Any Tips on Removing the Relay for the Foglights?
Discussion in '1st Gen Tundras (2000-2006)' started by Oldfart01, May 22, 2024.
  1. May 22, 2024 at 11:15 AM
    Oldfart01
    Oldfart01 [OP] New Member
    PA
    2006 Silver Tundra SR5 DC 4.7
    I recently had both of the fogs on my '06 DC stop working. Everything is stock. The 15 amp fuse in the interior fuse box is good, so I'm assuming I need to replace the relay. I did find on here that it should be the bottom, middle, relay on the back of the interior fuse panel. Problem is I can't get it out, it's really tight in there for my XXL hands. Any tips on how to get to it and remove it so I can replace it? Is there a locking tab or anything like that on it? I can see it a little bit with a mirror, it's blue, but I can't see it too well or reach it very well. Thanks very much in advance.
  2. May 22, 2024 at 11:20 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Needle nose pliers and some gentle wiggling.
    I'm pretty sure there's also specific tools for the job. But let's face it, needle nose with some gentle back and fourth and gently pulling up should get it done
    The Black Mamba and metalpete like this.
  3. May 22, 2024 at 2:39 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Have you confirmed the bulbs are good?
    When i bought my truck it had 144,000 on the ticker, one owner who passed away and the truck sat in his yard about 2-3 years before someone in the family took it to the local dealership and used it as a trade in on another vehicle. The truck was green, (white paint covered in mildew or grime from a tree) and the dealership pretty much listed it for get rid of it price. They didnt want to touch it, clean it, inspect it, basically the sale listing was "trade in, one owner, low mileage, auction price" I knew enough about the trucks that i knew the condition it was in, all original body panels, original windshield without a single rock peck, not a single rock chip on the hood, interior was flawless other than a coffee stain or two in the carpet, timing belt had been done at 100k, i knew the truck would be solid after some clean up. I bought it and when i got it home realized almost none of the lights worked. I had one headlight working, one tail light, and a few blinkers, thats it.
    I took it to auto zone and spent over $120 i had to replace both fogs, both headlights, both front running lights, both blinker lights, and everything in the tails except the reverse lights. Half the radio bezel lights were dead and burnt out, the overhead console button lights were out (still are). I guess the old man drove it during the day and never realized the lights were burning out one at a time or maybe the filaments got brittle from sitting up a while i dont know. Maybe check the bulbs just to be sure cause when i bought my truck both were DOA
  4. May 22, 2024 at 3:07 PM
    Oldfart01
    PA
    I'll double check the bulbs. I assumed they were good, they look clear, and they both worked fine for the 2 months I've had it, then they both quit at the same time.
  5. May 22, 2024 at 3:27 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you check the switch?
  6. May 22, 2024 at 4:43 PM
    Oldfart01
    PA
    If there is an on/off switch for the fogs, I haven't seen it in the few months I've owned it. I just went out and triple checked when I saw your post, there is no visible switch. As far as I know, they run whenever the lights are on. I did just pull the bulbs and there is no current being delivered with lights on and low beam. It's an '06 DC SR5. While looking with a mirror, I can see the relay on the bottom rear side of the interior fuse panel that some other posters in a different thread said runs the fogs, but I can't get it out so far. It's real tight on both sides of the relay and almost no room to work. Thank you for your input.
  7. May 22, 2024 at 4:48 PM
    The switch is the inner ring closest to the steering wheel on the stalk with the light controls
  8. May 22, 2024 at 5:18 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Seems you already know that they will only come on with the lo beam head lights on.
    They should go off with high beams.
    upload_2024-5-22_19-14-40.pngupload_2024-5-22_19-15-44.pngupload_2024-5-22_19-15-10.png
  9. May 22, 2024 at 5:22 PM
    They also often won't come on properly if you've done something silly, like upgrading your headlights to LED without making the appropriate changes to other stuff.
    But @Oldfart01 said everything is still stock, so I guess he didn't install any LED lights.
  10. May 22, 2024 at 5:39 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    I start by taking out other relays so I can get a good grip on the one I want. Then, use the wiggle & rock technique to gently pull it out.
    There's only a couple different relays, so I wouldn't be worried about mixing them up.
    1lowlife likes this.
  11. May 22, 2024 at 5:51 PM
    Oldfart01
    PA
    DING, DING DING!! I'm trying to think of something clever to say, other than that I guess I'm a dumb ass and didn't know it! :crazy: I had looked really hard at all the dash switches since I bought it. I've never seen a switch like that little ring on the light stalk. I read your reply and thought, "No way I missed something like that!" :rolleyes: Grabbed a flashlight and ran out to the truck and the lights magically came on after I turned the ring.
    I must have turned them off by accident while turning the headlight switch knob. I'm a little upset that you ruined all the fun I could have had tearing stuff apart for no reason. :frusty::frusty::frusty: I could have driven the truck another year and not noticed that little ring. I guess the dementia is sneaking up on me! Thank you for preventing me from continued mental retardation. :goingcrazy:
  12. May 22, 2024 at 6:04 PM
    Oldfart01
    PA
    Thank you, it's a good thing I don't embarrass easily!!! :goingcrazy::goingcrazy:Easiest repair ever.
    metalpete and 1lowlife[QUOTED] like this.
  13. May 22, 2024 at 6:08 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    We're just glad you got it working..:thumbsup:
    I've done worse..:cool:
  14. May 23, 2024 at 8:13 AM
    badass03taco
    well son of a biscuit eater.... that was an easy one.
  15. May 23, 2024 at 8:21 AM
    Oldfart01
    PA
    :D I wish more things could be fixed that easy!!
  16. May 23, 2024 at 9:09 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    So now you need to take a pic of you turning that switch and post it in the "What have you done to your 1st gen today" thread :thumbsup:
  17. May 23, 2024 at 9:12 AM
    FishNinja
    Lee
    06DC2wd
    +1
  18. May 23, 2024 at 9:12 AM
    I’m in the camp of never using them, and it drives me bananas when people have them on in the day time let alone no bad weather
    FishNinja likes this.
  19. May 23, 2024 at 9:13 AM
    FishNinja
    Lee
    06DC2wd
  20. May 23, 2024 at 9:17 AM
    Those probably actually work and the weather looks gloomy, you get a pass, this time
  21. May 23, 2024 at 9:20 AM
    They technically can, just use fire. Add fire to truck, burn it to the ground. No switch? No problem. Ergo, problem solved.
  22. May 23, 2024 at 9:21 AM
    FishNinja
    Lee
    06DC2wd
    they do, they're so bright that even during overcast days you can see the yellow reflecting off some surfaces.
  23. May 23, 2024 at 9:23 AM
    FishNinja
    Lee
    06DC2wd
    it's inferior so you'd be doing the world a favor.
  24. May 23, 2024 at 9:28 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Don't make me call in elevatorguy on you:rofl:
  25. May 23, 2024 at 9:30 AM
    FishNinja
    Lee
    06DC2wd
  26. May 23, 2024 at 9:58 AM
    Oldfart01
    PA
    :woot:
  27. May 23, 2024 at 2:42 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Thought DRLs were stupid long ago... now rides with fogs on 24/7 :bananadance::anonymous:
