Dirt Getting Inside of Tailgate
Discussion in '3rd Gen Tundras (2022+)' started by HeBeGB501, May 24, 2024.
  1. May 24, 2024 at 8:20 PM
    HeBeGB501
    HeBeGB501 [OP] New Member
    2024 White Tundra Limited, TRD OffRoad
    Has anyone had issues with getting dirt inside of the tailgate? I hauled a load of dirt and once I unloaded and sprayed out the bed, muddy water began dripping from the tailgate handle and painted plastic trim. I removed the black, top, cap and found some dirt. I cleaned that off and tried spraying out the inside of the gate, through the exposed holes but I still get muddy water dripping down the outside of the tailgate.
    My guess is that the dirt came from sweeping out the last remaining dirt from the bed, over the open tail gate.
    I assume I can pull the painted trim off as well but before I do that, how can I prevent it from happening again? I tried searching but all I find are people discussing sealing around the tailgate to prevent dust getting inside the bed. Has anyone tried sealing under the plastic trim cap.
    The attached picture is after trying to wash out the inside of the tailgate.
  2. May 24, 2024 at 8:40 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I don't have a 3rd Gen, but it probably still applies since there always seems to be a gap at the bottom of the tailgate liners. Whenever I hose out the bed, I always keep the tailgate up to prevent all the water from getting underneath there especially considering the backup camera is in there. I hose everything to the back and all the stuff that doesn't get washed out between the bed and tailgate, I just pull out by hand. But that's just me. :facepalm:
  3. May 24, 2024 at 8:50 PM
    *D*
    *D* New Member
    Dimitri
    Rhode Island
    ‘24 DC Long Bed 4x4 SR5
    Remove the panel on the inside of the tailgate and see what’s going on.
    When body panels are designed properly, there is an understanding that water (or dirt in your case) will inevitably get in- and it will also need a way to get out.
    Make sure you don’t block or seal any opportunity for drainage.
    Next time you haul dirt, let the bed dry naturally after emptying it. Sweeping it after that won’t force it into your tailgate.
    Reaper1911 likes this.
  4. May 25, 2024 at 5:32 AM
    therandomsuit
    therandomsuit New Member
    Yep, this happened to me last summer. I hauled 12 yards of top soil(3/4 yard at a time) and I had the exact same thing happen. I blew everything off with an air compressor and then pressure washed it a few times. It finds its way out eventually.
  5. May 26, 2024 at 8:06 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Not the tailgate but. I sprayed my truck off yesterday and kept getting muddy water running out of the front of the front fender flare.
  6. May 26, 2024 at 6:17 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I took my front flares off yesterday while taking the front off to install my lightbar.
    There was about 3” inches of muddy dust trapped at the bottom of the flares. It seems that there are many places to store dirt on our trucks!
  7. Jun 25, 2024 at 6:37 PM
    HeBeGB501
    I wanted to post an update to my original problem. I had to haul another yard of dirt plus another load of a pallet of sod. Once all done, I made sure to sweep off the tailgate by sweeping back towards the truck bed, not right off of the end. I also kept the tailgate up, as @TILLY suggested, when pressure washing the bed out. This method was successful, there was no more muddy water draining from the top of the tailgate.
