it very clear to me that I was in error. Now that I have that information i will continue to look for something to fit in that space that is not the one from HLR.com. I just think that there has to be other options out there that are as bright as the DD. pros I have as fog lights or the Morimoto 4bangers that I have as ditch lights.
  11. May 21, 2024 at 2:08 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    i have read about this one and i wanted to see what other options there were. Worst case , i'll just have to go this route. Thanks.
  12. May 21, 2024 at 8:11 AM
    The NSV is a plug and play fitment without having to cut anything. They changed the wiring to where it is only powered when the high beams are on if i recall correctly. I don't know if anyone has modded or rewired theirs differently with success. Another note on the NSV is that for $1K, it is only 9,000 lumens. For roughly a slightly higher price, the BD S8 40 inch is over 25,000 lumens. Below is the mounting kit if you go the BD route and I also attached the installation instructions so that you can see what is involved.
    https://sdhqoffroad.com/products/14-20-toyota-tundra-sdhq-built-hood-scoop-led-light-bar-mount
  13. May 25, 2024 at 5:11 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thanks all my bar should arrive today and the hardware came yesterday
    Ironically I saw a tundra with a bar in the bulge
    Though I’m not sure what kind it was. That was the confirmation I needed
    Tundra234 likes this.
  14. May 25, 2024 at 6:42 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    S8 bar recieved
