2002 v8 4x4 transmission slipping 1st to 2nd.
Discussion in '1st Gen Tundras (2000-2006)' started by parkss1181, May 21, 2024.
  1. May 21, 2024 at 6:09 PM
    parkss1181
    parkss1181 [OP] New Member
    Shane
    2002 TRD limited Access cab V8 4X4
    None yet, some to come !
    First and foremost I did research a bunch before posting this, I know in the 00-02’s the OD gear is a bit of a ticking time bomb. I’m assuming that’s what’s going on with my rig I just purchased (still got it at a steal so not too upset… knew it was gonna need some things)
    does anyone have a 03-04 or know someone with a replacement for sale? Looked around my local marketplace definitely little bit expensive. Need to call some junkyards tomorrow. But if anyone has a good deal they wanna do near. NYC area id love to have a spare lying around.
    1st thing I know I need to do is grease the drive line just for maintenance I seen it’s pretty big with our 1st gen’s.. I don’t think this will be my solution but definitely hope it could be lol.. the transmission acts pretty normal if I’m going at a light light acceleration. Grandma driving, once I put any good bit of acceleration into the pedal from a stop going from 1st to second you can feel it slipping and then a hard thud going to second. Every other gear no issue. I also need to check the transmission fluid of course. I was also thinking of using a better synthetic tranny fluid, and Lucas treatment. I’d like to get the most I can out of it. Any suggestions would be helpful as I did read a lot of the forums and the sticky’d post and previous others giving me advice. Thank you everyone in advance for any reply’s coming this way. I’m still new to my 1st gen. Only took it for 3 rides so far so sorry for any noob questions.
  2. May 21, 2024 at 6:56 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    What is the condition of the transmission fluid? That's the first step before you go spending time and money finding a replacement. No need to use any other transmission fluid than what's recommended. Stick to the basics first.
  3. May 22, 2024 at 9:06 AM
    parkss1181
    Shane
    Yeah i said i needed to check that first, i know I need to drive it for a good bit before I check it and want to see it’s at the top of the dipstick if im not mistaken.
  4. May 22, 2024 at 9:32 AM
    bfunke
    bfunke Tundra Curmudgeon
    Read Shifty’s FGT mega thread.
  5. May 22, 2024 at 9:47 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Once you check your transmission fluid (in the "So you bought a..." stickied thread) according to the full service manual and/or owner's manual's procedure, if you still have a problem then you can hunt up a replacement tranny at car-part.com. It's a pretty decent site once you figure out how to use it.
  6. May 22, 2024 at 10:12 AM
    ATBAV8
    Tempe, AZ
    Right. You need to drive it and get the transmission up to operating temperature to check the LEVEL with the engine running. How about just pulling the dipstick and checking the condition of the fluid? Is it brown? Does it smell burnt? It should be a nice ruby red and not have a burnt odor. Why not do that?
  7. May 22, 2024 at 1:42 PM
    parkss1181
    Shane
    hard to tell but I marked where it was showing on the trans dipstick. I took it for a 25sh min ride, half city half highway driving, after I was done driving cycled through the gears staying around 3sh seconds in each gear. This is what my dipstick is showing. Definitely low. I’ll have to pick up some ATF and top it off, I also see that it’s a bit tricky to get right and you don’t want to overfill it. If I also don’t know what ATF is in it (previous owner didn’t know.) should I just do a flush all together? I believe he always had it maintenanced by Toyota or a known mechanic.
    doesn’t seem to smell burnt. Also is a nice red color.
  8. May 22, 2024 at 2:59 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Start by topping it off with DEX III ATF (or equivalent). I use Castrol Transmax:
  9. May 22, 2024 at 3:02 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'd do a full flush of the transmission, my tundra and sequoia both hard really hard shifts when I got them, but new trans fluid cleared that up.
    parkss1181[OP] likes this.
  10. May 22, 2024 at 3:25 PM
    parkss1181
    Shane
    Should I be topping off in specific increments to avoid overfilling?
  11. May 22, 2024 at 3:30 PM
    w666
    Maryland
    Indeed
  12. May 22, 2024 at 4:08 PM
    Not only adding in increments, but you also need to shift back/forth thru the gears with the engine running after adding fluid at least a half a dozen times to move fluid.
  13. May 22, 2024 at 4:33 PM
    parkss1181
    Shane
    Sounds good. I’ll have some
    Hope In this clearing up the hard shifts… 03-04 trannys aren’t too expensive I’ve already found a few. But hopefully this clears it up!
  14. May 23, 2024 at 6:57 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    This is kinda common. My truck does it. Apparently it'll just do it for a very long time and not get worse nor better. I'm just easy on my truck with the 1-2 shift, or I'll put it in "2" before taking off then it shifts great, then put into "D" after it shifts to 2nd.
    I did a couple drain and fills a while back and am planning to do another soon but it's made no difference in the way it drives at all, just good to cycle through some new fluid. Drain and fill is easy as it has a drain plug. Just have to do it a couple or few times.
  15. May 24, 2024 at 3:37 AM
    parkss1181
    Shane
    I ended up getting some dex3, didn’t even put it in. First got some Lucas tranny conditioner which was 20 OZs put it in and went for a 30sh min ride, shifted to each gear with 3ssh seconds holding the shifts and going back up same way to park, engine still running took 3 readings and it was here way over the hot line. I’m assuming 20sh min last time wasn’t enough for an accurate reading as just 20 oz over filled it. I’m gonna take some back out later today after work and warm it up and take a reading. After doing the conditioner no change in the transmission behavior.
  16. May 24, 2024 at 10:33 AM
    parkss1181
    Shane
    Has anyone had good results using amsoil as a replacement? Maybe a good synthetic ATf and flush could extend the life of the Tranny..
